Memory Issue After Fresh Install
Hello, I’ve recently started trying to set up an old computer I received from someone moving to use as a server. The specs of the computer are as follows:
ASUS 990FX Extrem3 Motherboard (updated to last official BIOS)
FX4350 (AM3+) CPU
EVGA GTX 980
EVGA 850W PSU
G.Skill RipJaw DDR3-1600 (F3-12800CL9D-8GBRL, CL9-9-9-24 1.50v, XMP Ready, 2017)
SATA attached HDD
KDE Plasma Wayland
Using separate root and home partition
booting with grub
Entire system up to date
I am having an issue with RAM, it is showing only 3.8GB of memory available. The KDE system menu shows
Memory: 8 GiB of RAM (3.8 GiB usable)
there is a message beside it saying
Some memory is reserved for use by the kernel or system hardware such as integrated graphics memory.
Which is fair, but 4.2GiB seems WAY to high.
As an additional note, I have an addition pair of 2GBx2 sticks (same make and model, just lower capacity) that I removed for the purposes of debugging, however when they were connected, I still saw ~4.2GiB unusable.
I’m not really sure what to do, I’m not seeing any issues in the places I would expect, the CPU doesn’t even have integrated graphics. I haven’t seen anything like this on my main Arch desktop. This is my first time with Endeavor (I normally use Arch, but “Arch with a real installer” sounded very nice), is this just expected? Is there some subsystem that Endeavor shipped I should disable?
Log outputs:
>>> uname -a
Linux drakerp2-server 6.16.8-arch3-1 #1 SMP PREEMPT_DYNAMIC Mon, 22 Sep 2025 22:08:35 +0000 x86_64 GNU/Linux
>>> sudo dmidecode
# dmidecode 3.6
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
27 structures occupying 1645 bytes.
Table at 0x000EC5A0.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
	Vendor: American Megatrends Inc.
	Version: P1.90
	Release Date: 08/04/2015
	Address: 0xF0000
	Runtime Size: 64 kB
	ROM Size: 4 MB
	Characteristics:
		PCI is supported
		BIOS is upgradeable
		BIOS shadowing is allowed
		Boot from CD is supported
		Selectable boot is supported
		BIOS ROM is socketed
		EDD is supported
		5.25"/1.2 MB floppy services are supported (int 13h)
		3.5"/720 kB floppy services are supported (int 13h)
		3.5"/2.88 MB floppy services are supported (int 13h)
		Print screen service is supported (int 5h)
		8042 keyboard services are supported (int 9h)
		Serial services are supported (int 14h)
		Printer services are supported (int 17h)
		ACPI is supported
		USB legacy is supported
		BIOS boot specification is supported
		Targeted content distribution is supported
		UEFI is supported
	BIOS Revision: 4.6
Handle 0x0001, DMI type 1, 27 bytes
System Information
	Manufacturer: To Be Filled By O.E.M.
	Product Name: To Be Filled By O.E.M.
	Version: To Be Filled By O.E.M.
	Serial Number: To Be Filled By O.E.M.
	UUID: 03000200-0400-0500-0006-000700080009
	Wake-up Type: Power Switch
	SKU Number: To Be Filled By O.E.M.
	Family: To Be Filled By O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
	Manufacturer: ASRock
	Product Name: 990FX Extreme3
	Version:
	Serial Number:
	Asset Tag:
	Features:
		Board is a hosting board
		Board is replaceable
	Location In Chassis:
	Chassis Handle: 0x0003
	Type: Motherboard
	Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
	Type: Desktop
	Lock: Not Present
	Asset Tag: To Be Filled By O.E.M.
	Boot-up State: Safe
	Power Supply State: Safe
	Thermal State: Safe
	Security Status: None
	OEM Information: 0x00000000
	Height: Unspecified
	Number Of Power Cords: 1
	Contained Elements: 0
	SKU Number: To be filled by O.E.M.
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
	Socket Designation: CPUSocket
	Type: Central Processor
	Family: FX
	Manufacturer: AMD
	ID: 20 0F 60 00 FF FB 8B 17
	Signature: Family 21, Model 2, Stepping 0
	Flags:
		FPU (Floating-point unit on-chip)
		VME (Virtual mode extension)
		DE (Debugging extension)
		PSE (Page size extension)
		TSC (Time stamp counter)
		MSR (Model specific registers)
		PAE (Physical address extension)
		MCE (Machine check exception)
		CX8 (CMPXCHG8 instruction supported)
		APIC (On-chip APIC hardware supported)
		SEP (Fast system call)
		MTRR (Memory type range registers)
		PGE (Page global enable)
		MCA (Machine check architecture)
		CMOV (Conditional move instruction supported)
		PAT (Page attribute table)
		PSE-36 (36-bit page size extension)
		CLFSH (CLFLUSH instruction supported)
		MMX (MMX technology supported)
		FXSR (FXSAVE and FXSTOR instructions supported)
		SSE (Streaming SIMD extensions)
		SSE2 (Streaming SIMD extensions 2)
		HTT (Multi-threading)
	Version: AMD FX(tm)-4350 Quad-Core Processor
	Voltage: 1.3 V
	External Clock: 200 MHz
	Max Speed: 4200 MHz
	Current Speed: 4200 MHz
	Status: Populated, Enabled
	Upgrade: Socket AM3
	L1 Cache Handle: 0x0005
	L2 Cache Handle: 0x0006
	L3 Cache Handle: 0x0007
	Part Number: To Be Filled By O.E.M.
	Core Count: 4
	Core Enabled: 4
	Thread Count: 4
	Characteristics:
		64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
	Socket Designation: L1-Cache
	Configuration: Enabled, Not Socketed, Level 1
	Operational Mode: Write Back
	Installed Size: 192 kB
	Maximum Size: 192 kB
	Supported SRAM Types:
		Pipeline Burst
	Installed SRAM Type: Pipeline Burst
	Speed: 1 ns
	Error Correction Type: Multi-bit ECC
	System Type: Unified
	Associativity: 2-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
	Socket Designation: L2-Cache
	Configuration: Enabled, Not Socketed, Level 2
	Installed Size: 4 MB
	Maximum Size: 4 MB
		Pipeline Burst
	Speed: 1 ns
	Associativity: 16-way Set-associative
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
	Socket Designation: L3-Cache
	Configuration: Enabled, Not Socketed, Level 3
	Installed Size: 8 MB
	Maximum Size: 8 MB
		Pipeline Burst
	Speed: 1 ns
	Associativity: 64-way Set-associative
Handle 0x0008, DMI type 9, 17 bytes
System Slot Information
	Designation: PCI1
	Type: PCI
	Data Bus Width: 32 bit
	Current Usage: In Use
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
		PME signal is supported
Handle 0x0009, DMI type 9, 17 bytes
	Designation: PCI2
	Type: PCI
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
Handle 0x000A, DMI type 9, 17 bytes
	Designation: PCIE1
	Type: PCI Express
	Data Bus Width: 1x or x1
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
	Bus Address: 0000:00:0f.0
Handle 0x000B, DMI type 9, 17 bytes
	Designation: PCIE2
	Type: PCI Express
	Data Bus Width: 16x or x16
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
	Bus Address: 0000:00:02.0
Handle 0x000C, DMI type 9, 17 bytes
	Designation: PCIE3
	Type: PCI Express
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
	Bus Address: 0000:00:0b.0
Handle 0x000D, DMI type 9, 17 bytes
	Designation: PCIE4
	Type: PCI Express
	Data Bus Width: 4x or x4
	Length: Short
	Characteristics:
		3.3 V is provided
		Opening is shared
	Bus Address: 0000:00:0d.0
Handle 0x000E, DMI type 11, 5 bytes
OEM Strings
	String 1: To Be Filled By O.E.M.
Handle 0x000F, DMI type 16, 23 bytes
Physical Memory Array
	Use: System Memory
	Error Correction Type: None
	Maximum Capacity: 32 GB
	Error Information Handle: Not Provided
	Number Of Devices: 4
Handle 0x0010, DMI type 19, 31 bytes
Memory Array Mapped Address
	Starting Address: 0x00000000000
	Ending Address: 0x0013F0003FF
	Range Size: 5104 MB
	Physical Array Handle: 0x000F
	Partition Width: 255
Handle 0x0011, DMI type 17, 34 bytes
Memory Device
	Total Width: 64 bits
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: A1_DIMM0
	Bank Locator: A1_BANK0
	Type: DDR3
	Type Detail: Synchronous Unbuffered (Unregistered)
	Speed: 1600 MT/s
	Manufacturer: Undefined
	Serial Number: 00000000
	Asset Tag: A1_AssetTagNum0
	Part Number: F3-12800CL9-4GBRL
	Rank: 2
	Configured Memory Speed: 800 MT/s
Handle 0x0012, DMI type 20, 35 bytes
Memory Device Mapped Address
	Ending Address: 0x000FFFFFFFF
	Range Size: 4 GB
	Physical Device Handle: 0x0011
	Memory Array Mapped Address Handle: 0x0010
	Partition Row Position: 1
Handle 0x0013, DMI type 17, 34 bytes
Memory Device
	Total Width: Unknown
	Data Width: 64 bits
	Size: No Module Installed
	Form Factor: DIMM
	Set: None
	Locator: A1_DIMM1
	Bank Locator: A1_BANK1
	Type: Unknown
Handle 0x0014, DMI type 126, 35 bytes
Inactive
Handle 0x0015, DMI type 17, 34 bytes
Memory Device
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: A1_DIMM2
	Bank Locator: A1_BANK2
	Type: DDR3
	Speed: 1600 MT/s
	Asset Tag: A1_AssetTagNum2
	Rank: 2
Handle 0x0016, DMI type 20, 35 bytes
	Starting Address: 0x00100000000
	Ending Address: 0x001FFFFFFFF
	Range Size: 4 GB
	Physical Device Handle: 0x0015
Handle 0x0017, DMI type 17, 34 bytes
Memory Device
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: A1_DIMM3
	Bank Locator: A1_BANK3
	Type: Unknown
Handle 0x0018, DMI type 126, 35 bytes
Inactive
Handle 0x0019, DMI type 32, 20 bytes
System Boot Information
	Status: No errors detected
Handle 0x001C, DMI type 127, 4 bytes
End Of Table
>>> free -h
               total        used        free      shared  buff/cache   available
Mem:           3.8Gi       2.6Gi       604Mi        55Mi       711Mi       1.2Gi
Swap:          511Mi       383Mi       128Mi
>>> sudo dmesg
[    0.000000] Linux version 6.16.8-arch3-1 (linux@archlinux) (gcc (GCC) 15.2.1 20250813, GNU ld (GNU Binutils) 2.45.0) #1 SMP PREEMPT_DYNAMIC Mon, 22 Sep 2025 22:08:35 +0000
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=59e659d9-4b65-4db5-88dc-2eadd1ffa6a1 rw nowatchdog nvme_load=YES loglevel=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000b0338fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000b0339000-0x00000000b033afff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000b033b000-0x00000000be1e2fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000be1e3000-0x00000000be4f5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000be4f6000-0x00000000be8defff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000be8df000-0x00000000bee31fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bee32000-0x00000000bee32fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bee33000-0x00000000bf038fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bf039000-0x00000000bf452fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf453000-0x00000000bf7f3fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bf7f4000-0x00000000bf7fffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec20000-0x00000000fec20fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed61000-0x00000000fed70fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fef00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100001000-0x000000013effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] efi: EFI v2.3.1 by American Megatrends
[    0.000000] efi: ACPI=0xbe8cf000 ACPI 2.0=0xbe8cf000 SMBIOS=0xf04c0 INITRD=0xb0337e18
[    0.000000] efi: Not removing mem52: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem53: MMIO range=[0xfec10000-0xfec10fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem54: MMIO range=[0xfec20000-0xfec20fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem55: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem56: MMIO range=[0xfed61000-0xfed70fff] (64KB) from e820 map
[    0.000000] efi: Not removing mem57: MMIO range=[0xfed80000-0xfed8ffff] (64KB) from e820 map
[    0.000000] efi: Remove mem58: MMIO range=[0xfef00000-0xffffffff] (17MB) from e820 map
[    0.000000] e820: remove [mem 0xfef00000-0xffffffff] reserved
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./990FX Extreme3, BIOS P1.90 08/04/2015
[    0.000000] DMI: Memory slots populated: 2/4
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 4080.705 MHz processor
[    0.001699] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001702] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001709] last_pfn = 0x13f000 max_arch_pfn = 0x400000000
[    0.001717] total RAM covered: 3064M
[    0.001993] Found optimal setting for mtrr clean up
[    0.001993]  gran_size: 64K 	chunk_size: 16M 	num_reg: 3  	lose cover RAM: 0G
[    0.001998] MTRR map: 8 entries (5 fixed + 3 variable; max 22), built from 9 variable MTRRs
[    0.002000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.003196] e820: update [mem 0xbf800000-0xffffffff] usable ==> reserved
[    0.003203] last_pfn = 0xbf800 max_arch_pfn = 0x400000000
[    0.007280] found SMP MP-table at [mem 0x000fd8b0-0x000fd8bf]
[    0.007303] Using GB pages for direct mapping
[    0.008045] Secure boot disabled
[    0.008046] RAMDISK: [mem 0xa07dc000-0xac45ffff]
[    0.008052] ACPI: Early table checksum verification disabled
[    0.008055] ACPI: RSDP 0x00000000BE8CF000 000024 (v02 ALASKA)
[    0.008059] ACPI: XSDT 0x00000000BE8CF070 000064 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008064] ACPI: FACP 0x00000000BE8D5218 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.008069] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20250404/tbfadt-611)
[    0.008074] ACPI: DSDT 0x00000000BE8CF170 0060A2 (v02 ALASKA A M I    00000000 INTL 20051117)
[    0.008077] ACPI: FACS 0x00000000BE8D8080 000040
[    0.008080] ACPI: APIC 0x00000000BE8D5328 00007E (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.008083] ACPI: FPDT 0x00000000BE8D53A8 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008086] ACPI: MCFG 0x00000000BE8D53F0 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.008089] ACPI: AAFT 0x00000000BE8D5430 000062 (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.008092] ACPI: HPET 0x00000000BE8D5498 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
[    0.008095] ACPI: BGRT 0x00000000BE8D54D0 000038 (v00 ALASKA A M I    01072009 AMI  00010013)
[    0.008098] ACPI: SSDT 0x00000000BE8D5508 000D40 (v01 AMD    POWERNOW 00000001 AMD  00000001)
[    0.008100] ACPI: Reserving FACP table memory at [mem 0xbe8d5218-0xbe8d5323]
[    0.008102] ACPI: Reserving DSDT table memory at [mem 0xbe8cf170-0xbe8d5211]
[    0.008103] ACPI: Reserving FACS table memory at [mem 0xbe8d8080-0xbe8d80bf]
[    0.008104] ACPI: Reserving APIC table memory at [mem 0xbe8d5328-0xbe8d53a5]
[    0.008105] ACPI: Reserving FPDT table memory at [mem 0xbe8d53a8-0xbe8d53eb]
[    0.008106] ACPI: Reserving MCFG table memory at [mem 0xbe8d53f0-0xbe8d542b]
[    0.008107] ACPI: Reserving AAFT table memory at [mem 0xbe8d5430-0xbe8d5491]
[    0.008108] ACPI: Reserving HPET table memory at [mem 0xbe8d5498-0xbe8d54cf]
[    0.008109] ACPI: Reserving BGRT table memory at [mem 0xbe8d54d0-0xbe8d5507]
[    0.008110] ACPI: Reserving SSDT table memory at [mem 0xbe8d5508-0xbe8d6247]
[    0.008173] No NUMA configuration found
[    0.008174] Faking a node at [mem 0x0000000000000000-0x000000013effffff]
[    0.008183] NODE_DATA(0) allocated [mem 0x13efd4280-0x13effefff]
[    0.008402] Zone ranges:
[    0.008403]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.008405]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.008406]   Normal   [mem 0x0000000100000000-0x000000013effffff]
[    0.008408]   Device   empty
[    0.008409] Movable zone start for each node
[    0.008411] Early memory node ranges
[    0.008412]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.008413]   node   0: [mem 0x0000000000100000-0x00000000b0338fff]
[    0.008415]   node   0: [mem 0x00000000b033b000-0x00000000be1e2fff]
[    0.008415]   node   0: [mem 0x00000000bee32000-0x00000000bee32fff]
[    0.008416]   node   0: [mem 0x00000000bf039000-0x00000000bf452fff]
[    0.008417]   node   0: [mem 0x00000000bf7f4000-0x00000000bf7fffff]
[    0.008418]   node   0: [mem 0x0000000100001000-0x000000013effffff]
[    0.008420] Initmem setup node 0 [mem 0x0000000000001000-0x000000013effffff]
[    0.008426] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.008458] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.019834] On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.019892] On node 0, zone DMA32: 3151 pages in unavailable ranges
[    0.019918] On node 0, zone DMA32: 518 pages in unavailable ranges
[    0.019934] On node 0, zone DMA32: 929 pages in unavailable ranges
[    0.024081] On node 0, zone Normal: 2049 pages in unavailable ranges
[    0.024155] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.024303] ACPI: PM-Timer IO Port: 0x808
[    0.024314] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.024324] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[    0.024327] IOAPIC[1]: apic_id 6, version 33, address 0xfec20000, GSI 24-55
[    0.024329] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.024331] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.024335] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.024337] ACPI: HPET id: 0x43538210 base: 0xfed00000
[    0.024349] e820: update [mem 0xb2f75000-0xb31b5fff] usable ==> reserved
[    0.024366] CPU topo: Max. logical packages:   1
[    0.024367] CPU topo: Max. logical dies:       1
[    0.024367] CPU topo: Max. dies per package:   1
[    0.024371] CPU topo: Max. threads per core:   1
[    0.024373] CPU topo: Num. cores per package:     4
[    0.024373] CPU topo: Num. threads per package:   4
[    0.024374] CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
[    0.024391] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.024394] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.024395] PM: hibernation: Registered nosave memory: [mem 0xb0339000-0xb033afff]
[    0.024397] PM: hibernation: Registered nosave memory: [mem 0xb2f75000-0xb31b5fff]
[    0.024399] PM: hibernation: Registered nosave memory: [mem 0xbe1e3000-0xbee31fff]
[    0.024400] PM: hibernation: Registered nosave memory: [mem 0xbee33000-0xbf038fff]
[    0.024402] PM: hibernation: Registered nosave memory: [mem 0xbf453000-0xbf7f3fff]
[    0.024404] PM: hibernation: Registered nosave memory: [mem 0xbf800000-0x100000fff]
[    0.024406] [mem 0xbf800000-0xfebfffff] available for PCI devices
[    0.024407] Booting paravirtualized kernel on bare hardware
[    0.024410] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.030380] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.031055] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u524288
[    0.031063] pcpu-alloc: s217088 r8192 d28672 u524288 alloc=1*2097152
[    0.031066] pcpu-alloc: [0] 0 1 2 3
[    0.031085] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=59e659d9-4b65-4db5-88dc-2eadd1ffa6a1 rw nowatchdog nvme_load=YES loglevel=3
[    0.031180] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-linux nvme_load=YES", will be passed to user space.
[    0.031185] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.032257] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.032739] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.032794] software IO TLB: area num 4.
[    0.065564] Fallback order for Node 0: 0
[    0.065574] Built 1 zonelists, mobility grouping on.  Total pages: 1037734
[    0.065576] Policy zone: Normal
[    0.066156] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.093567] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.105131] ftrace: allocating 56047 entries in 220 pages
[    0.105136] ftrace: allocated 220 pages with 5 groups
[    0.105317] Dynamic Preempt: full
[    0.105458] rcu: Preemptible hierarchical RCU implementation.
[    0.105458] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[    0.105459] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.105461] 	Trampoline variant of Tasks RCU enabled.
[    0.105461] 	Rude variant of Tasks RCU enabled.
[    0.105462] 	Tracing variant of Tasks RCU enabled.
[    0.105462] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.105463] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.105471] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.105474] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.105476] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.112921] NR_IRQS: 524544, nr_irqs: 1000, preallocated irqs: 16
[    0.113129] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.113219] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.113299] Console: colour dummy device 80x25
[    0.113301] printk: legacy console [tty0] enabled
[    0.113525] ACPI: Core revision 20250404
[    0.113720] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.113733] APIC: Switch to symmetric I/O mode setup
[    0.114096] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.118734] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3ad22c333a5, max_idle_ns: 440795358405 ns
[    0.118740] Calibrating delay loop (skipped), value calculated using timer frequency.. 8161.41 BogoMIPS (lpj=4080705)
[    0.118774] LVT offset 1 assigned for vector 0xf9
[    0.118778] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[    0.118780] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[    0.118787] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.118788] Spectre V2 : Mitigation: Retpolines
[    0.118789] RETBleed: Mitigation: untrained return thunk
[    0.118790] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.118792] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[    0.118793] Spectre V2 : Enabling Speculation Barrier for firmware calls
[    0.118794] active return thunk: retbleed_return_thunk
[    0.118798] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.118804] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.118806] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.118807] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.118808] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.118810] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.146406] Freeing SMP alternatives memory: 56K
[    0.146414] pid_max: default: 32768 minimum: 301
[    0.152687] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[    0.153314] landlock: Up and running.
[    0.153318] Yama: becoming mindful.
[    0.153543] LSM support for eBPF active
[    0.153759] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.153775] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.257456] smpboot: CPU0: AMD FX(tm)-4350 Quad-Core Processor (family: 0x15, model: 0x2, stepping: 0x0)
[    0.257737] Performance Events: Fam15h core perfctr, AMD PMU driver.
[    0.257737] ... version:                0
[    0.257737] ... bit width:              48
[    0.257737] ... generic registers:      6
[    0.257737] ... value mask:             0000ffffffffffff
[    0.257737] ... max period:             00007fffffffffff
[    0.257737] ... fixed-purpose events:   0
[    0.257737] ... event mask:             000000000000003f
[    0.257737] signal: max sigframe size: 1776
[    0.257737] rcu: Hierarchical SRCU implementation.
[    0.257737] rcu: 	Max phase no-delay instances is 400.
[    0.257737] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.261729] MCE: In-kernel MCE decoding enabled.
[    0.261890] smp: Bringing up secondary CPUs ...
[    0.262094] smpboot: x86: Booting SMP configuration:
[    0.262096] .... node  #0, CPUs:      #1 #2 #3
[    0.276768] smp: Brought up 1 node, 4 CPUs
[    0.276768] smpboot: Total of 4 processors activated (32645.64 BogoMIPS)
[    0.277877] Memory: 3748724K/4150936K available (19868K kernel code, 2942K rwdata, 16672K rodata, 4664K init, 4948K bss, 395104K reserved, 0K cma-reserved)
[    0.278194] devtmpfs: initialized
[    0.278194] x86/mm: Memory block size: 128MB
[    0.279214] ACPI: PM: Registering ACPI NVS region [mem 0xbe4f6000-0xbe8defff] (4100096 bytes)
[    0.279214] ACPI: PM: Registering ACPI NVS region [mem 0xbee33000-0xbf038fff] (2121728 bytes)
[    0.279214] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.279214] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.279214] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[    0.280107] pinctrl core: initialized pinctrl subsystem
[    0.280228] PM: RTC time: 02:48:14, date: 2025-09-24
[    0.281112] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.281324] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.281394] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.281465] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.281473] audit: initializing netlink subsys (disabled)
[    0.281486] audit: type=2000 audit(1758682094.167:1): state=initialized audit_enabled=0 res=1
[    0.281486] thermal_sys: Registered thermal governor 'fair_share'
[    0.281486] thermal_sys: Registered thermal governor 'bang_bang'
[    0.281486] thermal_sys: Registered thermal governor 'step_wise'
[    0.281486] thermal_sys: Registered thermal governor 'user_space'
[    0.281486] thermal_sys: Registered thermal governor 'power_allocator'
[    0.281486] cpuidle: using governor ladder
[    0.281486] cpuidle: using governor menu
[    0.281807] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.282090] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.282095] PCI: not using ECAM ([mem 0xe0000000-0xefffffff] not reserved)
[    0.282097] PCI: Using configuration type 1 for base access
[    0.282098] PCI: Using configuration type 1 for extended access
[    0.282181] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.284087] HugeTLB: allocation took 0ms with hugepage_allocation_threads=1
[    0.284087] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.284087] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.284087] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.284087] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.286328] raid6: skipped pq benchmark and selected sse2x4
[    0.286328] raid6: using ssse3x2 recovery algorithm
[    0.286776] ACPI: Added _OSI(Module Device)
[    0.286776] ACPI: Added _OSI(Processor Device)
[    0.286776] ACPI: Added _OSI(Processor Aggregator Device)
[    0.290990] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.292030] ACPI: Interpreter enabled
[    0.292046] ACPI: PM: (supports S0 S3 S4 S5)
[    0.292048] ACPI: Using IOAPIC for interrupt routing
[    0.292461] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.292506] PCI: ECAM [mem 0xe0000000-0xefffffff] reserved as ACPI motherboard resource
[    0.292517] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.292519] PCI: Using E820 reservations for host bridge windows
[    0.292691] ACPI: Enabled 9 GPEs in block 00 to 1F
[    0.300194] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.300201] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.300602] PCI host bridge to bus 0000:00
[    0.300606] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.300609] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.300611] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.300613] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.300615] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[    0.300616] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xffffffff window]
[    0.300619] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.300634] pci 0000:00:00.0: [1002:5a14] type 00 class 0x060000 conventional PCI endpoint
[    0.300769] pci 0000:00:02.0: [1002:5a16] type 01 class 0x060400 PCIe Root Port
[    0.300781] pci 0000:00:02.0: PCI bridge to [bus 01]
[    0.300785] pci 0000:00:02.0:   bridge window [io  0xe000-0xefff]
[    0.300788] pci 0000:00:02.0:   bridge window [mem 0xfd000000-0xfe0fffff]
[    0.300793] pci 0000:00:02.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.300799] pci 0000:00:02.0: enabling Extended Tags
[    0.300824] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[    0.300930] pci 0000:00:05.0: [1002:5a19] type 01 class 0x060400 PCIe Root Port
[    0.300941] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.300946] pci 0000:00:05.0:   bridge window [mem 0xfe200000-0xfe2fffff]
[    0.300955] pci 0000:00:05.0: enabling Extended Tags
[    0.300979] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[    0.301083] pci 0000:00:0a.0: [1002:5a1d] type 01 class 0x060400 PCIe Root Port
[    0.301094] pci 0000:00:0a.0: PCI bridge to [bus 03]
[    0.301099] pci 0000:00:0a.0:   bridge window [mem 0xfe100000-0xfe1fffff]
[    0.301103] pci 0000:00:0a.0:   bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[    0.301109] pci 0000:00:0a.0: enabling Extended Tags
[    0.301133] pci 0000:00:0a.0: PME# supported from D0 D3hot D3cold
[    0.301241] pci 0000:00:11.0: [1002:4390] type 00 class 0x01018f conventional PCI endpoint
[    0.301276] pci 0000:00:11.0: BAR 0 [io  0xf090-0xf097]
[    0.301278] pci 0000:00:11.0: BAR 1 [io  0xf080-0xf083]
[    0.301281] pci 0000:00:11.0: BAR 2 [io  0xf070-0xf077]
[    0.301283] pci 0000:00:11.0: BAR 3 [io  0xf060-0xf063]
[    0.301286] pci 0000:00:11.0: BAR 4 [io  0xf050-0xf05f]
[    0.301288] pci 0000:00:11.0: BAR 5 [mem 0xfe30b000-0xfe30b3ff]
[    0.301301] pci 0000:00:11.0: set SATA to AHCI mode
[    0.301396] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310 conventional PCI endpoint
[    0.301430] pci 0000:00:12.0: BAR 0 [mem 0xfe30a000-0xfe30afff]
[    0.301533] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320 conventional PCI endpoint
[    0.301567] pci 0000:00:12.2: BAR 0 [mem 0xfe309000-0xfe3090ff]
[    0.301628] pci 0000:00:12.2: supports D1 D2
[    0.301630] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.301716] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310 conventional PCI endpoint
[    0.301753] pci 0000:00:13.0: BAR 0 [mem 0xfe308000-0xfe308fff]
[    0.301851] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320 conventional PCI endpoint
[    0.301885] pci 0000:00:13.2: BAR 0 [mem 0xfe307000-0xfe3070ff]
[    0.301917] pci 0000:00:13.2: supports D1 D2
[    0.301918] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.302005] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500 conventional PCI endpoint
[    0.302113] pci 0000:00:14.1: [1002:439c] type 00 class 0x01018a conventional PCI endpoint
[    0.302147] pci 0000:00:14.1: BAR 0 [io  0xf040-0xf047]
[    0.302150] pci 0000:00:14.1: BAR 1 [io  0xf030-0xf033]
[    0.302152] pci 0000:00:14.1: BAR 2 [io  0xf020-0xf027]
[    0.302155] pci 0000:00:14.1: BAR 3 [io  0xf010-0xf013]
[    0.302157] pci 0000:00:14.1: BAR 4 [io  0xf000-0xf00f]
[    0.302163] pci 0000:00:14.1: BAR 0 [io  0x01f0-0x01f7]: legacy IDE quirk
[    0.302165] pci 0000:00:14.1: BAR 1 [io  0x03f6]: legacy IDE quirk
[    0.302166] pci 0000:00:14.1: BAR 2 [io  0x0170-0x0177]: legacy IDE quirk
[    0.302168] pci 0000:00:14.1: BAR 3 [io  0x0376]: legacy IDE quirk
[    0.302247] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300 conventional PCI endpoint
[    0.302280] pci 0000:00:14.2: BAR 0 [mem 0xfe300000-0xfe303fff 64bit]
[    0.302308] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.302388] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100 conventional PCI endpoint
[    0.302519] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401 conventional PCI bridge
[    0.302541] pci 0000:00:14.4: PCI bridge to [bus 04] (subtractive decode)
[    0.302639] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310 conventional PCI endpoint
[    0.302673] pci 0000:00:14.5: BAR 0 [mem 0xfe306000-0xfe306fff]
[    0.302766] pci 0000:00:16.0: [1002:4397] type 00 class 0x0c0310 conventional PCI endpoint
[    0.302800] pci 0000:00:16.0: BAR 0 [mem 0xfe305000-0xfe305fff]
[    0.302896] pci 0000:00:16.2: [1002:4396] type 00 class 0x0c0320 conventional PCI endpoint
[    0.302930] pci 0000:00:16.2: BAR 0 [mem 0xfe304000-0xfe3040ff]
[    0.302961] pci 0000:00:16.2: supports D1 D2
[    0.302963] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[    0.303044] pci 0000:00:18.0: [1022:1600] type 00 class 0x060000 conventional PCI endpoint
[    0.303093] pci 0000:00:18.1: [1022:1601] type 00 class 0x060000 conventional PCI endpoint
[    0.303141] pci 0000:00:18.2: [1022:1602] type 00 class 0x060000 conventional PCI endpoint
[    0.303194] pci 0000:00:18.3: [1022:1603] type 00 class 0x060000 conventional PCI endpoint
[    0.303242] pci 0000:00:18.4: [1022:1604] type 00 class 0x060000 conventional PCI endpoint
[    0.303296] pci 0000:00:18.5: [1022:1605] type 00 class 0x060000 conventional PCI endpoint
[    0.303384] pci 0000:01:00.0: [10de:13c0] type 00 class 0x030000 PCIe Legacy Endpoint
[    0.303417] pci 0000:01:00.0: BAR 0 [mem 0xfd000000-0xfdffffff]
[    0.303420] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.303424] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]
[    0.303426] pci 0000:01:00.0: BAR 5 [io  0xe000-0xe07f]
[    0.303429] pci 0000:01:00.0: ROM [mem 0xfe000000-0xfe07ffff pref]
[    0.303435] pci 0000:01:00.0: enabling Extended Tags
[    0.303454] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.303551] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:02.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.303607] pci 0000:01:00.1: [10de:0fbb] type 00 class 0x040300 PCIe Endpoint
[    0.303638] pci 0000:01:00.1: BAR 0 [mem 0xfe080000-0xfe083fff]
[    0.303649] pci 0000:01:00.1: enabling Extended Tags
[    0.303754] pci 0000:00:02.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[    0.305762] pci 0000:00:02.0: PCI bridge to [bus 01]
[    0.305814] pci 0000:02:00.0: [1b6f:7023] type 00 class 0x0c0330 PCIe Endpoint
[    0.305852] pci 0000:02:00.0: BAR 0 [mem 0xfe200000-0xfe207fff 64bit]
[    0.305863] pci 0000:02:00.0: enabling Extended Tags
[    0.305910] pci 0000:02:00.0: supports D1 D2
[    0.305912] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.306005] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.306064] pci 0000:03:00.0: [14e4:16b1] type 00 class 0x020000 PCIe Endpoint
[    0.306109] pci 0000:03:00.0: BAR 0 [mem 0xd2110000-0xd211ffff 64bit pref]
[    0.306114] pci 0000:03:00.0: BAR 2 [mem 0xd2100000-0xd210ffff 64bit pref]
[    0.306119] pci 0000:03:00.0: ROM [mem 0xfe100000-0xfe1007ff pref]
[    0.306199] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.306328] pci 0000:00:0a.0: PCI bridge to [bus 03]
[    0.306342] pci_bus 0000:04: extended config space not accessible
[    0.306392] pci 0000:00:14.4: PCI bridge to [bus 04] (subtractive decode)
[    0.306400] pci 0000:00:14.4:   bridge window [io  0x0000-0x03af window] (subtractive decode)
[    0.306402] pci 0000:00:14.4:   bridge window [io  0x03e0-0x0cf7 window] (subtractive decode)
[    0.306403] pci 0000:00:14.4:   bridge window [io  0x03b0-0x03df window] (subtractive decode)
[    0.306405] pci 0000:00:14.4:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.306407] pci 0000:00:14.4:   bridge window [mem 0x000a0000-0x000dffff window] (subtractive decode)
[    0.306409] pci 0000:00:14.4:   bridge window [mem 0xc0000000-0xffffffff window] (subtractive decode)
[    0.307105] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.307181] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.307261] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.307340] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.307404] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.307455] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.307505] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.307555] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.307774] iommu: Default domain type: Translated
[    0.307774] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.308945] SCSI subsystem initialized
[    0.308960] libata version 3.00 loaded.
[    0.308960] ACPI: bus type USB registered
[    0.308960] usbcore: registered new interface driver usbfs
[    0.308960] usbcore: registered new interface driver hub
[    0.308960] usbcore: registered new device driver usb
[    0.308960] EDAC MC: Ver: 3.0.0
[    0.308960] efivars: Registered efivars operations
[    0.309805] NetLabel: Initializing
[    0.309808] NetLabel:  domain hash size = 128
[    0.309810] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.309831] NetLabel:  unlabeled traffic allowed by default
[    0.309838] mctp: management component transport protocol core
[    0.309839] NET: Registered PF_MCTP protocol family
[    0.309863] PCI: Using ACPI for IRQ routing
[    0.316572] PCI: pci_cache_line_size set to 64 bytes
[    0.316622] e820: reserve RAM buffer [mem 0xb0339000-0xb3ffffff]
[    0.316624] e820: reserve RAM buffer [mem 0xb2f75000-0xb3ffffff]
[    0.316626] e820: reserve RAM buffer [mem 0xbe1e3000-0xbfffffff]
[    0.316628] e820: reserve RAM buffer [mem 0xbee33000-0xbfffffff]
[    0.316630] e820: reserve RAM buffer [mem 0xbf453000-0xbfffffff]
[    0.316631] e820: reserve RAM buffer [mem 0xbf800000-0xbfffffff]
[    0.316633] e820: reserve RAM buffer [mem 0x13f000000-0x13fffffff]
[    0.316768] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.316768] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.316768] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.316768] vgaarb: loaded
[    0.316789] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.316794] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.318821] clocksource: Switched to clocksource tsc-early
[    0.321961] VFS: Disk quotas dquot_6.6.0
[    0.321991] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.322186] pnp: PnP ACPI init
[    0.322290] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[    0.322409] system 00:01: [mem 0xfec20000-0xfec200ff] could not be reserved
[    0.322796] system 00:03: [io  0x040b] has been reserved
[    0.322799] system 00:03: [io  0x04d6] has been reserved
[    0.322801] system 00:03: [io  0x0c00-0x0c01] has been reserved
[    0.322803] system 00:03: [io  0x0c14] has been reserved
[    0.322805] system 00:03: [io  0x0c50-0x0c51] has been reserved
[    0.322806] system 00:03: [io  0x0c52] has been reserved
[    0.322808] system 00:03: [io  0x0c6c] has been reserved
[    0.322810] system 00:03: [io  0x0c6f] has been reserved
[    0.322812] system 00:03: [io  0x0cd0-0x0cd1] has been reserved
[    0.322813] system 00:03: [io  0x0cd2-0x0cd3] has been reserved
[    0.322818] system 00:03: [io  0x0cd4-0x0cd5] has been reserved
[    0.322820] system 00:03: [io  0x0cd6-0x0cd7] has been reserved
[    0.322822] system 00:03: [io  0x0cd8-0x0cdf] has been reserved
[    0.322824] system 00:03: [io  0x0800-0x089f] has been reserved
[    0.322826] system 00:03: [io  0x0b20-0x0b3f] has been reserved
[    0.322827] system 00:03: [io  0x0900-0x090f] has been reserved
[    0.322829] system 00:03: [io  0x0910-0x091f] has been reserved
[    0.322831] system 00:03: [io  0xfe00-0xfefe] has been reserved
[    0.322833] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.322836] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.322839] system 00:03: [mem 0xfed80000-0xfed8ffff] has been reserved
[    0.322842] system 00:03: [mem 0xfed61000-0xfed70fff] has been reserved
[    0.322845] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.322847] system 00:03: [mem 0xfed00000-0xfed00fff] could not be reserved
[    0.322849] system 00:03: [mem 0xffc00000-0xffffffff] has been reserved
[    0.322953] system 00:04: [io  0x0290-0x029f] has been reserved
[    0.323232] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.323450] pnp 00:08: [dma 0 disabled]
[    0.323747] pnp: PnP ACPI: found 9 devices
[    0.330424] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.330674] NET: Registered PF_INET protocol family
[    0.330813] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.345772] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.345820] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.345870] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.346037] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.346124] TCP: Hash tables configured (established 32768 bind 32768)
[    0.346259] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.346314] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.346341] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.346507] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.346520] NET: Registered PF_XDP protocol family
[    0.346551] pci 0000:00:02.0: PCI bridge to [bus 01]
[    0.346557] pci 0000:00:02.0:   bridge window [io  0xe000-0xefff]
[    0.346562] pci 0000:00:02.0:   bridge window [mem 0xfd000000-0xfe0fffff]
[    0.346566] pci 0000:00:02.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.346570] pci 0000:00:05.0: PCI bridge to [bus 02]
[    0.346573] pci 0000:00:05.0:   bridge window [mem 0xfe200000-0xfe2fffff]
[    0.346578] pci 0000:00:0a.0: PCI bridge to [bus 03]
[    0.346600] pci 0000:00:0a.0:   bridge window [mem 0xfe100000-0xfe1fffff]
[    0.346603] pci 0000:00:0a.0:   bridge window [mem 0xd2100000-0xd21fffff 64bit pref]
[    0.346607] pci 0000:00:14.4: PCI bridge to [bus 04]
[    0.346618] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.346620] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.346621] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.346623] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.346625] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[    0.346626] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xffffffff window]
[    0.346628] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.346630] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfe0fffff]
[    0.346631] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    0.346633] pci_bus 0000:02: resource 1 [mem 0xfe200000-0xfe2fffff]
[    0.346635] pci_bus 0000:03: resource 1 [mem 0xfe100000-0xfe1fffff]
[    0.346636] pci_bus 0000:03: resource 2 [mem 0xd2100000-0xd21fffff 64bit pref]
[    0.346638] pci_bus 0000:04: resource 4 [io  0x0000-0x03af window]
[    0.346640] pci_bus 0000:04: resource 5 [io  0x03e0-0x0cf7 window]
[    0.346641] pci_bus 0000:04: resource 6 [io  0x03b0-0x03df window]
[    0.346643] pci_bus 0000:04: resource 7 [io  0x0d00-0xffff window]
[    0.346645] pci_bus 0000:04: resource 8 [mem 0x000a0000-0x000dffff window]
[    0.346646] pci_bus 0000:04: resource 9 [mem 0xc0000000-0xffffffff window]
[    0.362579] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x760 took 15498 usecs
[    0.375586] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x760 took 12536 usecs
[    0.387566] pci 0000:00:14.5: quirk_usb_early_handoff+0x0/0x760 took 11528 usecs
[    0.399564] pci 0000:00:16.0: quirk_usb_early_handoff+0x0/0x760 took 11706 usecs
[    0.399748] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.399786] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.399966] PCI: CLS 64 bytes, default 64
[    0.399978] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.399980] software IO TLB: mapped [mem 0x000000009bca5000-0x000000009fca5000] (64MB)
[    0.400024] LVT offset 0 assigned for vector 0x400
[    0.400039] Trying to unpack rootfs image as initramfs...
[    0.400073] perf: AMD IBS detected (0x000000ff)
[    0.424157] Initialise system trusted keyrings
[    0.424176] Key type blacklist registered
[    0.424285] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[    0.425994] fuse: init (API version 7.44)
[    0.426208] integrity: Platform Keyring initialized
[    0.426215] integrity: Machine keyring initialized
[    0.438911] xor: automatically using best checksumming function   avx
[    0.438914] Key type asymmetric registered
[    0.438915] Asymmetric key parser 'x509' registered
[    0.438973] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.439034] io scheduler mq-deadline registered
[    0.439037] io scheduler kyber registered
[    0.439080] io scheduler bfq registered
[    0.439241] ledtrig-cpu: registered to indicate activity on CPUs
[    0.439943] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.439978] ACPI: button: Power Button [PWRB]
[    0.440025] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.440071] ACPI: button: Power Button [PWRF]
[    0.440497] Could not retrieve perf counters (-19)
[    0.440766] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.440939] 00:08: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.443988] Non-volatile memory driver v1.3
[    0.443990] Linux agpgart interface v0.103
[    0.444044] ACPI: bus type drm_connector registered
[    0.444823] ahci 0000:00:11.0: AHCI vers 0001.0200, 32 command slots, 6 Gbps, SATA mode
[    0.444827] ahci 0000:00:11.0: 4/4 ports implemented (port mask 0xf)
[    0.444829] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[    0.445412] scsi host0: ahci
[    0.445638] scsi host1: ahci
[    0.445791] scsi host2: ahci
[    0.445941] scsi host3: ahci
[    0.446006] ata1: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b100 irq 19 lpm-pol 3
[    0.446009] ata2: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b180 irq 19 lpm-pol 3
[    0.446012] ata3: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b200 irq 19 lpm-pol 3
[    0.446014] ata4: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b280 irq 19 lpm-pol 3
[    0.446628] QUIRK: Enable AMD PLL fix
[    0.446643] ohci-pci 0000:00:12.0: OHCI PCI host controller
[    0.446649] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 1
[    0.446678] ohci-pci 0000:00:12.0: irq 18, io mem 0xfe30a000
[    0.501591] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.16
[    0.501598] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.501601] usb usb1: Product: OHCI PCI host controller
[    0.501602] usb usb1: Manufacturer: Linux 6.16.8-arch3-1 ohci_hcd
[    0.501604] usb usb1: SerialNumber: 0000:00:12.0
[    0.501885] hub 1-0:1.0: USB hub found
[    0.501895] hub 1-0:1.0: 5 ports detected
[    0.502227] ehci-pci 0000:00:12.2: EHCI Host Controller
[    0.502233] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 2
[    0.502238] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    0.502246] ehci-pci 0000:00:12.2: debug port 1
[    0.502305] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe309000
[    0.507529] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    0.507619] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    0.507624] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.507627] usb usb2: Product: EHCI Host Controller
[    0.507629] usb usb2: Manufacturer: Linux 6.16.8-arch3-1 ehci_hcd
[    0.507631] usb usb2: SerialNumber: 0000:00:12.2
[    0.507876] hub 2-0:1.0: USB hub found
[    0.507884] hub 2-0:1.0: 5 ports detected
[    0.556610] hub 1-0:1.0: USB hub found
[    0.556642] hub 1-0:1.0: 5 ports detected
[    0.556818] ehci-pci 0000:00:13.2: EHCI Host Controller
[    0.556826] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 3
[    0.556832] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    0.556843] ehci-pci 0000:00:13.2: debug port 1
[    0.556884] ehci-pci 0000:00:13.2: irq 17, io mem 0xfe307000
[    0.562519] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    0.562606] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    0.562610] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.562612] usb usb3: Product: EHCI Host Controller
[    0.562614] usb usb3: Manufacturer: Linux 6.16.8-arch3-1 ehci_hcd
[    0.562615] usb usb3: SerialNumber: 0000:00:13.2
[    0.562819] hub 3-0:1.0: USB hub found
[    0.562828] hub 3-0:1.0: 5 ports detected
[    0.563034] ehci-pci 0000:00:16.2: EHCI Host Controller
[    0.563042] ehci-pci 0000:00:16.2: new USB bus registered, assigned bus number 4
[    0.563050] ehci-pci 0000:00:16.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    0.563062] ehci-pci 0000:00:16.2: debug port 1
[    0.563109] ehci-pci 0000:00:16.2: irq 17, io mem 0xfe304000
[    0.568511] ehci-pci 0000:00:16.2: USB 2.0 started, EHCI 1.00
[    0.568628] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    0.568632] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.568634] usb usb4: Product: EHCI Host Controller
[    0.568636] usb usb4: Manufacturer: Linux 6.16.8-arch3-1 ehci_hcd
[    0.568637] usb usb4: SerialNumber: 0000:00:16.2
[    0.568848] hub 4-0:1.0: USB hub found
[    0.568857] hub 4-0:1.0: 4 ports detected
[    0.569044] ohci-pci 0000:00:13.0: OHCI PCI host controller
[    0.569059] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 5
[    0.569097] ohci-pci 0000:00:13.0: irq 18, io mem 0xfe308000
[    0.623587] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.16
[    0.623593] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.623595] usb usb5: Product: OHCI PCI host controller
[    0.623597] usb usb5: Manufacturer: Linux 6.16.8-arch3-1 ohci_hcd
[    0.623599] usb usb5: SerialNumber: 0000:00:13.0
[    0.623797] hub 5-0:1.0: USB hub found
[    0.623807] hub 5-0:1.0: 5 ports detected
[    0.624151] ohci-pci 0000:00:14.5: OHCI PCI host controller
[    0.624160] ohci-pci 0000:00:14.5: new USB bus registered, assigned bus number 6
[    0.624195] ohci-pci 0000:00:14.5: irq 18, io mem 0xfe306000
[    0.678552] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.16
[    0.678558] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.678560] usb usb6: Product: OHCI PCI host controller
[    0.678562] usb usb6: Manufacturer: Linux 6.16.8-arch3-1 ohci_hcd
[    0.678563] usb usb6: SerialNumber: 0000:00:14.5
[    0.678734] hub 6-0:1.0: USB hub found
[    0.678745] hub 6-0:1.0: 2 ports detected
[    0.679034] ohci-pci 0000:00:16.0: OHCI PCI host controller
[    0.679040] ohci-pci 0000:00:16.0: new USB bus registered, assigned bus number 7
[    0.679063] ohci-pci 0000:00:16.0: irq 18, io mem 0xfe305000
[    0.733574] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.16
[    0.733588] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.733592] usb usb7: Product: OHCI PCI host controller
[    0.733594] usb usb7: Manufacturer: Linux 6.16.8-arch3-1 ohci_hcd
[    0.733596] usb usb7: SerialNumber: 0000:00:16.0
[    0.733821] hub 7-0:1.0: USB hub found
[    0.733831] hub 7-0:1.0: 4 ports detected
[    0.734258] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    0.734263] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 8
[    0.734336] xhci_hcd 0000:02:00.0: hcc params 0x040050af hci version 0x100 quirks 0x0002010000080090
[    0.734536] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    0.734539] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 9
[    0.734542] xhci_hcd 0000:02:00.0: Host supports USB 3.0 SuperSpeed
[    0.734584] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
[    0.734587] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.734588] usb usb8: Product: xHCI Host Controller
[    0.734590] usb usb8: Manufacturer: Linux 6.16.8-arch3-1 xhci-hcd
[    0.734591] usb usb8: SerialNumber: 0000:02:00.0
[    0.734730] hub 8-0:1.0: USB hub found
[    0.734740] hub 8-0:1.0: 2 ports detected
[    0.734850] usb usb9: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.734880] usb usb9: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.16
[    0.734882] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.734884] usb usb9: Product: xHCI Host Controller
[    0.734886] usb usb9: Manufacturer: Linux 6.16.8-arch3-1 xhci-hcd
[    0.734887] usb usb9: SerialNumber: 0000:02:00.0
[    0.734989] hub 9-0:1.0: USB hub found
[    0.734998] hub 9-0:1.0: 2 ports detected
[    0.735160] usbcore: registered new interface driver usbserial_generic
[    0.735169] usbserial: USB Serial support registered for generic
[    0.735214] i8042: PNP: No PS/2 controller found.
[    0.735361] rtc_cmos 00:05: RTC can wake from S4
[    0.735589] rtc_cmos 00:05: registered as rtc0
[    0.735613] rtc_cmos 00:05: setting system clock to 2025-09-24T02:48:15 UTC (1758682095)
[    0.735651] rtc_cmos 00:05: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.735711] amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
[    0.735857] Relocating firmware framebuffer to offset 0x0000000001000000[d] within [mem 0xd0000000-0xd1ffffff flags 0x14220c]
[    0.736097] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    0.736100] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    0.738180] fbcon: Deferring console take-over
[    0.738185] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.738244] hid: raw HID events driver (C) Jiri Kosina
[    0.738281] usbcore: registered new interface driver usbhid
[    0.738283] usbhid: USB HID core driver
[    0.738363] drop_monitor: Initializing network drop monitor service
[    0.738703] NET: Registered PF_INET6 protocol family
[    0.755489] ata1: SATA link down (SStatus 0 SControl 300)
[    0.755524] ata3: SATA link down (SStatus 0 SControl 300)
[    0.759486] ata4: SATA link down (SStatus 0 SControl 300)
[    0.918552] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.919334] ata2.00: ATA-9: ST1000DM003-1ER162, CC46, max UDMA/133
[    0.919526] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    0.920627] ata2.00: configured for UDMA/133
[    0.932189] scsi 1:0:0:0: Direct-Access     ATA      ST1000DM003-1ER1 CC46 PQ: 0 ANSI: 5
[    0.933694] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.933701] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    0.933717] sd 1:0:0:0: [sda] Write Protect is off
[    0.933722] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.933747] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.933782] sd 1:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    0.963523] Freeing initrd memory: 193040K
[    0.970965] Segment Routing with IPv6
[    0.970968] RPL Segment Routing with IPv6
[    0.970992] In-situ OAM (IOAM) with IPv6
[    0.971027] NET: Registered PF_PACKET protocol family
[    0.971088] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[    0.971364] microcode: Current revision: 0x06000852
[    0.971366] microcode: Updated early from: 0x06000817
[    0.971471] IPI shorthand broadcast: enabled
[    0.974434] sched_clock: Marking stable (973781903, 587453)->(988360029, -13990673)
[    0.974589] registered taskstats version 1
[    0.974895] Loading compiled-in X.509 certificates
[    0.982324] Loaded X.509 cert 'Build time autogenerated kernel key: 7d8148e314c8603e91d6c5edfc705ff0faf765b3'
[    0.986604] zswap: loaded using pool zstd/zsmalloc
[    0.986662] Demotion targets for Node 0: null
[    0.986925] Key type .fscrypt registered
[    0.986927] Key type fscrypt-provisioning registered
[    0.989091] Btrfs loaded, zoned=yes, fsverity=yes
[    0.989136] Key type big_key registered
[    0.989832] PM:   Magic number: 9:818:814
[    0.991948] RAS: Correctable Errors collector initialized.
[    0.998926] clk: Disabling unused clocks
[    0.998931] PM: genpd: Disabling unused power domains
[    1.007424]  sda: sda1 sda2 sda3
[    1.007728] sd 1:0:0:0: [sda] Attached SCSI disk
[    1.009811] Freeing unused decrypted memory: 2028K
[    1.011108] Freeing unused kernel image (initmem) memory: 4664K
[    1.011147] Write protecting the kernel read-only data: 38912k
[    1.011566] Freeing unused kernel image (text/rodata gap) memory: 608K
[    1.012112] Freeing unused kernel image (rodata/data gap) memory: 1760K
[    1.044445] usb 5-2: new full-speed USB device number 2 using ohci-pci
[    1.053488] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.053494] rodata_test: all tests were successful
[    1.053500] Run /init as init process
[    1.053501]   with arguments:
[    1.053502]     /init
[    1.053503]   with environment:
[    1.053504]     HOME=/
[    1.053505]     TERM=linux
[    1.053506]     BOOT_IMAGE=/boot/vmlinuz-linux
[    1.053507]     nvme_load=YES
[    1.079265] systemd[1]: Successfully made /usr/ read-only.
[    1.079551] systemd[1]: systemd 258-3-arch running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    1.079557] systemd[1]: Detected architecture x86-64.
[    1.079560] systemd[1]: Running in initrd.
[    1.079745] fbcon: Taking over console
[    1.079813] systemd[1]: Hostname set to <drakerp2-server>.
[    1.081741] Console: switching to colour frame buffer device 128x48
[    1.202853] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    1.209483] usb 5-2: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06
[    1.209490] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.209494] usb 5-2: Product: USB Receiver
[    1.209496] usb 5-2: Manufacturer: Logitech
[    1.217730] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/0003:046D:C539.0001/input/input2
[    1.264238] systemd[1]: Queued start job for default target Initrd Default Target.
[    1.278301] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.278512] systemd[1]: Expecting device /dev/disk/by-uuid/59e659d9-4b65-4db5-88dc-2eadd1ffa6a1...
[    1.278674] systemd[1]: Reached target Initrd /usr File System.
[    1.278820] systemd[1]: Reached target Path Units.
[    1.278964] systemd[1]: Reached target Slice Units.
[    1.279124] systemd[1]: Reached target Swaps.
[    1.279268] systemd[1]: Reached target Timer Units.
[    1.279484] systemd[1]: Listening on Journal Socket (/dev/log).
[    1.279727] systemd[1]: Listening on Journal Sockets.
[    1.279935] systemd[1]: Listening on udev Control Socket.
[    1.280120] systemd[1]: Listening on udev Kernel Socket.
[    1.280263] systemd[1]: Reached target Socket Units.
[    1.281527] systemd[1]: Starting Create List of Static Device Nodes...
[    1.281705] systemd[1]: Check battery level during early boot was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/class/power_supply).
[    1.283056] systemd[1]: Starting Journal Service...
[    1.284242] systemd[1]: Starting Load Kernel Modules...
[    1.284952] systemd[1]: TPM PCR Barrier (initrd) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    1.284982] systemd[1]: Reached target Local Encrypted Volumes.
[    1.286017] systemd[1]: Starting Virtual Console Setup...
[    1.289366] systemd[1]: Finished Create List of Static Device Nodes.
[    1.290508] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    1.302745] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:13.0-2/input0
[    1.307000] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.1/0003:046D:C539.0002/input/input3
[    1.307096] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.1/0003:046D:C539.0002/input/input4
[    1.307216] i2c_dev: i2c /dev entries driver
[    1.309470] systemd-journald[146]: Collecting audit messages is disabled.
[    1.322395] systemd[1]: Finished Virtual Console Setup.
[    1.325453] systemd[1]: Starting dracut ask for additional cmdline parameters...
[    1.330126] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    1.332938] systemd[1]: Starting Create Static Device Nodes in /dev...
[    1.358092] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.1/0003:046D:C539.0002/input/input5
[    1.358413] hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:13.0-2/input1
[    1.364281] hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:13.0-2/input2
[    1.376413] systemd[1]: Finished dracut ask for additional cmdline parameters.
[    1.379977] systemd[1]: Starting dracut cmdline hook...
[    1.398858] systemd[1]: Finished Create Static Device Nodes in /dev.
[    1.399344] systemd[1]: Reached target Preparation for Local File Systems.
[    1.399503] systemd[1]: Reached target Local File Systems.
[    1.407710] systemd[1]: Started Journal Service.
[    1.425613] tsc: Refined TSC clocksource calibration: 4080.731 MHz
[    1.425628] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3ad244b25a1, max_idle_ns: 440795388794 ns
[    1.425654] clocksource: Switched to clocksource tsc
[    1.526022] device-mapper: uevent: version 1.0.3
[    1.526173] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    1.694979] logitech-djreceiver 0003:046D:C539.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:13.0-2/input0
[    1.796564] logitech-djreceiver 0003:046D:C539.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:13.0-2/input1
[    1.847545] logitech-djreceiver 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:13.0-2/input2
[    1.869599] usb 5-3: new full-speed USB device number 3 using ohci-pci
[    1.901467] logitech-djreceiver 0003:046D:C539.0003: device of type eQUAD Lightspeed 1 (0x0c) connected on slot 1
[    1.902150] input: Logitech Wireless Mouse PID:4085 Keyboard as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input7
[    1.926704] input: Logitech Wireless Mouse PID:4085 Mouse as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input8
[    1.926794] hid-generic 0003:046D:4085.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Mouse PID:4085] on usb-0000:00:13.0-2/input2:1
[    2.035484] usb 5-3: New USB device found, idVendor=046d, idProduct=c541, bcdDevice= 1.02
[    2.035492] usb 5-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.035495] usb 5-3: Product: USB Receiver
[    2.035498] usb 5-3: Manufacturer: Logitech
[    2.078660] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:13.0/usb5/5-3/5-3:1.0/0003:046D:C541.0005/input/input12
[    2.078769] hid-generic 0003:046D:C541.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:13.0-3/input0
[    2.108674] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    2.108780] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[    2.109101] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[    2.114713] input: Logitech USB Receiver Keyboard as /devices/pci0000:00/0000:00:13.0/usb5/5-3/5-3:1.1/0003:046D:C541.0006/input/input13
[    2.120083] scsi host4: pata_atiixp
[    2.120254] scsi host5: pata_atiixp
[    2.120302] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14 lpm-pol 0
[    2.120306] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15 lpm-pol 0
[    2.199739] hid-generic 0003:046D:C541.0006: input,hidraw5: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:13.0-3/input1
[    2.202742] hid-generic 0003:046D:C541.0007: hiddev98,hidraw6: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:13.0-3/input2
[    2.338630] input: Logitech G604  as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input14
[    2.379641] logitech-hidpp-device 0003:046D:4085.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech G604 ] on usb-0000:00:13.0-2/input2:1
[    2.398973] nvidia: loading out-of-tree module taints kernel.
[    2.398987] nvidia: module license 'NVIDIA' taints kernel.
[    2.398989] Disabling lock debugging due to kernel taint
[    2.398994] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    2.398996] nvidia: module license taints kernel.
[    2.996433] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[    3.020107] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    3.220874] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  580.82.09  Fri Aug 29 17:44:50 UTC 2025
[    3.264282] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  580.82.09  Fri Aug 29 17:11:30 UTC 2025
[    3.273860] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    3.274031] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    3.748352] Asymmetric key parser 'pkcs8' registered
[    3.812400] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[    3.821876] Console: switching to colour dummy device 80x25
[    3.828099] nvidia 0000:01:00.0: vgaarb: deactivate vga console
[    3.885945] fbcon: nvidia-drmdrmfb (fb0) is primary device
[    3.931164] Console: switching to colour frame buffer device 240x67
[    3.950719] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[    4.196452] EXT4-fs (sda2): mounted filesystem 59e659d9-4b65-4db5-88dc-2eadd1ffa6a1 r/w with ordered data mode. Quota mode: none.
[    4.687106] systemd-journald[146]: Received SIGTERM from PID 1 (systemd).
[    5.070110] random: crng init done
[    5.656518] systemd[1]: systemd 258-3-arch running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    5.656525] systemd[1]: Detected architecture x86-64.
[    5.932542] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    7.284243] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[    7.284415] systemd[1]: Stopped Switch Root.
[    7.286237] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[    7.288365] systemd[1]: Created slice Slice /system/dirmngr.
[    7.289348] systemd[1]: Created slice Slice /system/getty.
[    7.290211] systemd[1]: Created slice Slice /system/gpg-agent.
[    7.292282] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    7.294056] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    7.294927] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    7.297185] systemd[1]: Created slice Slice /system/keyboxd.
[    7.298108] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.298831] systemd[1]: Created slice User and Session Slice.
[    7.299299] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.300849] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.301478] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.301930] systemd[1]: Expecting device /dev/disk/by-uuid/1D94-D166...
[    7.302355] systemd[1]: Expecting device /dev/disk/by-uuid/524fbb19-7b42-423f-87c9-ba2a5a7f16fa...
[    7.302777] systemd[1]: Reached target Local Encrypted Volumes.
[    7.303199] systemd[1]: Reached target Login Prompts.
[    7.303677] systemd[1]: Reached target Image Downloads.
[    7.304135] systemd[1]: Stopped target Switch Root.
[    7.304542] systemd[1]: Stopped target Initrd File Systems.
[    7.304996] systemd[1]: Stopped target Initrd Root File System.
[    7.305425] systemd[1]: Reached target Local Integrity Protected Volumes.
[    7.305853] systemd[1]: Reached target Path Units.
[    7.306289] systemd[1]: Reached target Remote File Systems.
[    7.306708] systemd[1]: Reached target Slice Units.
[    7.307146] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.307665] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    7.308208] systemd[1]: Listening on LVM2 poll daemon socket.
[    7.310242] systemd[1]: Listening on Query the User Interactively for a Password.
[    7.312335] systemd[1]: Listening on Process Core Dump Socket.
[    7.315114] systemd[1]: Listening on Credential Encryption/Decryption.
[    7.318292] systemd[1]: Listening on Factory Reset Management.
[    7.319522] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.319638] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.319971] systemd[1]: Listening on udev Control Socket.
[    7.320945] systemd[1]: Listening on udev Varlink Socket.
[    7.321878] systemd[1]: Listening on User Database Manager Socket.
[    7.333776] systemd[1]: Mounting Huge Pages File System...
[    7.336303] systemd[1]: Mounting POSIX Message Queue File System...
[    7.347976] systemd[1]: Mounting Kernel Debug File System...
[    7.350643] systemd[1]: Mounting Kernel Trace File System...
[    7.355325] systemd[1]: Starting Create List of Static Device Nodes...
[    7.358753] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    7.359416] systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!configfs).
[    7.359480] systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
[    7.359524] systemd[1]: Load Kernel Module drm was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!drm).
[    7.359564] systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!fuse).
[    7.362507] systemd[1]: Mounting FUSE Control File System...
[    7.366034] systemd[1]: Starting Load Kernel Module loop...
[    7.367579] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    7.369893] systemd[1]: Starting Journal Service...
[    7.405511] systemd[1]: Starting Load Kernel Modules...
[    7.406185] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.409426] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.411680] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.413145] systemd[1]: Starting Load udev Rules from Credentials...
[    7.417392] loop: module loaded
[    7.417816] systemd[1]: Starting Coldplug All udev Devices...
[    7.421992] systemd[1]: Mounted Huge Pages File System.
[    7.423925] systemd[1]: Mounted POSIX Message Queue File System.
[    7.425778] systemd[1]: Mounted Kernel Debug File System.
[    7.427207] systemd[1]: Mounted Kernel Trace File System.
[    7.429627] systemd[1]: Finished Create List of Static Device Nodes.
[    7.430217] systemd[1]: Mounted FUSE Control File System.
[    7.430848] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    7.431040] systemd[1]: Finished Load Kernel Module loop.
[    7.433182] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    7.434132] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    7.450945] EXT4-fs (sda2): re-mounted 59e659d9-4b65-4db5-88dc-2eadd1ffa6a1.
[    7.451980] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.453743] systemd[1]: Activating swap /swapfile...
[    7.501297] systemd-journald[497]: Collecting audit messages is disabled.
[    7.528271] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    7.529201] systemd[1]: Starting Load/Save OS Random Seed...
[    7.529892] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.530052] systemd[1]: Started Journal Service.
[    7.574412] systemd-journald[497]: Received client request to flush runtime journal.
[    7.638894] Adding 524284k swap on /swapfile.  Priority:-2 extents:3 across:540668k
[   11.331183] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[   11.331194] piix4_smbus 0000:00:14.0: Using register 0x2c for SMBus port selection
[   11.331646] i2c i2c-7: Successfully instantiated SPD at 0x50
[   11.332214] i2c i2c-7: Successfully instantiated SPD at 0x51
[   11.332407] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[   11.380263] acpi_cpufreq: overriding BIOS provided _PSD data
[   11.380632] input: PC Speaker as /devices/platform/pcspkr/input/input15
[   11.401076] at24 7-0050: supply vcc not found, using dummy regulator
[   11.403140] at24 7-0050: 256 byte spd EEPROM, read-only
[   11.403175] at24 7-0051: supply vcc not found, using dummy regulator
[   11.405988] at24 7-0051: 256 byte spd EEPROM, read-only
[   11.745068] pps_core: LinuxPPS API ver. 1 registered
[   11.745078] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   11.753306] PTP clock support registered
[   11.780143] snd_hda_intel 0000:00:14.2: enabling device (0000 -> 0002)
[   11.780383] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[   11.780438] snd_hda_intel 0000:01:00.1: Disabling MSI
[   11.780447] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   11.809661] kvm_amd: TSC scaling supported
[   11.809665] kvm_amd: Nested Virtualization enabled
[   11.809667] kvm_amd: Nested Paging enabled
[   11.809668] kvm_amd: LBR virtualization supported
[   11.823500] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input16
[   11.823646] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input17
[   11.823726] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input18
[   11.823786] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input19
[   11.836236] tg3 0000:03:00.0 eth0: Tigon3 [partno(BCM57781) rev 57785100] (PCI Express) MAC address bc:5f:f4:af:08:e8
[   11.836243] tg3 0000:03:00.0 eth0: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[   11.836246] tg3 0000:03:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[   11.836249] tg3 0000:03:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[   11.845123] tg3 0000:03:00.0 enp3s0: renamed from eth0
[   12.032696] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[   12.032704] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   12.032708] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   12.032710] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   12.032712] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
[   12.032714] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   12.032716] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[   12.032717] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[   12.032719] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[   12.041392] mousedev: PS/2 mouse device common for all mice
[   12.053678] input: HDA ATI SB Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input20
[   12.053768] input: HDA ATI SB Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input21
[   12.053840] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input22
[   12.054279] input: HDA ATI SB Line Out Front as /devices/pci0000:00/0000:00:14.2/sound/card0/input23
[   12.054375] input: HDA ATI SB Line Out Surround as /devices/pci0000:00/0000:00:14.2/sound/card0/input24
[   12.054458] input: HDA ATI SB Line Out CLFE as /devices/pci0000:00/0000:00:14.2/sound/card0/input25
[   12.054630] input: HDA ATI SB Line Out Side as /devices/pci0000:00/0000:00:14.2/sound/card0/input26
[   12.054984] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input27
[   13.167735] EXT4-fs (sda3): mounted filesystem 524fbb19-7b42-423f-87c9-ba2a5a7f16fa r/w with ordered data mode. Quota mode: none.
[   26.131976] tg3 0000:03:00.0 enp3s0: Link is up at 1000 Mbps, full duplex
[   26.131998] tg3 0000:03:00.0 enp3s0: Flow control is on for TX and on for RX
[   26.132017] tg3 0000:03:00.0 enp3s0: EEE is enabled
[   51.519768] logitech-hidpp-device 0003:046D:4085.0004: HID++ 4.2 device connected.
BIOS option?
That is usually a hardware reservation. Check your BIOS settings and see if you have some reserved memory set for shared VRAM.
