Hello! I’m new to EndeavourOS! This is my first installation. I installed using the online method, with xfce4.
My system uses a Ryzen 7 5800H CPU and an RX-6700M GPU. The 5800H has integrated graphics. I think the system installed with the open source AMD drivers, although I honestly don’t know how to verify that. First indication was significantly worse performance playing native CS:GO and TF2 (even with potato settings) compared to the freshly-removed Windows 11. I’ve spent all morning googling things like “how to disable AMD APU/iGPU in linux” to repeated dead ends. I don’t think my barebones linux/manjaro/arch familiarity alone can get me to a solution.
Please help! The following is my output of entering inxi -Fxzr in terminal.
Kernel: 6.0.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.16.1 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Micro-Star product: Delta 15 A5EFK v: REV:1.0
serial: <superuser required>
Mobo: Micro-Star model: MS-15CK v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E15CKAMS.107 date: 10/06/2022
Battery:
ID-1: BAT1 charge: 45.5 Wh (60.1%) condition: 75.7/80.3 Wh (94.3%)
volts: 15.6 min: 15.2 model: MSI Corp. MS-15CK status: not charging
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1478 high: 3710 min/max: 400/4463 boost: enabled cores:
1: 3710 2: 3170 3: 400 4: 400 5: 400 6: 3168 7: 400 8: 400 9: 3007 10: 400
11: 400 12: 3087 13: 400 14: 400 15: 3515 16: 400 bogomips: 102241
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 bus-ID: 03:00.0
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-5.1
bus-ID: 06:00.0 temp: 48.0 C
Device-3: USB C Video Adaptor type: USB driver: N/A bus-ID: 1-1.3:5
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 driver: X:
loaded: amdgpu,modesetting unloaded: radeon dri: radeonsi gpu: amdgpu
resolution: 1: 2560x1440 2: 1920x1080~240Hz
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.12-arch1-1) direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-1.2:4
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 06:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
driver: snd_rn_pci_acp3x v: kernel bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 06:00.6
Device-5: C-Media Antlion USB adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.0.12-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.61 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
bus-ID: 04:00.0
Bluetooth:
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 953.87 GiB used: 116.74 GiB (12.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ1T0HALB-00000
size: 953.87 GiB temp: 37.9 C
ID-1: / size: 921.27 GiB used: 116.74 GiB (12.7%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.52 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): N/A
GPU: device: amdgpu temp: 54.0 C fan: 0 device: amdgpu temp: 48.0 C
Repos:
Packages: 901
Active pacman repo servers in: /etc/pacman.d/endeavouros-mirrorlist
1: https://ca.gate.endeavouros.com/endeavouros/repo/$repo/$arch
2: https://de.freedif.org/EndeavourOS/repo/$repo/$arch
3: https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch
4: https://mirror.moson.org/endeavouros/repo/$repo/$arch
5: https://mirror.funami.tech/endeavouros/repo/$repo/$arch
6: https://endeavour.remi.lu/repo/$repo/$arch
7: https://mirror.jordanrey.me/endeavouros/repo/$repo/$arch
8: https://mirror.linux.pizza/endeavouros/repo/$repo/$arch
9: https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
10: https://mirror.jingk.ai/endeavouros/repo/$repo/$arch
11: https://mirror.archlinux.tw/EndeavourOS/repo/$repo/$arch
12: https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch
13: https://mirror.freedif.org/EndeavourOS/repo/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: https://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
2: https://ord.mirror.rackspace.com/archlinux/$repo/os/$arch
3: https://mirrors.vectair.net/archlinux/$repo/os/$arch
4: https://mirrors.rit.edu/archlinux/$repo/os/$arch
5: https://mirror.fcix.net/archlinux/$repo/os/$arch
6: https://dfw.mirror.rackspace.com/archlinux/$repo/os/$arch
7: https://mirror.hackingand.coffee/arch/$repo/os/$arch
8: https://iad.mirror.rackspace.com/archlinux/$repo/os/$arch
9: https://mirror.arizona.edu/archlinux/$repo/os/$arch
10: https://mirror.tmmworkshop.com/archlinux/$repo/os/$arch
Processes: 358 Uptime: 18m Memory: 15.01 GiB used: 4.47 GiB (29.8%)
Init: systemd Compilers: gcc: 12.2.0 Shell: Zsh v: 5.9 inxi: 3.3.24
