I can connect to the guest with ssh from the host, but when I try from my windows laptop it doesn’t work. I can connect to the host’s ssh from the laptop. This worked a few weeks ago. I use this because I use wifi.
/etc/libvirt/hooks/qemu
#!/bin/bash
# IMPORTANT: Change the "VM NAME" string to match your actual VM Name.
# In order to create rules to other VMs, just duplicate the below block and configure
# it accordingly.
if [ "${1}" = "almalinux9" ] || [ "${1}" = "rocky9" ] || [ "${1}" = "almalinux8" ]; then
# Update the following variables to fit your setup
GUEST_IP=192.168.122.10
GUEST_PORT=22
HOST_PORT=2222
GUEST_PORT1=51820
HOST_PORT1=51820
GUEST_PORT2=6543
HOST_PORT2=6543
if [ "${2}" = "stopped" ] || [ "${2}" = "reconnect" ]; then
/sbin/iptables -D FORWARD -o virbr0 -p tcp -d $GUEST_IP --dport $GUEST_PORT -j ACCEPT
/sbin/iptables -t nat -D PREROUTING -p tcp --dport $HOST_PORT -j DNAT --to $GUEST_IP:$GUEST_PORT
/sbin/iptables -D FORWARD -o virbr0 -p udp -d $GUEST_IP --dport $GUEST_PORT1 -j ACCEPT
/sbin/iptables -t nat -D PREROUTING -p udp --dport $HOST_PORT1 -j DNAT --to $GUEST_IP:$GUEST_PORT1
/sbin/iptables -D FORWARD -o virbr0 -p tcp -d $GUEST_IP --dport $GUEST_PORT2 -j ACCEPT
/sbin/iptables -t nat -D PREROUTING -p tcp --dport $HOST_PORT2 -j DNAT --to $GUEST_IP:$GUEST_PORT2
fi
if [ "${2}" = "start" ] || [ "${2}" = "reconnect" ]; then
/sbin/iptables -I FORWARD -o virbr0 -p tcp -d $GUEST_IP --dport $GUEST_PORT -j ACCEPT
/sbin/iptables -t nat -I PREROUTING -p tcp --dport $HOST_PORT -j DNAT --to $GUEST_IP:$GUEST_PORT
/sbin/iptables -I FORWARD -o virbr0 -p udp -d $GUEST_IP --dport $GUEST_PORT1 -j ACCEPT
/sbin/iptables -t nat -I PREROUTING -p udp --dport $HOST_PORT1 -j DNAT --to $GUEST_IP:$GUEST_PORT1
/sbin/iptables -I FORWARD -o virbr0 -p tcp -d $GUEST_IP --dport $GUEST_PORT2 -j ACCEPT
/sbin/iptables -t nat -I PREROUTING -p tcp --dport $HOST_PORT2 -j DNAT --to $GUEST_IP:$GUEST_PORT2
fi
fi
The default network is available
sudo virsh net-list
[sudo] password for csaba:
Name State Autostart Persistent
default active yes yes
macvtap-net active yes yes
sudo iptables -L -n -v
Chain FORWARD (policy ACCEPT 364 packets, 28778 bytes)
pkts bytes target prot opt in out source destination
0 0 ACCEPT 6 -- * virbr0 0.0.0.0/0 192.168.122.10 tcp dpt:6543
0 0 ACCEPT 17 -- * virbr0 0.0.0.0/0 192.168.122.10 udp dpt:51820
0 0 ACCEPT 6 -- * virbr0 0.0.0.0/0 192.168.122.10 tcp dpt:22
5: virbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 52:54:00:ab:cc:61 brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
valid_lft forever preferred_lft forever
The debug ssh -vvv output from the laptop
debug2: ssh_connect_direct
debug1: Connecting to 192.168.1.107 [192.168.1.107] port 2222.
debug3: finish_connect - ERROR: async io completed with error: 10060, io:00000222AC81EF50
debug1: connect to address 192.168.1.107 port 2222: Connection timed out
ssh: connect to host 192.168.1.107 port 2222: Connection timed out
