Hi all
I need to resolve this problem: The gain on my Boya Lavalier microphone is WAY too low. Its almost inaudible using regular levels, and just barely usable on max boosted levels using pavucontrol and/or alsamixer
I have tested the microphone on a cheap USB audio dongle, and here the gain is perfectly fine, no need to even boost the gain/volume.
I’ve tried searching the net for solutions, but none has been found!
Do you have a suggestion for a solution, or should i wrap up the motherboard, and send it back using guarantee?
Let me know if you need logs or further hard/software info…
Thanks in Advance,
Gabriel
