Hey, all.
I’ve installed Artmis, I’m impressed.
I’m a fan of Mate DE, so yes, that is what I’m using.
My system is a Dell OptiPlex 9020, with i7 4790 in the CPU socket.
When I shutdown the system, the volume of the audio is set to 1%, because that works for me.
When I restart the system, the restored volume is at 4%, a bit too loud, so I want perfect restoration.
I’ve tried shutdown and restart after not using any audio player, I get the same issue, I assume the issues lies in the sound system configuration.
I believe the full Endeavour installation is still stock aside from updating daily.
inxi -A:
[mmmmna@Opti9020 ~]$ inxi -A
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
Sound Server-1: ALSA v: k5.18.16-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.56 running: yes
I believe I have tried a few weeks ago to delete the alsa rc file, but whatever I did, no change in behavior was observed.
Anyone have a suggestion on how to get the audio volume to perfectly store/restore?
