Make sure when you update the bios and set your settings to default you go back and turn off secure boot and fast boot before you start the process.
If you are going to build the partitions yourself just make sure first use gparted and create a GPT partition table which will delete existing partitions. Then create the partitions you want and use @FLVAL suggests 550 mb for the EFI partition and use mark it as /boot/efi. Create all your other partitions and then run the install. Make sure you look at the window at the bottom of the install screen as to where it is reporting it will install grub. I hope it works out for you and if it doesnāt then try @pudge suggestion as i know he had a similar issue but older hardware i think and @fernandomaroto suggestion. One of these should work because they are working in most applications.
Edit: Donāt forget the EFI partition is formatted Fat32
Reset BIOS to factory Defaults. - Not necessary, it will goes itself on default after updateā¦
Update it - Yes
Start EndeavourOS
not yet setup correctly your bios before to start Eos usb uefi live. Check uefi mode, select your UEFI SDD and UEFI usb key for boot + like @ricklinux told turn off secure boot and fast boot
Start EOS UEFI USB live
Build partitions myself
with Gparted rebuild your head gpt partion SDD (we are agree that in doing it, you will loose all your data on your SDD)
now create first partition sda1 550 Mb EFI and mark it as /boot/efi with flag esp format Fat32
create sda2 20Gb or 30Gb partition system mark it as / format ext4
create sda3 rest of the disk size mark it as /home format ext4
Start auto-installer.
yes your sdd is ready for install with Calamares
build grub
yes as @ricklinux told you check at the bottom of the install screen from Calamares where it is reporting it will install grub and put it on sda1
Just came back home, will try everything tomorrow (hope i come back earlier), will give you updated. That seems like i used to do but i think my bios is fucked up so resetting/update will probably help. See you tomorrow !
I was scared that your bios update turned badly !
So good your sheme partition is perfect, the only thing I have a doubt is about SWAP, I know that itās not recommanded by EOS to not use it on SDD that could damage it, so need to check this on M2 if itās the same or not.
About your motherboard, did you got to update it with the last BIOS version A ?
Do you see UEFI USB Key when prompt for install ? Iām wondering if you run really your USB key as UEFI !
I build the USB key with Mintstick which I could install at least 20 differents distros to test with success, always workā¦This USB creator is just an incredible tool. It makes the USB key from ISO in Fat16, never got problem with. In case you are interesting :
Do you think the M.2 could be different from SDD or HDD on usage ?
Your partition sheme is good, your UEFI USB key seems to work, on install on Calamares where did you place the grub when it asked you ?
