Microphone (HyperX QuadCast) no longer detected
Hi,
for a few days before my vacation I noticed, that my mic was missing from the settings (using KDE). Several search results didn’t help and I don’t want to break it any further by editing any files without knowing what I am doing. I just uninstalled easyeffects and reinstalled pipewire before I rebooted in hopes it would fix anything but sadly it didn’t.
I’m using headphones through a headphone jack and an USB soundbar. The mic is also connected through USB and was always also displayed as an output device as well as an input device. Currently it is only listed as an output device.
Here are some infos that might help finding the issue:
inxi -A
  Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
  Device-3: Creative SB Katana V2X
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
  Device-4: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
    type: USB
  API: ALSA v: k6.12.6-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.2.7 status: active
arecord -l
**** Liste der Hardware-Geräte (CAPTURE) ****
Karte 0: V2X [SB Katana V2X], Gerät 0: USB Audio [USB Audio]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 2: Generic [HD-Audio Generic], Gerät 0: ALC1220 Analog [ALC1220 Analog]
  Sub-Geräte: 1/1
Karte 2: Generic [HD-Audio Generic], Gerät 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
  Sub-Geräte: 1/1
Karte 3: S [HyperX QuadCast S], Gerät 0: USB Audio [USB Audio]
  Sub-Geräte: 1/1
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 271
Tile Size: 65472
User Name: *****
Host Name: *****
Server Name: PulseAudio (on PipeWire 1.2.7)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_0d_00.4.analog-stereo
Default Source: alsa_output.usb-HP__Inc_HyperX_QuadCast_S-00.analog-stereo.monitor
Cookie: 7c16:5b39
I’m also having a similar issue with a HyperX headphone. It worked normally until some update about a month ago. Did you manage to find a solution? Thanks.
