My bluetooth headphone mic not reconisied after switching to pipewire
i switched to pipe wire via
sudo pacman -S pipewire pipewire-pulse --needed
my headphone mic is no longer showing up i tried reinstall pulse audio but it still didn’t work so i went back to pipewire.
how do i fix this?
opening pavucontrol and setting my Bluetooth headset to headset unit makes the mic work
Welcome to the forum. Thanks for giving EndeavourOS a try. I hope you enjoy your time here.
Also happy to see you fixed your problem.
Pudge
it can also switch automatic to headset if you start using mic… and after stopping mic usage it switches back to headphone mode…
and welcome to the purple side from me too! :enos:
