Memory problem
Hi all. When I boot up my EOS box, the first message I get is the following: “cannot unprotect memory range…”, and then I get two very long numbers in hexadecimal, which I assume is the address range. What does this mean and how can I fix it?
GR
Seems to be related to BIOS…
This issue has been mentioned on the MSI Forums and the ASRock Forums as well.
@UncleSpellbinder, From what I’ve been reading, you may be right. I have a Gigabyte B850I AORUS PRO (32GB DDR5 RAM), which I updated not long ago. Now, on their website, there seems to be another update to fix a DDR5 memory problem. I’ll see what the new update is about and let you know how I fared.
GR
@UncleSpellbinder
I installed the new BIOS update but it didn’t solve the problem. I’m thinking that I may have to join the Gigabyte forum to see if I can get an answer. At least it isn’t causing any problems for me while I’m using this computer.
GR
So just finished flashing my Gigabyte Bios to the latest version and got the same error, but it did also just boot after the error. If I understand this correctly the memory update had something to do with Hynix memory chips, which as far as I know are not on my memory sticks (Corsair) , so maybe that causes the error ?
I contacted Gigabyte and asked if that error could be harmful and they replied that it often happens with Arch and Arch-based installations, but it’s inconsequential and causes no harmful effects either to the hardware or software. If I find a way to fix it, I’ll post the fix on the EOS forum. BTW, I have 2x16GB Corsair memory sticks.
GR
I have an older MSi Z370 GAMING M5 board with Corsair Vengeance LPX 32GB (2 x 16GB) DDR4 DRAM @ 3000MHz. The latest available BIOS is version 7B58v1B dated 2024-08-09. So I have the latest BIOS update already for my board. Hopefully, if/when another BIOS update for my board is released, the issue will be addressed.
Hmm this is kind of weird because the error does not show up on Artix (Arch based but uses Openrc instead of systemd) or any other distros I have installed. So it could be a combination of Arch with systemd thing.
So after more than a month I downloaded the latest Bios flash for my Gigabyte MOBO.
Now I have good news and (maybe) some bad news.
The error was gone after the BIOS update but the primary bootloader (1) was gone.
Had that happen before so I had made sure there was a secondary bootloader (debian grub) present, where I could boot from. So if you want to flash the BIOS be aware of the fact you might loose your bootloader. Also don’t forget that a BIOS update resets everything to default (including enabling secure boot again).
