Multi screen problem
Hi.
I’m not good in English, sorry.
I’m using Eos Qtile version. I have a secondary monitor connected to my laptop, but nothing shown in the monitor. so I installed XFCE and then login to it and monitor is OK and working. after logging in to XFCE, logout and login to Qtile. now monitor works in Qtile.
if I login first to Qtile, second monitor will not work, but if I login first to XFCE and then logout and login to Qtile, monitor will works.
I have to screen in my Qtile config file.
Perhaps that helps, you can use arandr or autorandr. I setup my screen as I like them save with autorandr. You can call in qtile
autorandr --change
At each start or restart. Once you saved a profile in autorandr it should automatically detect this setup.
Also her a recent topic with relevant links
Thanks.
I just installed autorandr and created two profiles. It’s detecting the monitor connected and switches to profile automatically.
