Mesa 23.1.0-1 is causing issues for amd-gpu?
/counting/
And i have already 3 users on telegram asking for help about something very similar looking…
so radeon driver looks like the effected one not amdgpu ?
sudo downgrade mesa lib32-mesa
but i would recommend to not add them to ignore list if it asks to do that!
should be a workaround and also possible if you already updated and see the issue on bootup… switch to TTY:
CtrlAltF3
should give you a login prompt.
Strange, I’m not facing issues, perhaps something with X11? I’m on Wayland…
DE: Gnome
$ inxi -G
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
    driver: amdgpu v: kernel
  Display: wayland server: X.Org v: 23.1.1 with: Xwayland v: 23.1.1
    compositor: gnome-shell v: 44.1 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~120Hz
  API: OpenGL v: 4.6 Mesa 23.1.0 renderer: AMD Radeon RX 6750 XT (navi22
    LLVM 15.0.7 DRM 3.52 6.3.3-arch1-1)
looks like only mobile GPU’s so far. No issues here 6750 XT
yes lets see the report is also still not confirmed…
but see:
its art… renoir ? and this is not a mobile GPU as it looks like…
just to add: already using 23.1 since rc2. 23.1.1 is scheduled for a release tonight. Let’s see, maybe a fix is already included.
Here also all good, desktop machine with RX 580, libva-mesa-driver 23.1.0-1 and mesa 23.1.0-1 are already installed.
Edit: I forgot to mention: KDE Plasma (just read that it made Gnome unusable).
No issues here on sway/wayland nor with i3/X11 with an AMD iGPU (680M).
Stupid question: How do I get back from the TTY to the GUI? With startx?
Usually press Ctrl + Alt + F7.
X is still nesting at TTY7 in most cases in some also on TTY1 or restart the DM will bring it back to:
sudo systemctl restart DM-name
I have no issue either with KDE using this version. Screen is crystal clear.
Edit: Seems to be Radeon ATI version graphics cards.
You have misunderstood me. I wrote that everything is fine with me and addendum: KDE is running here.
Does KDE trigger a protective reflex in you?
Confirmed here. Though it was Firefox because it would look garbled when I loaded it, but fine everywhere else, but when I rebooted everything was jacked up. Snapper to the rescue!
I have an A6 APU if anyone is wondering. mesa and amdvlk was updated,
No i understood you perfectly. I’m just saying that i have no issue with the latest mesa on KDE with Ryzen and i read the info about it. I think it was reported on older ATI graphics using Radeon.
Not having problems on my machine. I’m running a r6700xt card and Wayland
It seems to be only a problem for the older APU computers. At least that is what I am seeing in common. Mine still acted up when it was in X11 and Wayland. It finally got to the point that even the login screen was jacked up.
I’m on a old amd-gpu R9 M380 mac edition (mobile gpu) on a imac 27". I was planning to take a pic of my “art login” but it’s already here :slightly_smiling_face: So the update yesterday was not good for me.
Cheers
Same screen error for me.
$ inxi -SG
  Host: eco Kernel: 6.1.29-1-lts arch: x86_64 bits: 64 Desktop: KDE Plasma
    v: 5.27.5 Distro: EndeavourOS
  Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E] driver: radeon
    v: kernel
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: radeon
    unloaded: modesetting dri: radeonsi gpu: radeon resolution: 1920x1080~60Hz
  API: OpenGL v: 4.5 Mesa 23.0.3 renderer: VERDE ( LLVM 15.0.7 DRM 2.50
    6.1.29-1-lts)
