Mismatch between pool hostid and system hostid on imported pool
I noticed an issue getting the status of the zfs pool
found some info over here
https://github.com/openzfs/zfs/issues/9367
sudo zpool export <name pool>
sudo zgenhostid
sudo zpool set multihost=on
sudo zpool set multihost=off
sudo rm /etc/hostid
sudo zpool import -d /dev/disk/by-id -aN
These commands did the trick for me. I did not see the message anymore.
Is there somehow a relation between dracut and zfs showing this message anyway ?
Usually that error is caused by not creating a hostid prior to creating the pool, by sharing a pool between multiple installs or by mounting the pool externally to the system.
Typically the solution is to create a hostid using sudo zgenhostid. Then export and reimport the pool. Depending on when you import the pool, you may need to then run sudo dracut-rebuild so the new hostid gets in the initrd.
What you did seems like it will not be a long-term fix since you removed the hostid you generated.
Thanks @dalto for your quick response, it worked
