Using the Budgie desktop.
6.3.1-arch1-1
Have a look here:
Excellent! Did as you suggested, rebooted, everything looks well. ![]()
Sounds great! ![]()
thank you , had the same problem, worked like a charm, I used them in the same line: sudo pacman -Rdd mutter && sudo pacman -S mutter43
Even the sun has spots!
Honestly, in this case the credit is due to @xircon ![]()
But thanks for the compliment anyway!
Strangely, just had the same issue happen again, but the command did not work.
Then used the Welcome app, and it failed.
Then updated via Pamac (Launch Add/Remove Software) GUI and everything worked.
Guessing I’m not the only one using Budgie Endeavour.
Budgie mutter mutter43 6.4.8-arch1-1
