Hey guys
I was updating my system today. And out of nowhere my laptop freezes.
I tried to reboot it and in my systemd-boot menu I could only log into the windows or bios menu.
I plugged in a liv eos usb and tried to chroot into my system to repair the sytemd boot menu. But it won’t chroot and shows error.
See below.
[liveuser@eos-2023.05.28 ~]$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/archiso/airootfs
sda
├─sda1
└─sda2 ntfs Data ACB8E6D1B8E6995A
sdb iso9660 Joliet Extension EOS_202305 2023-05-28-11-02-36-00
├─sdb1 iso9660 Joliet Extension EOS_202305 2023-05-28-11-02-36-00 0 100% /run/archiso/bootmnt
└─sdb2 vfat FAT16 ARCHISO_EFI 5770-579C
nvme0n1
├─nvme0n1p1 vfat FAT32 SYSTEM_DRV BE06-D24C
├─nvme0n1p2
├─nvme0n1p3 ntfs Windows-SSD F8E80860E808200C
├─nvme0n1p4 ntfs WINRE_DRV EE14095214091EE9
├─nvme0n1p5 vfat FAT32 3E4E-89BF
├─nvme0n1p6 ext4 1.0 endeavouros 3d03e897-6bf0-4063-b681-cbac7e9e3ccf
└─nvme0n1p7 swap 1 0a30e8fb-f0b9-4a9a-a0b3-736c894653e2
sudo mount /dev/nvme0n1p6 /mnt
[liveuser@eos-2023.05.28 ~]$ sudo cat /mnt/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=3E4E-89BF /efi vfat defaults,noatime 0 2
UUID=3d03e897-6bf0-4063-b681-cbac7e9e3ccf / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
sudo mount /dev/nvme0n1p5 /mnt/efi
[liveuser@eos-2023.05.28 ~]$ sudo arch-chroot /mnt
chroot: failed to run command ‘/bin/bash’: Exec format error
I’m stuck here.
And below are my mount points
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 1.7G 1 loop /run/archiso/airootfs
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 16M 0 part
└─sda2 8:2 0 931.5G 0 part
sdb 8:16 1 29G 0 disk
├─sdb1 8:17 1 1.8G 0 part /run/archiso/bootmnt
└─sdb2 8:18 1 111M 0 part
nvme0n1 259:0 0 476.9G 0 disk
├─nvme0n1p1 259:1 0 260M 0 part
├─nvme0n1p2 259:2 0 16M 0 part
├─nvme0n1p3 259:3 0 182.7G 0 part
├─nvme0n1p4 259:4 0 1000M 0 part
├─nvme0n1p5 259:5 0 1000M 0 part /mnt/efi
├─nvme0n1p6 259:6 0 272.7G 0 part /mnt
└─nvme0n1p7 259:7 0 19.3G 0 part
Any ideas on what I can do?
