Monitor does not show up in xrandr
This is very weird. It’s a complicated problem, so I will list a few facts:
  • Kernel 6.9.6-arch1-1
  • nvidia-dkms 550.90.07-3
  • X11
  • EVGA GTX 1060 SSC 6GB
  • My GPU has 3 displayport outputs: DP-0, DP-2, and DP-4.
  • My primary monitor works regardless of which port it is connected to.
  • xrandr -q shows my primary monitor and its valid modes.
  • nvidia-settings shows both of my monitors, with the correct displayport, name, modes, and all that.
  • If I do not configure X11 (through nvidia-settings) to use my second monitor, it shows up in xrandr -q just fine.
  • If I use nvidia-settings to set up my second monitor, and reboot, I can drag my cursor over to said monitor, and an X shaped cursor shows up and moves as expected, however, no DE or WM will display to said monitor.
  • In the same scenario as above (when X11 uses my monitor), it does not show up in xrandr -q. It does not show up as disconnected, no, the entire DP-0/2/4 port entry is gone from the list.
  • It does not matter which monitor or cable I use, as long as it’s the primary monitor, it works fine.
  • My setup has worked flawlessly for about half a year.
  • I recently had to temporarily move my desktop and use a smaller, HDMI 1080p monitor. I had to set it up in nvidia-settings too, and it worked. The issue started upon returning to my old setup.
  • Windows can use both monitors just fine.
  • Both monitors are identical.
  • Deleting /etc/X11/xorg.conf and re-making it with nvidia-settings did not fix the issue.
Here is my X11 log if it helps:
Xorg.0.log
[     8.058]
X.Org X Server 1.21.1.13
X Protocol Version 11, Revision 0
[     8.058] Current Operating System: Linux wkst 6.9.6-arch1-1 #1 SMP PREEMPT_DYNAMIC Fri, 21 Jun 2024 19:49:19 +0000 x86_64
[     8.058] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=25871b91-1563-4937-9967-0e813e53001a rw nowatchdog nvme_load=YES loglevel=3 nvidia-drm.modeset=1
[     8.059]
[     8.059] Current version of pixman: 0.43.4
[     8.059] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     8.059] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     8.059] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jun 24 17:56:22 2024
[     8.060] (==) Using config file: "/etc/X11/xorg.conf"
[     8.060] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.060] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.060] (==) ServerLayout "Layout0"
[     8.061] (**) |-->Screen "Screen0" (0)
[     8.061] (**) |   |-->Monitor "Monitor0"
[     8.061] (**) |   |-->Device "Device0"
[     8.061] (**) |-->Screen "Screen1" (1)
[     8.061] (**) |   |-->Monitor "Monitor1"
[     8.061] (**) |   |-->Device "Device1"
[     8.061] (**) |-->Input Device "Keyboard0"
[     8.061] (**) |-->Input Device "Mouse0"
[     8.061] (**) Option "Xinerama" "0"
[     8.061] (**) Allowing byte-swapped clients
[     8.061] (==) Automatically adding devices
[     8.061] (==) Automatically enabling devices
[     8.061] (==) Automatically adding GPU devices
[     8.061] (==) Automatically binding GPU devices
[     8.061] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.061] (WW) The directory "/usr/share/fonts/misc" does not exist.
[     8.061] 	Entry deleted from font path.
[     8.061] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[     8.061] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[     8.061] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     8.061] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     8.061] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     8.061] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     8.061] (==) FontPath set to:
[     8.061] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.061] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[     8.061] (WW) Disabling Keyboard0
[     8.061] (WW) Disabling Mouse0
[     8.061] (II) Module ABI versions:
[     8.061] 	X.Org ANSI C Emulation: 0.4
[     8.061] 	X.Org Video Driver: 25.2
[     8.061] 	X.Org XInput driver : 24.4
[     8.061] 	X.Org Server Extension : 10.0
[     8.061] (++) using VT number 7
[     8.061] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.063] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.063] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
[     8.063] (II) xfree86: Adding drm device (/dev/dri/card1)
[     8.063] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:15:00.0/drm/card1
[     8.065] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     8.067] (--) PCI:*(1@0:0:0) 10de:1c03:3842:6264 rev 161, Mem @ 0xfa000000/16777216, 0xfcc0000000/268435456, 0xfcd0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     8.067] (--) PCI: (21@0:0:0) 1002:164e:1458:d000 rev 193, Mem @ 0xfce0000000/268435456, 0xfcf0000000/2097152, 0xfbd00000/524288, I/O @ 0x0000e000/256
[     8.067] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.067] (II) LoadModule: "glx"
[     8.068] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.071] (II) Module glx: vendor="X.Org Foundation"
[     8.071] 	compiled for 1.21.1.13, module version = 1.0.0
[     8.071] 	ABI class: X.Org Server Extension, version 10.0
[     8.071] (II) LoadModule: "nvidia"
[     8.071] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     8.073] (II) Module nvidia: vendor="NVIDIA Corporation"
[     8.073] 	compiled for 1.6.99.901, module version = 1.0.0
[     8.073] 	Module class: X.Org Video Driver
[     8.073] (II) NVIDIA dlloader X Driver  550.90.07  Fri May 31 09:34:34 UTC 2024
[     8.073] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     8.074] (II) Loading sub module "fb"
[     8.074] (II) LoadModule: "fb"
[     8.074] (II) Module "fb" already built-in
[     8.074] (II) Loading sub module "wfb"
[     8.074] (II) LoadModule: "wfb"
[     8.074] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     8.074] (II) Module wfb: vendor="X.Org Foundation"
[     8.074] 	compiled for 1.21.1.13, module version = 1.0.0
[     8.074] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.075] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     8.075] (==) NVIDIA(0): RGB weight 888
[     8.075] (==) NVIDIA(0): Default visual is TrueColor
[     8.075] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.075] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     8.075] (**) NVIDIA(0): Option "Stereo" "0"
[     8.075] (**) NVIDIA(0): Option "SLI" "Off"
[     8.075] (**) NVIDIA(0): Option "MultiGPU" "Off"
[     8.075] (**) NVIDIA(0): Option "BaseMosaic" "off"
[     8.075] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     8.075] (**) NVIDIA(0): Stereo disabled by request
[     8.075] (**) NVIDIA(0): NVIDIA SLI disabled.
[     8.075] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[     8.075] (**) NVIDIA(0): Option "MetaModes" "DP-2: 1920x1080_144 +0+0 {AllowGSYNC=Off}"
[     8.075] (**) NVIDIA(1): Option "MetaModes" "DP-0: 1920x1080_144 +0+0 {AllowGSYNC=Off}"
[     8.075] (**) NVIDIA(0): Enabling 2D acceleration
[     8.075] (II) Loading sub module "glxserver_nvidia"
[     8.075] (II) LoadModule: "glxserver_nvidia"
[     8.075] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     8.109] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     8.109] 	compiled for 1.6.99.901, module version = 1.0.0
[     8.109] 	Module class: X.Org Server Extension
[     8.109] (II) NVIDIA GLX Module  550.90.07  Fri May 31 09:34:56 UTC 2024
[     8.109] (II) NVIDIA: The X server supports PRIME Render Offload.
[     8.110] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     8.110] (--) NVIDIA(0):     DFP-0
[     8.110] (--) NVIDIA(0):     DFP-1
[     8.110] (--) NVIDIA(0):     DFP-2
[     8.110] (--) NVIDIA(0):     DFP-3
[     8.110] (--) NVIDIA(0):     DFP-4 (boot)
[     8.110] (--) NVIDIA(0):     DFP-5
[     8.110] (--) NVIDIA(0):     DFP-6
[     8.110] (--) NVIDIA(0):     DFP-7
[     8.110] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1060 6GB (GP106-A) at PCI:1:0:0
[     8.110] (II) NVIDIA(0):     (GPU-0)
[     8.110] (--) NVIDIA(0): Memory: 6291456 kBytes
[     8.110] (--) NVIDIA(0): VideoBIOS: 86.06.68.00.62
[     8.110] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     8.110] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     8.110] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     8.110] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     8.111] (--) NVIDIA(GPU-0):
[     8.111] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     8.111] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     8.111] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     8.111] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     8.111] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[     8.111] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[     8.111] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     8.111] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     8.111] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     8.111] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[     8.111] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[     8.111] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[     8.116] (--) NVIDIA(GPU-0): DFP-5: disconnected
[     8.116] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[     8.116] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[     8.116] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     8.116] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[     8.116] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[     8.116] (--) NVIDIA(GPU-0): DFP-7: disconnected
[     8.116] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[     8.116] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[     8.118] (II) NVIDIA(0): Validated MetaModes:
[     8.118] (II) NVIDIA(0):     "DP-2:1920x1080_144+0+0{AllowGSYNC=Off}"
[     8.118] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[     8.121] (--) NVIDIA(0): DPI set to (77, 76); computed from "UseEdidDpi" X config
[     8.121] (--) NVIDIA(0):     option
[     8.121] (**) NVIDIA(1): Depth 24, (--) framebuffer bpp 32
[     8.121] (==) NVIDIA(1): RGB weight 888
[     8.121] (==) NVIDIA(1): Default visual is TrueColor
[     8.121] (==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
[     8.121] (**) NVIDIA(1): Option "Stereo" "0"
[     8.121] (**) NVIDIA(1): Option "SLI" "Off"
[     8.121] (**) NVIDIA(1): Option "MultiGPU" "Off"
[     8.121] (**) NVIDIA(1): Option "BaseMosaic" "off"
[     8.121] (**) NVIDIA(1): Option "AllowEmptyInitialConfiguration"
[     8.121] (**) NVIDIA(1): Stereo disabled by request
[     8.121] (**) NVIDIA(1): NVIDIA SLI disabled.
[     8.121] (**) NVIDIA(1): NVIDIA Multi-GPU disabled.
[     8.121] (II) NVIDIA: The X server supports PRIME Render Offload.
[     8.121] (II) NVIDIA(1): NVIDIA GPU NVIDIA GeForce GTX 1060 6GB (GP106-A) at PCI:1:0:0
[     8.121] (II) NVIDIA(1):     (GPU-0)
[     8.121] (--) NVIDIA(1): Memory: 6291456 kBytes
[     8.121] (--) NVIDIA(1): VideoBIOS: 86.06.68.00.62
[     8.121] (II) NVIDIA(1): Detected PCI Express Link width: 16X
[     8.121] (WW) NVIDIA(1): No valid modes for "DP-0:1920x1080_144+0+0{AllowGSYNC=Off}";
[     8.121] (WW) NVIDIA(1):     removing.
[     8.121] (WW) NVIDIA(1): Unable to validate any modes; falling back to the default mode
[     8.121] (WW) NVIDIA(1):     "nvidia-auto-select".
[     8.121] (--) NVIDIA(1): No enabled display devices found; starting anyway because
[     8.121] (--) NVIDIA(1):     AllowEmptyInitialConfiguration is enabled
[     8.121] (II) NVIDIA(1): Validated MetaModes:
[     8.121] (II) NVIDIA(1):     "NULL"
[     8.121] (II) NVIDIA(1): Virtual screen size determined to be 640 x 480
[     8.121] (WW) NVIDIA(1): Unable to get display device for DPI computation.
[     8.121] (==) NVIDIA(1): DPI set to (75, 75); computed from built-in default
[     8.122] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[     8.122] (II) NVIDIA:     access.
[     8.123] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     8.123] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     8.123] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     8.123] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     8.123] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     8.123] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     8.123] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     8.123] (II) NVIDIA(0):     Config Options in the README.
[     8.131] (II) NVIDIA(0): Setting mode "DP-2:1920x1080_144+0+0{AllowGSYNC=Off}"
[     8.218] (==) NVIDIA(0): Disabling shared memory pixmaps
[     8.218] (==) NVIDIA(0): Backing store enabled
[     8.218] (==) NVIDIA(0): Silken mouse enabled
[     8.218] (**) NVIDIA(0): DPMS enabled
[     8.218] (II) Loading sub module "dri2"
[     8.218] (II) LoadModule: "dri2"
[     8.218] (II) Module "dri2" already built-in
[     8.218] (II) NVIDIA(0): [DRI2] Setup complete
[     8.218] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     8.219] (II) NVIDIA(1): ACPI: failed to connect to the ACPI event daemon; the daemon
[     8.219] (II) NVIDIA(1):     may not be running or the "AcpidSocketPath" X
[     8.219] (II) NVIDIA(1):     configuration option may not be set correctly.  When the
[     8.219] (II) NVIDIA(1):     ACPI event daemon is available, the NVIDIA X driver will
[     8.219] (II) NVIDIA(1):     try to use it to receive ACPI event notifications.  For
[     8.219] (II) NVIDIA(1):     details, please see the "ConnectToAcpid" and
[     8.219] (II) NVIDIA(1):     "AcpidSocketPath" X configuration options in Appendix B: X
[     8.219] (II) NVIDIA(1):     Config Options in the README.
[     8.228] (II) NVIDIA(1): Setting mode "NULL"
[     8.237] (==) NVIDIA(1): Disabling shared memory pixmaps
[     8.237] (==) NVIDIA(1): Backing store enabled
[     8.237] (==) NVIDIA(1): Silken mouse enabled
[     8.237] (**) NVIDIA(1): DPMS enabled
[     8.237] (II) Loading sub module "dri2"
[     8.237] (II) LoadModule: "dri2"
[     8.237] (II) Module "dri2" already built-in
[     8.237] (II) NVIDIA(1): [DRI2] Setup complete
[     8.237] (II) NVIDIA(1): [DRI2]   VDPAU driver: nvidia
[     8.237] (II) Initializing extension Generic Event Extension
[     8.237] (II) Initializing extension SHAPE
[     8.237] (II) Initializing extension MIT-SHM
[     8.237] (II) Initializing extension XInputExtension
[     8.237] (II) Initializing extension XTEST
[     8.237] (II) Initializing extension BIG-REQUESTS
[     8.237] (II) Initializing extension SYNC
[     8.237] (II) Initializing extension XKEYBOARD
[     8.237] (II) Initializing extension XC-MISC
[     8.237] (II) Initializing extension SECURITY
[     8.237] (II) Initializing extension XFIXES
[     8.237] (II) Initializing extension RENDER
[     8.237] (II) Initializing extension RANDR
[     8.237] (II) Initializing extension COMPOSITE
[     8.237] (II) Initializing extension DAMAGE
[     8.237] (II) Initializing extension MIT-SCREEN-SAVER
[     8.237] (II) Initializing extension DOUBLE-BUFFER
[     8.237] (II) Initializing extension RECORD
[     8.237] (II) Initializing extension DPMS
[     8.237] (II) Initializing extension Present
[     8.238] (II) Initializing extension DRI3
[     8.238] (II) Initializing extension X-Resource
[     8.238] (II) Initializing extension XVideo
[     8.238] (II) Initializing extension XVideo-MotionCompensation
[     8.238] (II) Initializing extension GLX
[     8.238] (II) Indirect GLX disabled.
[     8.238] (II) GLX: Another vendor is already registered for screen 0
[     8.238] (II) GLX: Another vendor is already registered for screen 1
[     8.238] (II) Initializing extension XFree86-VidModeExtension
[     8.238] (II) Initializing extension XFree86-DGA
[     8.238] (II) Initializing extension XFree86-DRI
[     8.238] (II) Initializing extension DRI2
[     8.238] (II) Initializing extension NV-GLX
[     8.238] (II) Initializing extension NV-CONTROL
[     8.286] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.286] (**) Power Button: Applying InputClass "devname"
[     8.286] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.286] (**) Power Button: Applying InputClass "system-keyboard"
[     8.286] (II) LoadModule: "libinput"
[     8.286] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.288] (II) Module libinput: vendor="X.Org Foundation"
[     8.288] 	compiled for 1.21.1.8, module version = 1.4.0
[     8.288] 	Module class: X.Org XInput Driver
[     8.288] 	ABI class: X.Org XInput driver, version 24.4
[     8.288] (II) Using input driver 'libinput' for 'Power Button'
[     8.288] (**) Power Button: always reports core events
[     8.288] (**) Option "Device" "/dev/input/event1"
[     8.294] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.294] (II) event1  - Power Button: device is a keyboard
[     8.294] (II) event1  - Power Button: device removed
[     8.340] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     8.340] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.340] (**) Option "xkb_layout" "us"
[     8.340] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.340] (II) event1  - Power Button: device is a keyboard
[     8.341] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[     8.341] (**) Video Bus: Applying InputClass "devname"
[     8.341] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.341] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.341] (II) Using input driver 'libinput' for 'Video Bus'
[     8.341] (**) Video Bus: always reports core events
[     8.341] (**) Option "Device" "/dev/input/event2"
[     8.341] (II) event2  - Video Bus: is tagged by udev as: Keyboard
[     8.341] (II) event2  - Video Bus: device is a keyboard
[     8.341] (II) event2  - Video Bus: device removed
[     8.403] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:73/LNXVIDEO:00/input/input2/event2"
[     8.403] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     8.403] (**) Option "xkb_layout" "us"
[     8.404] (II) event2  - Video Bus: is tagged by udev as: Keyboard
[     8.404] (II) event2  - Video Bus: device is a keyboard
[     8.404] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     8.404] (**) Power Button: Applying InputClass "devname"
[     8.404] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.404] (**) Power Button: Applying InputClass "system-keyboard"
[     8.404] (II) Using input driver 'libinput' for 'Power Button'
[     8.404] (**) Power Button: always reports core events
[     8.404] (**) Option "Device" "/dev/input/event0"
[     8.405] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.405] (II) event0  - Power Button: device is a keyboard
[     8.405] (II) event0  - Power Button: device removed
[     8.423] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     8.423] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     8.423] (**) Option "xkb_layout" "us"
[     8.424] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.424] (II) event0  - Power Button: device is a keyboard
[     8.424] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event6)
[     8.424] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[     8.424] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[     8.424] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[     8.424] (**) Option "Device" "/dev/input/event6"
[     8.425] (II) event6  - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[     8.476] (II) event6  - not using input device '/dev/input/event6'.
[     8.476] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event6
[     8.476] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[     8.476] (II) UnloadModule: "libinput"
[     8.477] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[     8.477] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[     8.477] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[     8.477] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[     8.477] (**) Option "Device" "/dev/input/event9"
[     8.477] (II) event9  - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[     8.533] (II) event9  - not using input device '/dev/input/event9'.
[     8.533] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event9
[     8.533] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[     8.533] (II) UnloadModule: "libinput"
[     8.533] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[     8.533] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[     8.533] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[     8.533] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[     8.533] (**) Option "Device" "/dev/input/event10"
[     8.534] (II) event10 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[     8.610] (II) event10 - not using input device '/dev/input/event10'.
[     8.610] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event10
[     8.610] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[     8.610] (II) UnloadModule: "libinput"
[     8.610] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event5)
[     8.610] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[     8.610] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[     8.610] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[     8.610] (**) Option "Device" "/dev/input/event5"
[     8.611] (II) event5  - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[     8.693] (II) event5  - not using input device '/dev/input/event5'.
[     8.693] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event5
[     8.693] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[     8.693] (II) UnloadModule: "libinput"
[     8.694] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event7)
[     8.694] (**) HD-Audio Generic HDMI/DP,pcm=3: Applying InputClass "devname"
[     8.694] (II) Using input driver 'libinput' for 'HD-Audio Generic HDMI/DP,pcm=3'
[     8.694] (**) HD-Audio Generic HDMI/DP,pcm=3: always reports core events
[     8.694] (**) Option "Device" "/dev/input/event7"
[     8.694] (II) event7  - HD-Audio Generic HDMI/DP,pcm=3: is tagged by udev as: Switch
[     8.790] (II) event7  - not using input device '/dev/input/event7'.
[     8.790] (EE) libinput: HD-Audio Generic HDMI/DP,pcm=3: Failed to create a device for /dev/input/event7
[     8.790] (EE) PreInit returned 2 for "HD-Audio Generic HDMI/DP,pcm=3"
[     8.790] (II) UnloadModule: "libinput"
[     8.790] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event11)
[     8.790] (**) HD-Audio Generic HDMI/DP,pcm=7: Applying InputClass "devname"
[     8.790] (II) Using input driver 'libinput' for 'HD-Audio Generic HDMI/DP,pcm=7'
[     8.790] (**) HD-Audio Generic HDMI/DP,pcm=7: always reports core events
[     8.790] (**) Option "Device" "/dev/input/event11"
[     8.791] (II) event11 - HD-Audio Generic HDMI/DP,pcm=7: is tagged by udev as: Switch
[     8.843] (II) event11 - not using input device '/dev/input/event11'.
[     8.843] (EE) libinput: HD-Audio Generic HDMI/DP,pcm=7: Failed to create a device for /dev/input/event11
[     8.843] (EE) PreInit returned 2 for "HD-Audio Generic HDMI/DP,pcm=7"
[     8.843] (II) UnloadModule: "libinput"
[     8.844] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event12)
[     8.844] (**) HD-Audio Generic HDMI/DP,pcm=8: Applying InputClass "devname"
[     8.844] (II) Using input driver 'libinput' for 'HD-Audio Generic HDMI/DP,pcm=8'
[     8.844] (**) HD-Audio Generic HDMI/DP,pcm=8: always reports core events
[     8.844] (**) Option "Device" "/dev/input/event12"
[     8.844] (II) event12 - HD-Audio Generic HDMI/DP,pcm=8: is tagged by udev as: Switch
[     8.896] (II) event12 - not using input device '/dev/input/event12'.
[     8.896] (EE) libinput: HD-Audio Generic HDMI/DP,pcm=8: Failed to create a device for /dev/input/event12
[     8.897] (EE) PreInit returned 2 for "HD-Audio Generic HDMI/DP,pcm=8"
[     8.897] (II) UnloadModule: "libinput"
[     8.897] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=9 (/dev/input/event14)
[     8.897] (**) HD-Audio Generic HDMI/DP,pcm=9: Applying InputClass "devname"
[     8.897] (II) Using input driver 'libinput' for 'HD-Audio Generic HDMI/DP,pcm=9'
[     8.897] (**) HD-Audio Generic HDMI/DP,pcm=9: always reports core events
[     8.897] (**) Option "Device" "/dev/input/event14"
[     8.897] (II) event14 - HD-Audio Generic HDMI/DP,pcm=9: is tagged by udev as: Switch
[     8.963] (II) event14 - not using input device '/dev/input/event14'.
[     8.963] (EE) libinput: HD-Audio Generic HDMI/DP,pcm=9: Failed to create a device for /dev/input/event14
[     8.963] (EE) PreInit returned 2 for "HD-Audio Generic HDMI/DP,pcm=9"
[     8.963] (II) UnloadModule: "libinput"
[     8.964] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event19)
[     8.964] (**) HD-Audio Generic Front Mic: Applying InputClass "devname"
[     8.964] (II) Using input driver 'libinput' for 'HD-Audio Generic Front Mic'
[     8.964] (**) HD-Audio Generic Front Mic: always reports core events
[     8.964] (**) Option "Device" "/dev/input/event19"
[     8.964] (II) event19 - HD-Audio Generic Front Mic: is tagged by udev as: Switch
[     9.016] (II) event19 - not using input device '/dev/input/event19'.
[     9.016] (EE) libinput: HD-Audio Generic Front Mic: Failed to create a device for /dev/input/event19
[     9.017] (EE) PreInit returned 2 for "HD-Audio Generic Front Mic"
[     9.017] (II) UnloadModule: "libinput"
[     9.017] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event20)
[     9.017] (**) HD-Audio Generic Rear Mic: Applying InputClass "devname"
[     9.017] (II) Using input driver 'libinput' for 'HD-Audio Generic Rear Mic'
[     9.017] (**) HD-Audio Generic Rear Mic: always reports core events
[     9.017] (**) Option "Device" "/dev/input/event20"
[     9.017] (II) event20 - HD-Audio Generic Rear Mic: is tagged by udev as: Switch
[     9.070] (II) event20 - not using input device '/dev/input/event20'.
[     9.070] (EE) libinput: HD-Audio Generic Rear Mic: Failed to create a device for /dev/input/event20
[     9.070] (EE) PreInit returned 2 for "HD-Audio Generic Rear Mic"
[     9.070] (II) UnloadModule: "libinput"
[     9.070] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event21)
[     9.070] (**) HD-Audio Generic Line Out: Applying InputClass "devname"
[     9.070] (II) Using input driver 'libinput' for 'HD-Audio Generic Line Out'
[     9.070] (**) HD-Audio Generic Line Out: always reports core events
[     9.070] (**) Option "Device" "/dev/input/event21"
[     9.071] (II) event21 - HD-Audio Generic Line Out: is tagged by udev as: Switch
[     9.136] (II) event21 - not using input device '/dev/input/event21'.
[     9.136] (EE) libinput: HD-Audio Generic Line Out: Failed to create a device for /dev/input/event21
[     9.137] (EE) PreInit returned 2 for "HD-Audio Generic Line Out"
[     9.137] (II) UnloadModule: "libinput"
[     9.137] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event22)
[     9.137] (**) HD-Audio Generic Front Headphone: Applying InputClass "devname"
[     9.137] (II) Using input driver 'libinput' for 'HD-Audio Generic Front Headphone'
[     9.137] (**) HD-Audio Generic Front Headphone: always reports core events
[     9.137] (**) Option "Device" "/dev/input/event22"
[     9.137] (II) event22 - HD-Audio Generic Front Headphone: is tagged by udev as: Switch
[     9.187] (II) event22 - not using input device '/dev/input/event22'.
[     9.187] (EE) libinput: HD-Audio Generic Front Headphone: Failed to create a device for /dev/input/event22
[     9.187] (EE) PreInit returned 2 for "HD-Audio Generic Front Headphone"
[     9.187] (II) UnloadModule: "libinput"
[     9.187] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/event4)
[     9.187] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.187] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "libinput keyboard catchall"
[     9.187] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "system-keyboard"
[     9.187] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.187] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.187] (**) Option "Device" "/dev/input/event4"
[     9.188] (II) event4  - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard Joystick
[     9.188] (II) event4  - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.188] (II) event4  - Ducky Ducky One 3 TKL RGB: device removed
[     9.213] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2:1.0/0003:3233:8311.0001/input/input4/event4"
[     9.213] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 TKL RGB" (type: KEYBOARD, id 9)
[     9.213] (**) Option "xkb_layout" "us"
[     9.214] (II) event4  - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard Joystick
[     9.214] (II) event4  - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.215] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/js0)
[     9.215] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.215] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "system-keyboard"
[     9.215] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.215] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.215] (**) Option "Device" "/dev/input/js0"
[     9.280] (II) js0     - not using input device '/dev/input/js0'.
[     9.280] (EE) libinput: Ducky Ducky One 3 TKL RGB: Failed to create a device for /dev/input/js0
[     9.280] (EE) PreInit returned 2 for "Ducky Ducky One 3 TKL RGB"
[     9.280] (II) UnloadModule: "libinput"
[     9.280] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/event8)
[     9.280] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.280] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "libinput keyboard catchall"
[     9.280] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "system-keyboard"
[     9.280] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.280] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.280] (**) Option "Device" "/dev/input/event8"
[     9.281] (II) event8  - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.281] (II) event8  - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.281] (II) event8  - Ducky Ducky One 3 TKL RGB: device removed
[     9.306] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2:1.1/0003:3233:8311.0002/input/input13/event8"
[     9.307] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 TKL RGB" (type: KEYBOARD, id 10)
[     9.307] (**) Option "xkb_layout" "us"
[     9.308] (II) event8  - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.308] (II) event8  - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.308] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/event13)
[     9.308] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.308] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "libinput pointer catchall"
[     9.308] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "My Mouse"
[     9.308] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.308] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.308] (**) Option "Device" "/dev/input/event13"
[     9.364] (II) event13 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Mouse
[     9.364] (II) event13 - Ducky Ducky One 3 TKL RGB: device is a pointer
[     9.364] (II) event13 - Ducky Ducky One 3 TKL RGB: device removed
[     9.420] (**) Option "AccelSpeed" "-0.8"
[     9.420] (II) libinput: Ducky Ducky One 3 TKL RGB: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.420] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2:1.2/0003:3233:8311.0003/input/input14/event13"
[     9.420] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 TKL RGB" (type: MOUSE, id 11)
[     9.420] (**) Option "AccelerationScheme" "none"
[     9.420] (**) Ducky Ducky One 3 TKL RGB: (accel) selected scheme none/0
[     9.420] (**) Ducky Ducky One 3 TKL RGB: (accel) acceleration factor: 2.000
[     9.420] (**) Ducky Ducky One 3 TKL RGB: (accel) acceleration threshold: 4
[     9.477] (II) event13 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Mouse
[     9.477] (II) event13 - Ducky Ducky One 3 TKL RGB: device is a pointer
[     9.478] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/mouse0)
[     9.478] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.478] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "My Mouse"
[     9.478] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.478] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.478] (**) Option "Device" "/dev/input/mouse0"
[     9.530] (II) mouse0  - not using input device '/dev/input/mouse0'.
[     9.530] (EE) libinput: Ducky Ducky One 3 TKL RGB: Failed to create a device for /dev/input/mouse0
[     9.530] (EE) PreInit returned 2 for "Ducky Ducky One 3 TKL RGB"
[     9.530] (II) UnloadModule: "libinput"
[     9.530] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/event15)
[     9.530] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.530] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "libinput keyboard catchall"
[     9.530] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "system-keyboard"
[     9.530] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.530] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.530] (**) Option "Device" "/dev/input/event15"
[     9.531] (II) event15 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.531] (II) event15 - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.531] (II) event15 - Ducky Ducky One 3 TKL RGB: device removed
[     9.583] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2:1.3/0003:3233:8311.0004/input/input15/event15"
[     9.583] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 TKL RGB" (type: KEYBOARD, id 12)
[     9.583] (**) Option "xkb_layout" "us"
[     9.584] (II) event15 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.584] (II) event15 - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.585] (II) config/udev: Adding input device Ducky Ducky One 3 TKL RGB (/dev/input/event16)
[     9.585] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "devname"
[     9.585] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "libinput keyboard catchall"
[     9.585] (**) Ducky Ducky One 3 TKL RGB: Applying InputClass "system-keyboard"
[     9.585] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 TKL RGB'
[     9.585] (**) Ducky Ducky One 3 TKL RGB: always reports core events
[     9.585] (**) Option "Device" "/dev/input/event16"
[     9.586] (II) event16 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.586] (II) event16 - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.586] (II) event16 - Ducky Ducky One 3 TKL RGB: device removed
[     9.636] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.2/9-1.2:1.4/0003:3233:8311.0005/input/input16/event16"
[     9.637] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 TKL RGB" (type: KEYBOARD, id 13)
[     9.637] (**) Option "xkb_layout" "us"
[     9.638] (II) event16 - Ducky Ducky One 3 TKL RGB: is tagged by udev as: Keyboard
[     9.638] (II) event16 - Ducky Ducky One 3 TKL RGB: device is a keyboard
[     9.638] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/event17)
[     9.638] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "devname"
[     9.638] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     9.638] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "My Mouse"
[     9.638] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse'
[     9.638] (**) Logitech G502 HERO Gaming Mouse: always reports core events
[     9.638] (**) Option "Device" "/dev/input/event17"
[     9.694] (II) event17 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[     9.694] (II) event17 - Logitech G502 HERO Gaming Mouse: device set to 2400 DPI
[     9.694] (II) event17 - Logitech G502 HERO Gaming Mouse: device is a pointer
[     9.694] (II) event17 - Logitech G502 HERO Gaming Mouse: device removed
[     9.746] (**) Option "AccelSpeed" "-0.8"
[     9.746] (II) libinput: Logitech G502 HERO Gaming Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.747] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.4/9-1.4:1.0/0003:046D:C08B.0007/input/input17/event17"
[     9.747] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse" (type: MOUSE, id 14)
[     9.747] (**) Option "AccelerationScheme" "none"
[     9.747] (**) Logitech G502 HERO Gaming Mouse: (accel) selected scheme none/0
[     9.747] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration factor: 2.000
[     9.747] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration threshold: 4
[     9.804] (II) event17 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[     9.804] (II) event17 - Logitech G502 HERO Gaming Mouse: device set to 2400 DPI
[     9.804] (II) event17 - Logitech G502 HERO Gaming Mouse: device is a pointer
[     9.805] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/mouse1)
[     9.805] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "devname"
[     9.805] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "My Mouse"
[     9.805] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse'
[     9.805] (**) Logitech G502 HERO Gaming Mouse: always reports core events
[     9.805] (**) Option "Device" "/dev/input/mouse1"
[     9.856] (II) mouse1  - not using input device '/dev/input/mouse1'.
[     9.856] (EE) libinput: Logitech G502 HERO Gaming Mouse: Failed to create a device for /dev/input/mouse1
[     9.856] (EE) PreInit returned 2 for "Logitech G502 HERO Gaming Mouse"
[     9.856] (II) UnloadModule: "libinput"
[     9.857] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Keyboard (/dev/input/event18)
[     9.857] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "devname"
[     9.857] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.857] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     9.857] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Keyboard'
[     9.857] (**) Logitech G502 HERO Gaming Mouse Keyboard: always reports core events
[     9.857] (**) Option "Device" "/dev/input/event18"
[     9.858] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     9.858] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[     9.858] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device removed
[     9.883] (II) libinput: Logitech G502 HERO Gaming Mouse Keyboard: needs a virtual subdevice
[     9.883] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.4/9-1.4:1.1/0003:046D:C08B.0008/input/input18/event18"
[     9.883] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Keyboard" (type: MOUSE, id 15)
[     9.883] (**) Option "AccelerationScheme" "none"
[     9.883] (**) Logitech G502 HERO Gaming Mouse Keyboard: (accel) selected scheme none/0
[     9.883] (**) Logitech G502 HERO Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[     9.883] (**) Logitech G502 HERO Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[     9.884] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     9.884] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[     9.884] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[     9.884] (**) PC Speaker: Applying InputClass "devname"
[     9.884] (II) Using input driver 'libinput' for 'PC Speaker'
[     9.884] (**) PC Speaker: always reports core events
[     9.884] (**) Option "Device" "/dev/input/event3"
[     9.885] (II) event3  - PC Speaker: not tagged as supported input device
[     9.966] (II) event3  - not using input device '/dev/input/event3'.
[     9.966] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event3
[     9.966] (EE) PreInit returned 2 for "PC Speaker"
[     9.967] (II) UnloadModule: "libinput"
[     9.970] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "devname"
[     9.970] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.970] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     9.970] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Keyboard'
[     9.970] (**) Logitech G502 HERO Gaming Mouse Keyboard: always reports core events
[     9.970] (**) Option "Device" "/dev/input/event18"
[     9.970] (II) libinput: Logitech G502 HERO Gaming Mouse Keyboard: is a virtual subdevice
[     9.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.3/0000:16:00.0/usb9/9-1/9-1.4/9-1.4:1.1/0003:046D:C08B.0008/input/input18/event18"
[     9.970] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Keyboard" (type: KEYBOARD, id 16)
[     9.970] (**) Option "xkb_layout" "us"
[    16.694] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    16.694] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    16.694] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    16.694] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    16.694] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    16.694] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    16.694] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    16.694] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    16.694] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    16.694] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    16.694] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    16.694] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    16.694] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    16.694] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    16.694] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    16.699] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    16.699] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    16.699] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    16.699] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    16.699] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    16.699] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    16.699] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    16.699] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    16.699] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    25.010] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    25.010] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    25.010] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    25.010] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    25.010] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    25.010] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    25.010] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    25.010] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    25.010] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    25.011] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    25.011] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    25.011] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    25.011] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    25.011] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    25.011] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    25.015] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    25.015] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    25.015] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    25.015] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    25.015] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    25.015] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    25.016] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    25.016] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    25.016] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    26.543] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    26.543] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    26.543] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    26.543] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    26.543] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    26.543] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    26.543] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    26.543] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    26.543] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    26.543] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    26.543] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    26.543] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    26.543] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    26.543] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    26.543] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    26.548] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    26.548] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    26.548] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    26.548] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    26.548] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    26.548] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    26.548] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    26.548] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    26.548] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    27.146] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    27.146] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    27.146] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    27.146] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    27.146] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    27.146] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    27.146] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    27.146] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    27.146] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    27.146] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    27.146] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    27.146] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    27.146] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    27.146] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    27.146] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    27.151] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    27.151] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    27.151] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    27.151] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    27.151] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    27.151] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    27.151] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    27.151] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    27.151] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    27.778] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    27.778] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    27.778] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    27.778] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    27.778] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    27.778] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    27.778] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    27.778] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    27.778] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    27.778] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    27.778] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    27.778] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    27.778] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    27.778] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    27.778] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    27.783] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    27.783] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    27.783] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    27.783] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    27.783] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    27.783] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    27.783] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    27.783] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    27.783] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    28.380] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    28.380] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    28.380] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    28.380] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    28.380] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    28.380] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    28.380] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    28.380] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    28.380] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    28.380] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    28.380] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    28.380] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    28.380] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    28.380] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    28.380] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    28.385] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    28.385] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    28.385] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    28.385] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    28.385] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    28.385] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    28.385] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    28.385] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    28.385] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    28.998] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    28.998] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    28.998] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    28.998] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    28.998] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    28.998] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    28.998] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    28.998] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    28.998] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    28.998] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    28.998] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    28.998] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    28.998] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    28.998] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    28.998] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    29.003] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    29.003] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    29.003] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    29.003] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    29.003] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    29.003] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    29.003] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    29.003] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    29.003] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    30.076] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    30.076] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    30.076] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    30.076] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    30.076] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    30.076] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    30.076] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    30.076] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    30.076] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    30.076] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    30.076] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    30.076] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    30.076] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    30.076] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    30.076] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    30.081] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    30.081] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    30.081] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    30.081] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    30.081] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    30.081] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    30.081] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    30.081] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    30.081] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    31.263] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    31.263] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    31.263] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    31.263] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    31.263] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    31.263] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    31.263] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    31.263] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    31.263] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    31.263] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    31.263] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    31.263] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    31.263] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    31.263] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    31.263] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    31.268] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    31.268] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    31.268] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    31.268] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    31.268] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    31.268] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    31.269] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    31.269] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    31.269] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    32.524] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    32.524] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    32.524] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    32.524] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    32.524] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    32.524] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    32.524] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    32.524] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    32.524] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    32.524] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    32.524] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    32.524] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    32.524] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    32.524] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    32.524] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    32.529] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    32.529] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    32.529] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    32.529] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    32.529] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    32.529] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    32.529] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    32.529] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    32.529] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    33.119] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    33.119] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    33.119] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    33.119] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    33.119] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    33.119] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    33.119] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    33.119] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    33.119] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    33.119] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    33.119] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    33.119] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    33.119] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    33.119] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    33.119] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    33.124] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    33.124] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    33.124] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    33.124] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    33.124] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    33.124] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    33.124] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    33.124] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    33.124] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    63.972] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    63.972] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    63.972] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    63.972] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    63.972] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    63.972] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    63.972] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    63.972] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    63.972] (--) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
[    63.972] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    63.972] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    63.972] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    63.972] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    63.972] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    63.972] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    63.977] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    63.977] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    63.977] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    63.977] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    63.977] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    63.977] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    63.977] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    63.977] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    63.977] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    71.527] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    71.527] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[    71.527] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[    72.334] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    72.334] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    72.334] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    75.976] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[    75.976] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[    75.976] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[    79.286] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    79.286] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    79.286] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    79.286] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    79.286] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    79.286] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    79.286] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[    79.286] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[    79.286] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[    79.291] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    79.291] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    79.291] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    79.291] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    79.291] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    79.291] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    79.296] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    79.296] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    79.296] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    79.296] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    79.296] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    79.296] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    79.296] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    79.296] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    79.296] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    81.547] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    81.547] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    81.547] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    81.547] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    81.547] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    81.547] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    81.547] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[    81.547] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[    81.547] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[    81.552] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    81.552] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    81.552] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    81.552] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    81.552] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    81.552] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    81.557] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    81.557] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    81.557] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    81.557] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    81.557] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    81.557] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    81.557] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    81.557] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    81.557] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    96.995] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    96.995] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    96.995] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    96.996] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    96.996] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    96.996] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    96.996] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[    96.996] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[    96.996] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[    97.000] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    97.000] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    97.000] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    97.001] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[    97.001] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[    97.001] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[    97.006] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    97.006] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    97.006] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    97.006] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    97.006] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    97.006] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    97.006] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    97.006] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    97.006] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[  7135.041] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7135.041] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7135.041] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7135.041] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7135.041] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7135.041] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7135.041] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[  7135.041] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[  7135.041] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[  7135.045] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7135.045] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7135.045] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7135.046] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[  7135.046] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[  7135.046] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[  7135.050] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  7135.050] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[  7135.050] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[  7135.050] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  7135.050] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[  7135.050] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[  7135.050] (--) NVIDIA(GPU-0): DFP-7: disconnected
[  7135.050] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[  7135.050] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[  7236.001] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7236.001] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7236.001] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7236.001] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7236.001] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7236.001] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7236.002] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[  7236.002] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[  7236.002] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[  7236.006] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7236.006] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7236.006] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7236.006] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[  7236.006] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[  7236.006] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[  7236.011] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  7236.011] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[  7236.011] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[  7236.011] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  7236.011] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[  7236.011] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[  7236.011] (--) NVIDIA(GPU-0): DFP-7: disconnected
[  7236.011] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[  7236.011] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[  7369.938] (--) NVIDIA(GPU-0): DFP-0: disconnected
[  7369.938] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[  7369.938] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[  7369.938] (--) NVIDIA(GPU-0): DFP-1: disconnected
[  7369.938] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[  7369.938] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[  7369.938] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): connected
[  7369.938] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): Internal DisplayPort
[  7369.938] (--) NVIDIA(GPU-0): GBT M28U (DFP-2): 1440.0 MHz maximum pixel clock
[  7369.942] (--) NVIDIA(GPU-0): DFP-3: disconnected
[  7369.942] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[  7369.942] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[  7369.943] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): connected
[  7369.943] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): Internal DisplayPort
[  7369.943] (--) NVIDIA(GPU-0): GBT M28U (DFP-4): 1440.0 MHz maximum pixel clock
[  7369.947] (--) NVIDIA(GPU-0): DFP-5: disconnected
[  7369.947] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[  7369.947] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[  7369.947] (--) NVIDIA(GPU-0): DFP-6: disconnected
[  7369.947] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[  7369.947] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[  7369.947] (--) NVIDIA(GPU-0): DFP-7: disconnected
[  7369.947] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[  7369.947] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[  7413.394] (II) event17 - Logitech G502 HERO Gaming Mouse: Enabling spurious button debouncing, see https://wayland.freedesktop.org/libinput/doc/1.26.0/button-debouncing.html for details
And my X11 config
xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 550.78
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    Screen      1  "Screen1" 1920 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "GBT M28U"
    HorizSync       246.0 - 246.0
    VertRefresh     48.0 - 144.0
    Option         "DPMS"
EndSection
Section "Monitor"
    Identifier     "Monitor1"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "NVIDIA GeForce GTX 1060 6GB"
    BusID          "PCI:1:0:0"
    Screen          0
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "nvidia"
    BusID          "PCI:1:0:0"
    Screen          1
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DP-2"
    Option         "metamodes" "DP-2: 1920x1080_144 +0+0 {AllowGSYNC=Off}"
    Option         "SLI" "Off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Screen"
    Identifier     "Screen1"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "DP-0: 1920x1080_144 +0+0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Any pointers would be greatly appreciated!
(DP-0 is secondary monitor)
Before X11 config
xrandr -q
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
DP-0 connected (normal left inverted right x axis y axis)
   3840x2160     60.00 + 144.00   120.00   119.88    59.94    23.98
   2560x1440    143.86   119.88    59.94
   1920x1080    143.85   119.88    60.00    59.94    23.98
   1680x1050     59.95
   1440x900      59.89
   1280x1024     60.02
   1280x720     119.88    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x480       59.94
   640x480       75.00    59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
   1920x1080    143.85*  119.88    60.00    59.94    23.98
   1680x1050     59.95
   1440x900      59.89
   1280x1024     60.02
   800x600       75.00    60.32
   720x480       59.94
   640x480       75.00    59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
After X11 config
xrandr -q
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
   1680x1050     59.95
   1440x900      59.89
   1280x1024     60.02
   800x600       75.00    60.32
   720x480       59.94
   640x480       75.00    59.94
Alright, I tried re-making about a dozen configuration files, but none of them seem to have fixed it.
I decided to just re-install EOS, and it works now. Oh well.
Should I mark this as solved? Reinstalling isn’t really a great solution.
Should we find PEBCAC so it is not repeated later? :smile:
Machines and code always behave the same. The alteration factor is PEBCAC.
This filepath should not be used, unless you are advised so for some special case. The proper path, if needed (usually there is no need for an xorg file) is in folder
/etc/X11/xorg.conf.d/somename.conf
If you had provided your system data (inxi -Faz, or inxi -SMIGaz output) we would have a better idea.
I agree. From xorg log, it seems you have two (2) graphic cards, with separate PCI IDs, both set to the same PCI address (disaster :face_with_head_bandage: ) and MultiGPU disabled.
It looks weird.
The more weird thing is that nvidia-settings has created this conf file.
I guess they (nvidia utilities) shouldn’t mess with xorg configuration.
The good news is that yopur system is working fine!
:tada:
Yeah I’m not sure what happened, it just seems like plugging in that other HDMI monitor made nvidia-settings break my config somewhere, but it should only be messing with that one xorg config file, that is all I ever prompts me to do. I’m surprised deleting the config file didn’t fix it.
What do you suggest I do instead of nvidia-settings?
I need to do the following:
Set the resolution of my monitors, enable force full composition pipeline (fix screen tearing), and enable G-Sync on the displays.
Humans.
Ask the System Administrator (usually the user with RTFM responsibilities) :rofl: .
I decided to try to replicate the issue, and I managed to do it once, and even found a solution!
In very rare occasions, when going back to my dual-monitor setup, nvidia-settings will set my secondary display to X screen 1, but still display it as X screen 0, even though it writes the former to the config file.
The solution is to set the display to X screen 1 or New X screen, reboot, then set it back to X screen 0. It is a weird GUI bug that does not happen every time.
