Multi WM installation
Will it be possible to install two or more windows managers on same installation from installer?
On ArchLabs this is is possible but I did not find this functionality on EndeavourOS installer .
It’s almost certainly possible, but it’s just as easy, if not easier, to install them manually afterwards.
Yes would be easier if scripts to get a specific WM is available to be used to install a new WM along with an existing one
I saw one for openbox on EndeavourOS development page , I hope there is one for Worm as well so I can install it along with my openbox
This post may help How to try out Multiple Window Managers?
