This is really strange. After I uninstalled it it booted normally with a black text screen.
Then after that I could get the image of my choice.
I can’t believe it happens with an expert.
Grub “features” again?
Well it doesn’t make sense or maybe it does as this computer i never had any issue with the original grub fiasco. It has been working all along and i use it once a day and it’s always up to date. I was shocked when i saw the grub2-theme-endeavouros was missing. So i dealt with it as far as i know properly but then it just wouldn’t boot except straight to the firmware screen. This is my dual boot Windows/Xfce on Nvidia which i haven’t had any issues with. Both grub wise or Nvidia.
Yes it had an error and then if you pressed enter it went to the black screen and booted. But then when i removed the entry in /etc/default/grub and updated that’s when it booted only into firmware?
I thought it is over and with installing/updating/mkconfig it should not happen.
I don’t know if this another reason to start thinking seriously about it?
I know some might get angry with me.
But … even with this solution of doing that stuff… it should not be like this. This is not how operating systems work.
This is what I believe, just my personal point of view.
It’s probably because i still had the original grub that had the problem even though it never showed itself. I just thought i was past all that stuff since it never emerged until now! Why?
Edit: It’s gone now because i reinstalled it faster than you can blink! Almost!
Since we don’t know what caused it and it is a single instance of an issue, I wouldn’t panic over it.
I’m not panicking…just don’t understand if my system is up to date and the grub2-theme-endeavouros package was removed a while back? Why all of a sudden it does this?
Another GRub new “feature”!
Though it is working fine with me after I made the hook, knowing how it did with you makes me really consider converting again to sytsemd-boot
. I see there is no guarantee it will not break in the future. It might be safer to convert again though sacrificing booting to old snapshots.
I remember like a month ago, I was surprised that despite having BTRFS, snapshots… etc. I had nothing to boot to. As you did, it was easier for me to make a fresh install. But this contradicts the point of a rolling release, and I do not feel OK to reinstall, reconfigure,… all the stuff I did again.
For me reinstalling is a joke. I also had btrfs but I’m not a whiz at understanding how to do everything so sometimes it’s just not worth my time. I don’t have data, I don’t save stuff.
Edit: Sure i can use systemd-boot but if something goes wrong with it I’d be worse off than grub as i don’t understand it any better.
How is that? I know everybody was reinstalling, reconfiguring… Grub to avoid this.
For me, the main issue is reinstalling and configuring all the apps allover again.
Installation is smooth and easy.
@ricklinux said he had the old Grub (I don’t know how he could keep it there all that time)
Lucky you. I tend to panic in 2 cases only
- when I can’t boot to the system
- when I have a problem with WiFi
Other than that, no matter what happens I don’t care, everything can be uninstalled, cleaned. reinstaled,… (almost)
There is nothing much to configure. It’s minor. I don’t configure the crap out of stuff. It’s minor minor setting changes and installed packages take only a couple of minutes.
But not everyone did. This could easily be the first time he ran grub-mkconfig since then.
My experience, systemd-boot was really simple.
My humble understanding it is simpler by design than Grub, so it fits the KISS. Though Grub offers a lot more.
You know what, I am same as you I don’t understand systemd-boot
more than Grub, but I actually don’t understand any of them!
So, he didn’t though updating/upgrading for a month and it was booting normally till it happened now?
I am trying to imagine how!
What are you talking about? As we discussed yesterday, you don’t need to run grub-mkconfig when you update. You are choosing to do so but that is your personal choice, not a general requirement.
Sorry for misunderstanding.
What I was understanding that you have to if kernel gets updated.
No, you only need to run it if you add/remove kernels, run grub-install or change the grub configuration.
Thank you for clarifying this to me. So I mistakenly understood. Adding a kernel is not same as updating the kernel. I hope I got it right this time.
