Mirror selection for installation
As the title says how can I select which mirrors to use for installation because at the moment installing endeavor takes 3 - 4 hours whereas updating after install takes a lot less time because I manually select appropriate mirrors.
Simple. Update the mirrors on the live ISO via the welcome app. Just remember the live ISO is not persistent and changes do not stay applied if you reboot.
Oh that works? Thank you, I will try it out.
