Hello,
After installing nvidia drivers using nvidia-installer-dkms
my monitor which is plugged into my graphics card does work. However, I have a second monitor plugged into VGA in my motherboard. This monitor is not detected. I have run lscpi -v
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
Subsystem: ASUSTeK Computer Inc. Device 8534
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: hsw_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f6000000-f70fffff [size=17M]
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff [size=288M]
Kernel driver in use: pcieport
00:02.0 Display controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Kernel driver in use: i915
Kernel modules: i915
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at f7814000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 28
Memory at f7800000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f781f000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
Memory at f781c000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 8576
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at f7810000 (64-bit, non-prefetchable) [size=16K]
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: ce200000-ce3fffff [size=2M]
Prefetchable memory behind bridge: 00000000ce400000-00000000ce5fffff [size=2M]
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: 00000000f2100000-00000000f21fffff [size=1M]
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f781b000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation B85 Express LPC Controller (rev 05)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 27
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f781a000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
Flags: medium devsel, IRQ 18
Memory at f7819000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 8c94
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f7080000 (32-bit, non-prefetchable) [size=16K]
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
Subsystem: ASUSTeK Computer Inc. P8 series motherboard
Flags: bus master, fast devsel, latency 0, IRQ 18
I/O ports at d000 [size=256]
Memory at f2104000 (64-bit, prefetchable) [size=4K]
Memory at f2100000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169, r8168
and xrandr
Screen 0: minimum 8 x 8, current 1360 x 768, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1360x768+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1360x768 60.02*+
1920x1080 59.94 50.00 29.97 25.00 23.98 60.05 60.00 50.04
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
I dont see any hint of the VGA monitor around.
Thanks,
leapingfrog
