For me, it’s about not wanting things installed that I don’t need. I don’t have a printer, so I don’t have cups installed. My question: with the online installation (KDE Plasma), can I also deselect the print-manager or do I need it to be able to print documents as .pdf (in Libreoffice this is done via the export function anyway)?
Or, on an existing installation, remove it with
sudo pacman -Rns print-manager ?
Does the absence of print-manager affect anything else in the system (conversion of documents to .pdf outside the PDF export function in LibreOffice is not provided).
Edit: Just found out that print-manager cannot be uninstalled afterwards because that would violate kde-meta-package dependencies. OK, then just leave it out when reinstalling.
[uwe@HAL ~]$ sudo pacman -Rs print-manager
[sudo] Passwort für uwe:
Abhängigkeiten werden geprüft …
Fehler: Vorgang konnte nicht vorbereitet werden (Kann Abhängigkeiten nicht erfüllen)
:: Entfernen von print-manager verletzt Abhängigkeit »print-manager«, benötigt von kde-utilities-meta
[uwe@HAL ~]$
I would have to disassemble the kde-utilities-meta.
