I have a bizarre issue which is that my mouse starts stuttering and then lagging for few seconds.
E.g. I move the mouse and the pointer will move like 5 seconds latter. Or sometimes it moves instantly but the movement stutters.
And this only happens when I plug in the USB key. Once I remove the USB key the mouse works normal again.
I rarely use the USB keys so I can’t tell when this started.
I have tried all three different USB keys that I have and all of them causes the same issue.
What logs should I check to begin troubleshooting this issue ?
P.S. I’m using radeon GPU, wayland and KDE plasma desktop. I have fully updated the system and the issue persists.
There is a new symptom, the first time I plugged in the USB key, my keyboard stopped working. Then I had to plugg/unplugg the USB key a few times before the keyboard was working with the usb key plugged in.
You have a few USB port options there. Currently, if I’m reading it correctly, your mouse is connected to just a USB 2.0 port.
Try putting either the mouse, or the USB key, into one of the USB 3.1 or 3.2 ports.
USB
Rear USB (Total 12 ports)
1 x USB 3.2 Gen 2x2 port (1 x USB Type-C®)
3 x USB 3.2 Gen 2 ports (2 x Type-A + 1 x USB Type-C®)
4 x USB 3.2 Gen 1 port (4 x Type-A)
4 x USB 2.0 ports (4 x Type-A) Front USB (Total 7 ports)
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers supports additional 4 USB 2.0 ports
