Meta key at random times not working, regardless whether on X or Wayland
I recently started having weird issues with the Meta (a.k.a. Win) key on EndeavourOS on Slimbook Pro X 14.
Problem
At seemingly random occasions, the Meta key stops working completely.
One minute, everything works fine and the Meta key works both to open up the application menu, Meta+Tab switches between Activities, Meta+W triggers the overview etc. etc.
The next, none of these do anymore.
Potential culprits (or what I tried to blame so far)
I initially blamed this on Lutris or Steam, but since then it happened a few times even without either running.
Then I thought it may be an issue Wayland, so I switched back to X11.
The problem persisted. I used xev and when the Meta key stops working in Plasma, also xev does not detect presses or releases of that button.
I have not yet figured out what triggers the problem …will update here, if I do.
Still, this is very annoying and any help would be greatly appreciated.
Work-around
Sometimes – but not always – when I suspend to RAM (sleep) and then wake up the laptop again, Meta key would start working again.
Sometimes it takes a few sleep-wake-up cycles for that to happen though.
Where it worked
This is a new (about a week old) machine and when I ran the stock Ubuntu with GNOME set-up on it for the first few days, this issue did not show up. (I’m not 100% dismissing a HW issue, but this seems like relevant info.)
(I am posting this to Plasma, but feel free to move wherever it fits better.)
Regardless of compositor xev/wev (wev is xev on wayland) should detect the key. My guess is hardware.
If you boot off the install media into a live system, does it work??
I have not tried that yet, and as I said, it seems to kick off at random, so I hard to tell how long I would need to use it test it properly :person_shrugging:
Is there a way to detect it in the console / tty?
In a terminal:
 xev -event keyboard
It will report keytstrokes made in the terminal, without all the noise from the touchpad.
That only works in a terminal emulator.
What I’m asking is if it is possible to detect this as a faulty button without windowing system – without X and without Wayland?
At work, so sneakin’ a peek at the forum and read it wrong! Not that I know of.
I remember having a problem with the Super key with Plasma 4 and having to use (from memory) Ksuperkey.
Yeah, but the KSuperKey thing was likely the issue from a few years ago (in Plasma) when Meta would only act as a modifier, but did not want to open the menu.
In any case I’ll write to Slimbook to ask them what they think. This laptop has a custom Meta key engraving, so it may actually be an issue with the hardware, let’s see …
(Don’t get into trouble at work on my behalf!)
Many keyboards have a meta key “lock” feature, which intentionally disables the key. I believe it is for Windows users, to prevent disrupting a game by accidentally pressing it.
See if you can figure out if your keyboard has it, and how to trigger it (sometimes it is Fn + meta, not always). Maybe it is being triggered inadvertently.
That was in fact it. I just got an answer from Slimbook’s support saying that Fn+F2 is hard-coded to disable/enable the Meta key.
