Hello everyone,
I am experiencing an issue with my external monitor that sometimes it randomly freezes, and seconds later my laptop, and i am force to reboot (Using REISUB) as can’t do anything else. I can’t seem to find the issue, but it might be related to nvidia so I reinstalled the packages but still facing problems.
Kernel: 6.12.13-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: HP product: OMEN Laptop 15-en1xxx v: N/A
Mobo: HP model: 88D1 v: 75.75 serial: <superuser required>
part-nu: 455C8UA#ABA uuid: <superuser required> UEFI: AMI v: F.20
date: 08/09/2022
Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB
L3: 16 MiB
Speed (MHz): avg: 1992 min/max: 400/4280 boost: enabled cores: 1: 1992
2: 1992 3: 1992 4: 1992 5: 1992 6: 1992 7: 1992 8: 1992 9: 1992 10: 1992
11: 1992 12: 1992 bogomips: 79080
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 570.86.16 arch: Ampere pcie:
speed: 2.5 GT/s lanes: 8 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: none
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 0408:5423
class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,radeon alternate: fbdev,nouveau,nv,vesa
dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: 27E6QC serial: <filter> res: 2560x1440 dpi: 108
size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 2560x1440
min: 640x480
Monitor-2: eDP-1 model: LG Display 0x05fe res: 1920x1080 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
renoir LLVM 19.1.7 DRM 3.59 6.12.13-1-lts) device-ID: 1002:1638
display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.13-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-68695874c7c5 state: down mac: <filter>
IF-ID-2: br-b4466ca712b1 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 68.1 C mobo: 52.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): fan-1: 2685 fan-2: 0
Memory: total: 32 GiB note: est. available: 30.7 GiB used: 4.96 GiB (16.2%)
