Hello,
I run Linux in a VM using QXL for graphics I use Gnome and RDP (gnome-remote-desktop) and for the most part it is a tolerable experience.
Recently I tried Fedora and noticed that it is significantly snappier. It was so noticeable that I went to the trouble of benchmarking graphics and found that indeed there is a significant difference between the two. I installed a fresh copy of EOS and created a new user (to make sure it was not something I’ve messed up in my configuraiton). I ran glmark2 on both VMs and here is the comparison which quantifies my perception:
# EOS scores
[localuser@eos bmk]$ tail -n2 glmark-*.log
==> glmark-es2.log <==
glmark2 Score: 322
==> glmark-es2-wayland.log <==
glmark2 Score: 360
==> glmark-wayland.log <==
glmark2 Score: 418
# Fedora scores
[localuser@fedora bmk]$ tail -n2 *.log
glmark2 Score: 314
glmark2 Score: 546
glmark2 Score: 639
Now, I do run Gnome on wayland, and as you can see 360/546 and 418/639 in favor of Fedora which is almost 50% faster.
I noticed that Fedora uses older newer LLVM (16 vs 17) but newer older MESA (23 vs 24):
# EOS
[user@eos bmk]$ head -n 12 glmark-wayland.log
MESA: error: ZINK: vkCreateInstance failed (VK_ERROR_INCOMPATIBLE_DRIVER)
libEGL warning: egl: failed to create dri2 screen
glmark2 2023.01
OpenGL Information
GL_VENDOR: Mesa
GL_RENDERER: llvmpipe (LLVM 16.0.6, 256 bits)
GL_VERSION: 4.5 (Compatibility Profile) Mesa 24.0.1-arch1.1
Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=32 stencil=0 samples=0
Surface Size: 800x600 windowed
# Fedora
[user@fedora bmk]$ head -n 12 glmark-wayland.log
MESA: error: ZINK: failed to choose pdev
glmark2 2023.01
OpenGL Information
GL_VENDOR: Mesa
GL_RENDERER: llvmpipe (LLVM 17.0.6, 256 bits)
GL_VERSION: 4.5 (Compatibility Profile) Mesa 23.3.5
I can only assume that either:
- there is some significant boost from the newer
MESALLVM - there is some significant regression from the new
LLVMMESA - a combination of both?
Is there any plan to upgrade the mesa LLVM packages in EOS? I plan to re-run as soon as they are released to see if the performance difference disappears.
EDIT: I mixed up the newer/older version comparison for LLVM and MESA.
