The keybinding $mod+c to launcher wofer (a file manager won’t work). I can launch via terminal with the command “wofer” and if works fine.
$mod+d to launch dolphin too won’t work
Here’s my config
# Autostart
exec systemctl --user import-environment SWAYSOCK WAYLAND_DISPLAY
exec /home/aryan/Apps/pcloud
exec /usr/lib/kdeconnectd
exec kdeconnect-indicator
exec picom --experimental-backends
exec mako
exec /usr/lib/polkit-kde-authentication-agent-1
exec nm-applet --indicator
exec autotiling-rs
exec mkfifo $SWAYSOCK.wob && tail -f $SWAYSOCK.wob | wob --border-color '#ff5e81ac' --background-color '#cc2e3440' --bar-color '#ff5e81ac'
exec ~/.azotebg
exec gammastep
exec lxpolkit
exec swaybg -i /home/aryan/Pictures/wallpapers/firecool.png
exec mako
# exec /usr/share/sway/scripts/inactive-windows-transparency.py
# exec syncthing -no-browser
# Dynamic Wallpaper
# exec oguri -c ~/.config/oguri/config
# exec dwall -s flcl &
input * xkb_layout "gb"
# Windows Rules
for_window [class="(?i)ark"] floating enable
for_window [class="(?i)mpv"] floating enable
for_window [app_id="imv"] floating enable, border pixel 3
for_window [app_id="pavucontrol"] floating enable, sticky enable, resize set width 550 px height 600px, move position cursor, move down 330
for_window [title=".+[Ss]haring (Indicator|your screen)"] floating enable, move to scratchpad
for_window [title="Copying"] floating enable
for_window [title="Discord Updater"] floating enable
for_window [app_id="dolphin" window_type="utility"] floating enable
for_window [title="File Already Exist"] floating enable
for_window [workspace="4"] layout tabbed
for_window [workspace="5"] layout tabbed
### Variables
# Logo key. Use Mod1 for Alt.
set $mod Mod4
# Home row direction keys, like vim
set $left h
set $down j
set $up k
set $right l
# Your preferred terminal emulator
set $term alacritty
# Your preferred application launcher
# Note: pass the final command to swaymsg so that the resulting window can be opened
# on the original workspace that the command was run on.
set $menu wofi -c ~/.config/wofi/config -I
bindsym $mod+backspace exec fish -c wofer
bindsym $mod+c exec wofer
bindsym $mod+d exec wofi-emoji
#bindsym $mod+m exec fish -c 'manga_menu'
# Disable titlebar
default_border pixel 3
# Font
# title_align center
font pango:ProductSansMedium 14px
# Window decoration
# class border backgr. text indicator child_border
client.focused #5e81ac #5e81ac #eceff4 #434c5e #5e81ac
client.focused_inactive #4c566a #4c566a #d8dee9 #3b4252 #434c5e
client.unfocused #4c566a #4c566a #d8dee9 #3b4252 #434c5e
client.urgent #7c818c #bf616a #eceff4 #900000 #bf616a
client.placeholder #000000 #0c0c0c #eceff4 #000000 #0c0c0c
#Asignments
assign [app_id="lutris"] 4
assign [app_id="gamehub"] 4
assign [app_id="steam"] 4
assign [app_id="virt-manager"] 6
assign [app_id="virtualbox"] 6
assign [app_id="Signal"] 5
assign [title="Signal"] 5
assign [app_id="discord"] 5
assign [title="discord"] 5
assign [title="Wine System Tray"] scratchpad
# Additionally, you can issue commands with the following syntax. This is useful to bind keys to changing the gap size.
#gaps inner 10
gaps outer 5
### Output configuration
# Default wallpaper (more resolutions are available in /usr/share/backgrounds/sway/)
# output "*" bg ~/wallpapers/1.jpg fill
# swaybg_command -
# Example configuration:
output HDMI-A-I {
pos 0 0
res 2560x1440
adaptive_sync off
scale 1
# output HDMI-A-1 resolution 2560x1440 position 0,0 scale
# You can get the names of your outputs by running: swaymsg -t get_outputs
### Idle configuration
exec swayidle -w\
timeout 1070 'swaylock -f -C ~/.config/swaylock/config'\
timeout 770 'swaymsg "output * dpms off"' \
resume 'swaymsg "output * dpms on"' \
before-sleep 'swaylock -C ~/.config/swaylock/config'
# This will lock your screen after 300 seconds of inactivity, then turn off
# your displays after another 300 seconds, and turn your screens back on when
# resumed. It will also lock your screen before your computer goes to sleep.
# Screenlocking
bindsym $mod+f1 exec ~/.config/sway/lockman.sh
bindsym $mod+f12 exec ~/.config/sway/lockman.sh
# Screenshot with grim and swappy
bindsym print exec /home/aryan/.config/sway/screenshot.sh
### Input configuration
input "1267:12363:ELAN0650:01_04F3:304B_Touchpad" {
dwt enabled
tap enabled
natural_scroll enabled
middle_emulation enabled
# You can get the names of your inputs by running: swaymsg -t get_inputs
# Read `man 5 sway-input` for more information about this section.
#Borders
border_images.focused ~/.config/sway/borders/focused.png
border_images.focused_inactive ~/.config/sway/borders/focused_inactive.png
border_images.unfocused ~/.config/sway/borders/unfocused.png
border_images.urgent ~/.config/sway/borders/urgent.png
gaps inner 28
### Key bindings
# Basics:
# Launch a terminal
bindsym $mod+return exec $term
# Kill focused window
bindsym $mod+X kill
# Start your launcher
bindsym $mod+Space exec $menu
# Launch Dolphin
# bindsym $mod+d exec dolphin
# Drag floating windows by holding down $mod and left mouse button.
# Resize them with right mouse button + $mod.
# Despite the name, also works for non-floating windows.
# Change normal to inverse to use left mouse button for resizing and right
# mouse button for dragging.
floating_modifier $mod normal
# Reload the configuration file
bindsym $mod+Shift+c reload
# Power menu
bindsym $mod+Shift+e exec wlogout -p layer-shell
# Moving around:
# Move your focus around
bindsym $mod+$left focus left
bindsym $mod+$down focus down
bindsym $mod+$up focus up
bindsym $mod+$right focus right
# Or use $mod+[up|down|left|right]
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# Move the focused window with the same, but add Shift
bindsym $mod+Shift+$left move left
bindsym $mod+Shift+$down move down
bindsym $mod+Shift+$up move up
bindsym $mod+Shift+$right move right
# Ditto, with arrow keys
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# Workspaces:
# Switch to workspace
bindsym $mod+1 workspace 1
bindsym $mod+2 workspace 2
bindsym $mod+3 workspace 3
bindsym $mod+4 workspace 4
bindsym $mod+5 workspace 5
bindsym $mod+6 workspace 6
bindsym $mod+7 workspace 7
bindsym $mod+8 workspace 8
bindsym $mod+9 workspace 9
bindsym $mod+0 workspace 10
# Move focused container to workspace
bindsym $mod+Shift+1 move container to workspace 1
bindsym $mod+Shift+2 move container to workspace 2
bindsym $mod+Shift+3 move container to workspace 3
bindsym $mod+Shift+4 move container to workspace 4
bindsym $mod+Shift+5 move container to workspace 5
bindsym $mod+Shift+6 move container to workspace 6
bindsym $mod+Shift+7 move container to workspace 7
bindsym $mod+Shift+8 move container to workspace 8
bindsym $mod+Shift+9 move container to workspace 9
bindsym $mod+Shift+0 move container to workspace 10
# Note: workspaces can have any name you want, not just numbers.
# We just use 1-10 as the default.
# Switch to next/previous workspace
bindsym ctrl+Alt+Right workspace next_on_output
bindsym ctrl+Alt+$right workspace next_on_output
bindsym ctrl+Alt+Left workspace prev_on_output
bindsym ctrl+Alt+$left workspace prev_on_output
# Layout stuff:
# You can "split" the current object of your focus with
# $mod+b or $mod+v, for horizontal and vertical splits
# respectively.
bindsym $mod+b splith
bindsym $mod+v splitv
# Switch the current container between different layout styles
bindsym $mod+s layout stacking
bindsym $mod+Tab layout tabbed
bindsym $mod+e layout toggle split
# Make the current focus fullscreen
bindsym $mod+f fullscreen
# Toggle the current focus between tiling and floating mode
bindsym alt+Space floating toggle
# Swap focus between the tiling area and the floating area
bindsym shift+space focus mode_toggle
# Move focus to the parent container
bindsym $mod+a focus parent
# Back and Forth
# bindsym $mod+d workspace back_and_forth
# Scratchpad:
# Sway has a "scratchpad", which is a bag of holding for windows.
# You can send windows there and get them back later.
# Move the currently focused window to the scratchpad
bindsym $mod+Shift+minus move scratchpad
# Show the next scratchpad window or hide the focused scratchpad window.
# If there are multiple scratchpad windows, this command cycles through them.
bindsym alt+tab scratchpad show
bindsym $mod+minus scratchpad show
# Resizing containers:
bindsym $mod+alt+$left resize shrink width 20px
bindsym $mod+alt+$up resize grow height 20px
bindsym $mod+alt+$down resize shrink height 20px
bindsym $mod+alt+$right resize grow width 20px
bindsym $mod+alt+Left resize shrink width 20px
bindsym $mod+alt+Up resize grow height 20px
bindsym $mod+alt+Down resize shrink height 20px
bindsym $mod+alt+Right resize grow width 20px
# Return to default mode
# bindsym Return mode "default"
# bindsym Escape mode "default"
# mode resize {
# left will shrink the containers width
# right will grow the containers width
# up will shrink the containers height
# down will grow the containers height
# bindsym $mod+r mode "resize"
# Status Bar:
# Read `man 5 sway-bar` for more information about this section.
bar {
swaybar_command waybar
include /etc/sway/config.d/*
# Special keys
# /usr/include/xkbcommon/xkbcommon-keysyms.h
bindsym XF86AudioRaiseVolume exec pamixer -ui 2 && pamixer --get-volume > $SWAYSOCK.wob
bindsym XF86AudioLowerVolume exec pamixer -ud 2 && pamixer --get-volume > $SWAYSOCK.wob
bindsym XF86AudioMute exec pamixer --toggle-mute && ( pamixer --get-mute && echo 0 > $SWAYSOCK.wob ) || pamixer --get-volume > $SWAYSOCK.wob
bindsym XF86MonBrightnessUp exec brightnessctl -c backlight set +1%
bindsym XF86MonBrightnessDown exec brightnessctl -c backlight set 1%-
bindsym XF86KbdBrightnessUp exec brightnessctl -c backlight set +1%
bindsym XF86KbdBrightnessDown exec brightnessctl -c backlight set 1%-
bindsym XF86AudioPlay exec playerctl play-pause
bindsym XF86AudioNext exec playerctl next
bindsym XF86AudioPrev exec playerctl previous
exec_always {
gsettings set org.gnome.desktop.interface gtk-theme 'NordSur-dark'
#gsettings set $gnome-schema gtk-theme 'NordSur-dark'
gsettings set org.gnome.desktop.interface icon-theme 'Papirus-Dark'
