I saw another post dealing with this, but they only had the issue with a single package. I have this error for more packages than my terminal will list out for me and I don’t know how to handle that. All the ones listed out are prefaced with “qt6-declarative:” and then various files are listed. Do I have to fix every one of them one by one? Or is there a different issue here?
have you updated the mirrors lately??
can you share the pacman log showing this?
cat /var/log/pacman.log | grep "2024-11"
It is necessary to show the actual errors if you you want any assistance.
Isn’t that what the “y” in -Syu does?
[2024-11-07T13:21:54-0600] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file ‘/efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd-fallback’ done ***
[2024-11-07T13:21:54-0600] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd 6.11.6-arch1-1
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
grep: (standard input): binary file matches
Sorry, I’m not used to interacting in the forums, I usually just lurk when I have issues.
show us the whole thing for the date in question. this tells me nothing
start with the line that is similar to this one with the date in question
[2024-11-10T12:55:14-0500] [PACMAN] Running 'pacman --sync -y -u --'
from memory this refreshes the mirror list but doesn’t rerate the mirrors you need to re rate your mirrors by using either rate-mirrors or reflector. The easiest way is to use the Welcome app and run the update mirrors for both arch and endeavourOS
cat /var/log/pacman.log | grep “2024-11”
[2024-11-07T12:45:44-0600] [PACMAN] Running 'pacman -r /tmp/calamares-root-6dgel_t0 -Sy --noconfirm base base-devel btrfs-progs cryptsetup device-mapper diffutils dosfstools dracut e2fsprogs efibootmgr eos-hooks endeavouros-keyring endeavouros-mirrorlist exfatprogs f2fs-tools iptables-nft inetutils jfsutils less linux linux-firmware linux-headers logrotate lsb-release lvm2 man-db man-pages mdadm nano netctl ntfs-3g perl python reiserfsprogs s-nail sudo sysfsutils systemd-sysvcompat texinfo usbutils which xfsprogs xterm'
[2024-11-07T12:45:44-0600] [PACMAN] synchronizing package lists
[2024-11-07T12:47:03-0600] [ALPM] transaction started
[2024-11-07T12:47:03-0600] [ALPM] installed iana-etc (20241016-1)
[2024-11-07T12:47:03-0600] [ALPM] warning: /tmp/calamares-root-6dgel_t0/etc/resolv.conf installed as /tmp/calamares-root-6dgel_t0/etc/resolv.conf.pacnew
[2024-11-07T12:47:03-0600] [ALPM] warning: directory permissions differ on /tmp/calamares-root-6dgel_t0/run/, filesystem: 1777 package: 755
[2024-11-07T12:47:03-0600] [ALPM] installed filesystem (2024.04.07-1)
[2024-11-07T12:47:03-0600] [ALPM] installed linux-api-headers (6.10-1)
[2024-11-07T12:47:03-0600] [ALPM] installed tzdata (2024b-2)
[2024-11-07T12:47:03-0600] [ALPM] installed glibc (2.40+r16+gaa533d58ff-2)
[2024-11-07T12:47:03-0600] [ALPM] installed gcc-libs (14.2.1+r134+gab884fffe3fc-1)
[2024-11-07T12:47:04-0600] [ALPM] installed ncurses (6.5-3)
[2024-11-07T12:47:04-0600] [ALPM] installed readline (8.2.013-1)
[2024-11-07T12:47:04-0600] [ALPM] installed bash (5.2.037-1)
[2024-11-07T12:47:04-0600] [ALPM] installed acl (2.3.2-1)
[2024-11-07T12:47:04-0600] [ALPM] installed attr (2.5.2-1)
[2024-11-07T12:47:04-0600] [ALPM] installed gmp (6.3.0-2)
[2024-11-07T12:47:04-0600] [ALPM] installed zlib (1:1.3.1-2)
[2024-11-07T12:47:04-0600] [ALPM] installed sqlite (3.46.1-1)
[2024-11-07T12:47:04-0600] [ALPM] installed util-linux-libs (2.40.2-1)
[2024-11-07T12:47:04-0600] [ALPM] installed e2fsprogs (1.47.1-4)
[2024-11-07T12:47:04-0600] [ALPM] installed keyutils (1.6.3-3)
[2024-11-07T12:47:04-0600] [ALPM] installed gdbm (1.24-1)
[2024-11-07T12:47:04-0600] [ALPM] installed openssl (3.4.0-1)
[2024-11-07T12:47:04-0600] [ALPM] installed libsasl (2.1.28-5)
[2024-11-07T12:47:04-0600] [ALPM] installed libldap (2.6.8-2)
[2024-11-07T12:47:04-0600] [ALPM] installed libevent (2.1.12-4)
[2024-11-07T12:47:04-0600] [ALPM] installed libverto (0.3.2-5)
[2024-11-07T12:47:04-0600] [ALPM] installed lmdb (0.9.33-1)
[2024-11-07T12:47:04-0600] [ALPM] installed krb5 (1.21.3-1)
[2024-11-07T12:47:04-0600] [ALPM] installed libtirpc (1.3.6-1)
[2024-11-07T12:47:04-0600] [ALPM] installed pambase (20230918-2)
[2024-11-07T12:47:04-0600] [ALPM] installed libcap-ng (0.8.5-2)
[2024-11-07T12:47:04-0600] [ALPM] installed audit (4.0.2-2)
[2024-11-07T12:47:04-0600] [ALPM] installed libxcrypt (4.4.36-2)
[2024-11-07T12:47:04-0600] [ALPM] installed libnsl (2.0.1-1)
[2024-11-07T12:47:04-0600] [ALPM] installed libgpg-error (1.50-1)
[2024-11-07T12:47:04-0600] [ALPM] installed libgcrypt (1.11.0-2)
[2024-11-07T12:47:04-0600] [ALPM] installed lz4 (1:1.10.0-2)
[2024-11-07T12:47:04-0600] [ALPM] installed xz (5.6.3-1)
[2024-11-07T12:47:04-0600] [ALPM] installed zstd (1.5.6-1)
[2024-11-07T12:47:05-0600] [ALPM] installed systemd-libs (256.7-1)
[2024-11-07T12:47:05-0600] [ALPM] installed pam (1.6.1-3)
[2024-11-07T12:47:05-0600] [ALPM] installed libcap (2.71-1)
[2024-11-07T12:47:05-0600] [ALPM] installed coreutils (9.5-2)
[2024-11-07T12:47:05-0600] [ALPM] installed bzip2 (1.0.8-6)
[2024-11-07T12:47:05-0600] [ALPM] installed libseccomp (2.5.5-3)
[2024-11-07T12:47:05-0600] [ALPM] installed file (5.45-1)
[2024-11-07T12:47:05-0600] [ALPM] installed findutils (4.10.0-2)
[2024-11-07T12:47:05-0600] [ALPM] installed mpfr (4.2.1-4)
[2024-11-07T12:47:05-0600] [ALPM] installed gawk (5.3.1-1)
[2024-11-07T12:47:05-0600] [ALPM] installed pcre2 (10.44-1)
[2024-11-07T12:47:05-0600] [ALPM] installed grep (3.11-1)
[2024-11-07T12:47:05-0600] [ALPM] installed procps-ng (4.0.4-3)
[2024-11-07T12:47:05-0600] [ALPM] installed sed (4.9-3)
[2024-11-07T12:47:05-0600] [ALPM] installed tar (1.35-2)
[2024-11-07T12:47:05-0600] [ALPM] installed libunistring (1.2-1)
[2024-11-07T12:47:05-0600] [ALPM] installed icu (75.1-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libxml2 (2.13.4-1)
[2024-11-07T12:47:05-0600] [ALPM] installed gettext (0.22.5-2)
[2024-11-07T12:47:05-0600] [ALPM] installed hwdata (0.389-1)
[2024-11-07T12:47:05-0600] [ALPM] installed kmod (33-3)
[2024-11-07T12:47:05-0600] [ALPM] installed pciutils (3.13.0-2)
[2024-11-07T12:47:05-0600] [ALPM] installed psmisc (23.7-1)
[2024-11-07T12:47:05-0600] [ALPM] installed shadow (4.16.0-1)
[2024-11-07T12:47:05-0600] [ALPM] installed util-linux (2.40.2-1)
[2024-11-07T12:47:05-0600] [ALPM] installed gzip (1.13-4)
[2024-11-07T12:47:05-0600] [ALPM] installed licenses (20240728-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libtasn1 (4.19.0-2)
[2024-11-07T12:47:05-0600] [ALPM] installed libffi (3.4.6-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libp11-kit (0.25.5-1)
[2024-11-07T12:47:05-0600] [ALPM] installed p11-kit (0.25.5-1)
[2024-11-07T12:47:05-0600] [ALPM] installed ca-certificates-utils (20240618-1)
[2024-11-07T12:47:05-0600] [ALPM] installed ca-certificates-mozilla (3.106-1)
[2024-11-07T12:47:05-0600] [ALPM] installed ca-certificates (20240618-1)
[2024-11-07T12:47:05-0600] [ALPM] installed brotli (1.1.0-2)
[2024-11-07T12:47:05-0600] [ALPM] installed libidn2 (2.3.7-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libnghttp2 (1.64.0-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libnghttp3 (1.6.0-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libpsl (0.21.5-2)
[2024-11-07T12:47:05-0600] [ALPM] installed libssh2 (1.11.0-1)
[2024-11-07T12:47:05-0600] [ALPM] installed curl (8.11.0-2)
[2024-11-07T12:47:05-0600] [ALPM] installed nettle (3.10-1)
[2024-11-07T12:47:05-0600] [ALPM] installed gnutls (3.8.8-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libksba (1.6.7-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libusb (1.0.27-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libassuan (3.0.0-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libsysprof-capture (47.1-1)
[2024-11-07T12:47:05-0600] [ALPM] installed glib2 (2.82.2-1)
[2024-11-07T12:47:05-0600] [ALPM] installed json-c (0.18-1)
[2024-11-07T12:47:05-0600] [ALPM] installed tpm2-tss (4.1.3-1)
[2024-11-07T12:47:05-0600] [ALPM] installed libsecret (0.21.4-1)
[2024-11-07T12:47:05-0600] [ALPM] installed pinentry (1.3.1-5)
[2024-11-07T12:47:05-0600] [ALPM] installed npth (1.7-1)
[2024-11-07T12:47:06-0600] [ALPM] installed gnupg (2.4.6-1)
[2024-11-07T12:47:06-0600] [ALPM] installed gpgme (1.24.0-1)
[2024-11-07T12:47:06-0600] [ALPM] installed libarchive (3.7.7-1)
[2024-11-07T12:47:06-0600] [ALPM] warning: /tmp/calamares-root-6dgel_t0/etc/pacman.d/mirrorlist installed as /tmp/calamares-root-6dgel_t0/etc/pacman.d/mirrorlist.pacnew
[2024-11-07T12:47:06-0600] [ALPM] installed pacman-mirrorlist (20240717-1)
[2024-11-07T12:47:06-0600] [ALPM] installed device-mapper (2.03.28-1)
[2024-11-07T12:47:06-0600] [ALPM] installed popt (1.19-2)
[2024-11-07T12:47:06-0600] [ALPM] installed argon2 (20190702-6)
[2024-11-07T12:47:06-0600] [ALPM] installed cryptsetup (2.7.5-1)
[2024-11-07T12:47:06-0600] [ALPM] installed expat (2.6.3-2)
[2024-11-07T12:47:06-0600] [ALPM] installed dbus (1.14.10-2)
[2024-11-07T12:47:06-0600] [ALPM] installed dbus-broker (36-4)
[2024-11-07T12:47:06-0600] [ALPM] installed dbus-broker-units (36-4)
[2024-11-07T12:47:06-0600] [ALPM] installed dbus-units (36-4)
[2024-11-07T12:47:06-0600] [ALPM] installed kbd (2.6.4-3)
[2024-11-07T12:47:06-0600] [ALPM] installed libelf (0.192-2)
[2024-11-07T12:47:06-0600] [ALPM] installed systemd (256.7-1)
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Initializing machine ID from random generator.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'sys' with GID 3.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'mem' with GID 8.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'ftp' with GID 11.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'mail' with GID 12.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'log' with GID 19.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'smmsp' with GID 25.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'proc' with GID 26.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'games' with GID 50.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'lock' with GID 54.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'network' with GID 90.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'floppy' with GID 94.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'scanner' with GID 96.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'power' with GID 98.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'nobody' with GID 65534.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'adm' with GID 999.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'wheel' with GID 998.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'utmp' with GID 997.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'audio' with GID 996.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'disk' with GID 995.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'input' with GID 994.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'kmem' with GID 993.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'kvm' with GID 992.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'lp' with GID 991.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'optical' with GID 990.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'render' with GID 989.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'sgx' with GID 988.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'storage' with GID 987.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'tty' with GID 5.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'uucp' with GID 986.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'video' with GID 985.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'users' with GID 984.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'groups' with GID 983.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-journal' with GID 982.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'rfkill' with GID 981.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'bin' with GID 1.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'bin' (n/a) with UID 1 and GID 1.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'daemon' with GID 2.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'daemon' (n/a) with UID 2 and GID 2.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'mail' (n/a) with UID 8 and GID 12.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'ftp' (n/a) with UID 14 and GID 11.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'http' with GID 33.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'http' (n/a) with UID 33 and GID 33.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'nobody' (Kernel Overflow User) with UID 65534 and GID 65534.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'dbus' with GID 81.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'dbus' (System Message Bus) with UID 81 and GID 81.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-coredump' with GID 980.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-coredump' (systemd Core Dumper) with UID 980 and GID 980.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-network' with GID 979.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-network' (systemd Network Management) with UID 979 and GID 979.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-oom' with GID 978.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-oom' (systemd Userspace OOM Killer) with UID 978 and GID 978.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-journal-remote' with GID 977.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-journal-remote' (systemd Journal Remote) with UID 977 and GID 977.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-resolve' with GID 976.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-resolve' (systemd Resolver) with UID 976 and GID 976.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'systemd-timesync' with GID 975.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'systemd-timesync' (systemd Time Synchronization) with UID 975 and GID 975.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'tss' with GID 974.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'tss' (tss user for tpm2) with UID 974 and GID 974.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating group 'uuidd' with GID 68.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Creating user 'uuidd' (n/a) with UID 68 and GID 68.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/getty.target.wants/getty@tty1.service' → '/usr/lib/systemd/system/getty@.service'.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/multi-user.target.wants/remote-fs.target' → '/usr/lib/systemd/system/remote-fs.target'.
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/sockets.target.wants/systemd-userdbd.socket' → '/usr/lib/systemd/system/systemd-userdbd.socket'.
[2024-11-07T12:47:06-0600] [ALPM] installed pacman (7.0.0.r3.g7736133-1)
[2024-11-07T12:47:06-0600] [ALPM] installed archlinux-keyring (20241015-1)
[2024-11-07T12:47:06-0600] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2024-11-07T12:47:09-0600] [ALPM-SCRIPTLET] ==> Updating trust database...
[2024-11-07T12:47:09-0600] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2024-11-18
[2024-11-07T12:47:09-0600] [ALPM] installed systemd-sysvcompat (256.7-1)
[2024-11-07T12:47:09-0600] [ALPM] installed iputils (20240905-1)
[2024-11-07T12:47:09-0600] [ALPM] installed libmnl (1.0.5-2)
[2024-11-07T12:47:09-0600] [ALPM] installed libnftnl (1.2.8-1)
[2024-11-07T12:47:09-0600] [ALPM] installed libnl (3.11.0-1)
[2024-11-07T12:47:09-0600] [ALPM] installed libpcap (1.10.5-2)
[2024-11-07T12:47:09-0600] [ALPM] installed libnfnetlink (1.0.2-2)
[2024-11-07T12:47:09-0600] [ALPM] installed libnetfilter_conntrack (1.0.9-2)
[2024-11-07T12:47:09-0600] [ALPM] installed jansson (2.14-4)
[2024-11-07T12:47:09-0600] [ALPM] installed nftables (1:1.1.1-1)
[2024-11-07T12:47:09-0600] [ALPM] installed iptables-nft (1:1.8.10-2)
[2024-11-07T12:47:09-0600] [ALPM] installed libbpf (1.4.3-1)
[2024-11-07T12:47:09-0600] [ALPM] installed iproute2 (6.11.0-1)
[2024-11-07T12:47:09-0600] [ALPM] installed base (3-2)
[2024-11-07T12:47:09-0600] [ALPM] installed m4 (1.4.19-3)
[2024-11-07T12:47:09-0600] [ALPM] installed diffutils (3.10-1)
[2024-11-07T12:47:09-0600] [ALPM] installed db5.3 (5.3.28-5)
[2024-11-07T12:47:09-0600] [ALPM] installed perl (5.40.0-1)
[2024-11-07T12:47:09-0600] [ALPM] installed autoconf (2.72-1)
[2024-11-07T12:47:09-0600] [ALPM] installed automake (1.17-1)
[2024-11-07T12:47:09-0600] [ALPM] installed binutils (2.43+r4+g7999dae6961-1)
[2024-11-07T12:47:09-0600] [ALPM] installed bison (3.8.2-8)
[2024-11-07T12:47:09-0600] [ALPM] installed xxhash (0.8.2-1)
[2024-11-07T12:47:09-0600] [ALPM] installed debugedit (5.1-1)
[2024-11-07T12:47:09-0600] [ALPM] installed fakeroot (1.36-1)
[2024-11-07T12:47:10-0600] [ALPM] installed flex (2.6.4-5)
[2024-11-07T12:47:10-0600] [ALPM] installed libmpc (1.3.1-2)
[2024-11-07T12:47:10-0600] [ALPM] installed libisl (0.27-1)
[2024-11-07T12:47:10-0600] [ALPM] installed gcc (14.2.1+r134+gab884fffe3fc-1)
[2024-11-07T12:47:10-0600] [ALPM] installed groff (1.23.0-7)
[2024-11-07T12:47:10-0600] [ALPM] installed libtool (2.5.3-1)
[2024-11-07T12:47:10-0600] [ALPM] installed gc (8.2.8-2)
[2024-11-07T12:47:10-0600] [ALPM] installed guile (3.0.10-1)
[2024-11-07T12:47:10-0600] [ALPM] installed make (4.4.1-2)
[2024-11-07T12:47:10-0600] [ALPM] installed patch (2.7.6-10)
[2024-11-07T12:47:10-0600] [ALPM] installed pkgconf (2.1.1-1)
[2024-11-07T12:47:10-0600] [ALPM] installed sudo (1.9.16-1)
[2024-11-07T12:47:10-0600] [ALPM] installed texinfo (7.1.1-1)
[2024-11-07T12:47:10-0600] [ALPM] installed which (2.21-6)
[2024-11-07T12:47:10-0600] [ALPM] installed base-devel (1-2)
[2024-11-07T12:47:10-0600] [ALPM] installed lzo (2.10-5)
[2024-11-07T12:47:10-0600] [ALPM] installed btrfs-progs (6.11-1)
[2024-11-07T12:47:10-0600] [ALPM] installed dosfstools (4.2-5)
[2024-11-07T12:47:10-0600] [ALPM] installed cpio (2.15-2)
[2024-11-07T12:47:11-0600] [ALPM] installed dracut (105-1)
[2024-11-07T12:47:11-0600] [ALPM] installed efivar (39-1)
[2024-11-07T12:47:11-0600] [ALPM] installed efibootmgr (18-3)
[2024-11-07T12:47:11-0600] [ALPM] installed eos-hooks (1.16-1)
[2024-11-07T12:47:11-0600] [ALPM] installed endeavouros-keyring (20231222-1)
[2024-11-07T12:47:11-0600] [ALPM-SCRIPTLET] ==> Appending keys from endeavouros.gpg...
[2024-11-07T12:47:11-0600] [ALPM-SCRIPTLET] ==> Updating trust database...
[2024-11-07T12:47:11-0600] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2024-11-18
[2024-11-07T12:47:11-0600] [ALPM] warning: /tmp/calamares-root-6dgel_t0/etc/pacman.d/endeavouros-mirrorlist installed as /tmp/calamares-root-6dgel_t0/etc/pacman.d/endeavouros-mirrorlist.pacnew
[2024-11-07T12:47:11-0600] [ALPM] installed endeavouros-mirrorlist (24.10-1)
[2024-11-07T12:47:11-0600] [ALPM] installed exfatprogs (1.2.5-1)
[2024-11-07T12:47:11-0600] [ALPM] installed f2fs-tools (1.16.0-3)
[2024-11-07T12:47:11-0600] [ALPM] installed inetutils (2.5-1)
[2024-11-07T12:47:11-0600] [ALPM] installed jfsutils (1.1.15-9)
[2024-11-07T12:47:11-0600] [ALPM] installed less (1:661-1)
[2024-11-07T12:47:12-0600] [ALPM] installed linux (6.11.6.arch1-1)
[2024-11-07T12:47:12-0600] [ALPM] installed linux-firmware-whence (20241017.22a6c7dc-1)
[2024-11-07T12:47:12-0600] [ALPM] installed linux-firmware (20241017.22a6c7dc-1)
[2024-11-07T12:47:12-0600] [ALPM] installed pahole (1:1.27-2)
[2024-11-07T12:47:14-0600] [ALPM] installed linux-headers (6.11.6.arch1-1)
[2024-11-07T12:47:14-0600] [ALPM] installed logrotate (3.22.0-1)
[2024-11-07T12:47:14-0600] [ALPM] installed lsb-release (2.0.r53.a86f885-2)
[2024-11-07T12:47:14-0600] [ALPM] installed thin-provisioning-tools (1.1.0-1)
[2024-11-07T12:47:14-0600] [ALPM] installed libaio (0.3.113-3)
[2024-11-07T12:47:14-0600] [ALPM] installed lvm2 (2.03.28-1)
[2024-11-07T12:47:14-0600] [ALPM] installed libpipeline (1.5.8-1)
[2024-11-07T12:47:14-0600] [ALPM] installed man-db (2.13.0-1)
[2024-11-07T12:47:15-0600] [ALPM] installed man-pages (6.9.1-1)
[2024-11-07T12:47:15-0600] [ALPM] installed mdadm (4.3-2)
[2024-11-07T12:47:15-0600] [ALPM] installed nano (8.2-1)
[2024-11-07T12:47:15-0600] [ALPM] installed systemd-resolvconf (256.7-1)
[2024-11-07T12:47:15-0600] [ALPM] installed netctl (1.29-2)
[2024-11-07T12:47:15-0600] [ALPM] installed fuse-common (3.16.2-1)
[2024-11-07T12:47:15-0600] [ALPM] installed fuse2 (2.9.9-5)
[2024-11-07T12:47:15-0600] [ALPM] installed ntfs-3g (2022.10.3-1)
[2024-11-07T12:47:15-0600] [ALPM] installed mpdecimal (4.0.0-2)
[2024-11-07T12:47:15-0600] [ALPM] installed python (3.12.7-1)
[2024-11-07T12:47:15-0600] [ALPM] installed reiserfsprogs (3.6.27-5)
[2024-11-07T12:47:15-0600] [ALPM] installed s-nail (14.9.24-2)
[2024-11-07T12:47:15-0600] [ALPM] installed sysfsutils (2.1.1-2)
[2024-11-07T12:47:15-0600] [ALPM] installed usbutils (018-1)
[2024-11-07T12:47:15-0600] [ALPM] installed libedit (20240517_3.1-1)
[2024-11-07T12:47:15-0600] [ALPM] installed libinih (58-1)
[2024-11-07T12:47:15-0600] [ALPM] installed liburcu (0.14.1-1)
[2024-11-07T12:47:15-0600] [ALPM] installed xfsprogs (6.11.0-1)
[2024-11-07T12:47:15-0600] [ALPM] installed libpng (1.6.44-1)
[2024-11-07T12:47:15-0600] [ALPM] installed graphite (1:1.3.14-4)
[2024-11-07T12:47:15-0600] [ALPM] installed harfbuzz (10.0.1-1)
[2024-11-07T12:47:15-0600] [ALPM] installed freetype2 (2.13.3-1)
[2024-11-07T12:47:15-0600] [ALPM] installed fontconfig (2:2.15.0-2)
[2024-11-07T12:47:15-0600] [ALPM-SCRIPTLET] Creating fontconfig configuration...
[2024-11-07T12:47:15-0600] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2024-11-07T12:47:15-0600] [ALPM] installed xcb-proto (1.17.0-2)
[2024-11-07T12:47:15-0600] [ALPM] installed xorgproto (2024.1-2)
[2024-11-07T12:47:15-0600] [ALPM] installed libxdmcp (1.1.5-1)
[2024-11-07T12:47:15-0600] [ALPM] installed libxau (1.0.11-3)
[2024-11-07T12:47:16-0600] [ALPM] installed libxcb (1.17.0-1)
[2024-11-07T12:47:16-0600] [ALPM] installed libx11 (1.8.10-1)
[2024-11-07T12:47:16-0600] [ALPM] installed libxrender (0.9.11-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libxft (2.3.8-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libxext (1.3.6-1)
[2024-11-07T12:47:16-0600] [ALPM] installed libice (1.1.1-3)
[2024-11-07T12:47:16-0600] [ALPM] installed libsm (1.2.4-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libxt (1.3.0-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libxmu (1.2.1-1)
[2024-11-07T12:47:16-0600] [ALPM] installed libxpm (3.5.17-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libxaw (1.0.16-1)
[2024-11-07T12:47:16-0600] [ALPM] installed xorg-fonts-encodings (1.1.0-1)
[2024-11-07T12:47:16-0600] [ALPM] installed libfontenc (1.1.8-1)
[2024-11-07T12:47:16-0600] [ALPM] installed luit (20240102-2)
[2024-11-07T12:47:16-0600] [ALPM] installed xbitmaps (1.1.3-2)
[2024-11-07T12:47:16-0600] [ALPM] installed libutempter (1.2.1-4)
[2024-11-07T12:47:16-0600] [ALPM] installed libxkbfile (1.1.3-1)
[2024-11-07T12:47:16-0600] [ALPM] installed xterm (395-1)
[2024-11-07T12:47:16-0600] [ALPM] transaction completed
[2024-11-07T12:47:16-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2024-11-07T12:47:16-0600] [ALPM-SCRIPTLET] Creating group 'alpm' with GID 973.
[2024-11-07T12:47:17-0600] [ALPM-SCRIPTLET] Creating user 'alpm' (Arch Linux Package Management) with UID 973 and GID 973.
[2024-11-07T12:47:17-0600] [ALPM-SCRIPTLET] Creating group '_talkd' with GID 972.
[2024-11-07T12:47:17-0600] [ALPM-SCRIPTLET] Creating user '_talkd' (User for legacy talkd server) with UID 972 and GID 972.
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-catalog.hook'...
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-11-07T12:47:17-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-hwdb.hook'...
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-sysctl.hook'...
[2024-11-07T12:47:17-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-11-07T12:47:18-0600] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-11-07T12:47:18-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:47:18-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:47:18-0600] [ALPM] running '40-fontconfig-config.hook'...
[2024-11-07T12:47:18-0600] [ALPM] running '40-update-ca-trust.hook'...
[2024-11-07T12:47:19-0600] [ALPM] running '60-depmod.hook'...
[2024-11-07T12:47:21-0600] [ALPM] running 'dbus-reload.hook'...
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:47:21-0600] [ALPM] running 'detect-old-perl-modules.hook'...
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] perl: warning: Setting locale failed.
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] perl: warning: Please check that your locale settings:
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LANGUAGE = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_ALL = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_CTYPE = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_NUMERIC = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_COLLATE = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_TIME = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_MESSAGES = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_MONETARY = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_ADDRESS = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_IDENTIFICATION = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_MEASUREMENT = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_PAPER = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_TELEPHONE = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LC_NAME = (unset),
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] LANG = "en_US.UTF-8"
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] are supported and installed on your system.
[2024-11-07T12:47:21-0600] [ALPM-SCRIPTLET] perl: warning: Falling back to the standard locale ("C").
[2024-11-07T12:47:21-0600] [ALPM] running 'eos-hooks.hook'...
[2024-11-07T12:47:21-0600] [ALPM] running 'eos-lsb-release.hook'...
[2024-11-07T12:47:21-0600] [ALPM] running 'eos-os-release.hook'...
[2024-11-07T12:47:21-0600] [ALPM] running 'fontconfig.hook'...
[2024-11-07T12:47:21-0600] [ALPM] running 'texinfo-install.hook'...
[2024-11-07T12:47:25-0600] [PACMAN] Running 'pacman -Sy'
[2024-11-07T12:47:25-0600] [PACMAN] synchronizing package lists
[2024-11-07T12:47:26-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout libwnck3 mesa-utils xf86-input-libinput xorg-xdpyinfo xorg-server xorg-xinit xorg-xinput xorg-xkill xorg-xrandr xf86-video-amdgpu xf86-video-ati b43-fwcutter broadcom-wl-dkms dnsmasq dnsutils ethtool iwd modemmanager networkmanager networkmanager-openconnect networkmanager-openvpn nss-mdns openssh usb_modeswitch wpa_supplicant xl2tpd downgrade pacman-contrib pkgfile rebuild-detector reflector yay accountsservice bash-completion bluez bluez-utils ffmpegthumbnailer gst-libav gst-plugin-pipewire gst-plugins-bad gst-plugins-ugly libdvdcss libgsf libopenraw plocate poppler-glib xdg-user-dirs xdg-utils efitools haveged nfs-utils nilfs-utils ntp smartmontools unrar unzip xz cantarell-fonts freetype2 noto-fonts noto-fonts-emoji noto-fonts-cjk noto-fonts-extra ttf-bitstream-vera ttf-dejavu ttf-liberation ttf-opensans alsa-firmware alsa-plugins alsa-utils pavucontrol pipewire-pulse wireplumber pipewire-alsa pipewire-jack rtkit dmidecode dmraid hdparm hwdetect lsscsi mtools sg3_utils sof-firmware power-profiles-daemon upower endeavouros-theming eos-apps-info eos-log-tool eos-packagelist eos-quickstart eos-rankmirrors reflector-simple welcome duf findutils fsarchiver git glances hwinfo inxi meld nano-syntax-highlighting pv python-defusedxml python-packaging rsync tldr sed vi wget firewalld python-pyqt5 python-capng adwaita-icon-theme loupe evince file-roller gdm gnome-calculator gnome-clocks gnome-console gnome-control-center gnome-disk-utility gnome-keyring gnome-nettool gnome-power-manager gnome-screenshot gnome-shell gnome-system-monitor gnome-terminal gnome-text-editor gnome-themes-extra gnome-tweaks gnome-usage gnome-weather gvfs gvfs-afc gvfs-gphoto2 gvfs-mtp gvfs-nfs gvfs-smb nautilus sushi totem xdg-desktop-portal-gnome xdg-desktop-portal xdg-user-dirs-gtk arc-gtk-theme-eos eos-settings-gnome eos-qogir-icons'
[2024-11-07T12:49:34-0600] [ALPM] transaction started
[2024-11-07T12:49:34-0600] [ALPM] installed dconf (0.40.0-3)
[2024-11-07T12:49:34-0600] [ALPM] installed gsettings-system-schemas (47.1-1)
[2024-11-07T12:49:34-0600] [ALPM] installed adobe-source-code-pro-fonts (2.042u+1.062i+1.026vf-2)
[2024-11-07T12:49:34-0600] [ALPM] installed cantarell-fonts (1:0.303.1-2)
[2024-11-07T12:49:34-0600] [ALPM] installed gsettings-desktop-schemas (47.1-1)
[2024-11-07T12:49:34-0600] [ALPM] installed libxfixes (6.0.1-2)
[2024-11-07T12:49:34-0600] [ALPM] installed libxi (1.8.2-1)
[2024-11-07T12:49:34-0600] [ALPM] installed libxtst (1.2.5-1)
[2024-11-07T12:49:34-0600] [ALPM] installed xorg-xprop (1.2.7-1)
[2024-11-07T12:49:34-0600] [ALPM] installed at-spi2-core (2.54.0-2)
[2024-11-07T12:49:34-0600] [ALPM] installed pixman (0.44.0-1)
[2024-11-07T12:49:34-0600] [ALPM] installed cairo (1.18.2-2)
[2024-11-07T12:49:34-0600] [ALPM] installed libjpeg-turbo (3.0.4-1)
[2024-11-07T12:49:34-0600] [ALPM] installed jbigkit (2.1-8)
[2024-11-07T12:49:34-0600] [ALPM] installed libtiff (4.7.0-1)
[2024-11-07T12:49:34-0600] [ALPM] installed shared-mime-info (2.4-1)
[2024-11-07T12:49:34-0600] [ALPM] installed gdk-pixbuf2 (2.42.12-2)
[2024-11-07T12:49:34-0600] [ALPM] installed hicolor-icon-theme (0.18-1)
[2024-11-07T12:49:35-0600] [ALPM] installed adwaita-icon-theme-legacy (46.2-3)
[2024-11-07T12:49:35-0600] [ALPM] installed adwaita-cursors (47.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed adwaita-icon-theme (47.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed desktop-file-utils (0.28-1)
[2024-11-07T12:49:35-0600] [ALPM] installed fribidi (1.0.16-1)
[2024-11-07T12:49:35-0600] [ALPM] installed iso-codes (4.17.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libcloudproviders (0.3.6-1)
[2024-11-07T12:49:35-0600] [ALPM] installed lcms2 (2.16-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libcolord (1.4.7-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libdaemon (0.14-6)
[2024-11-07T12:49:35-0600] [ALPM] installed avahi (1:0.8+r194+g3f79789-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libcups (2:2.4.11-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libpciaccess (0.18.1-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libdrm (2.4.123-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libxshmfence (1.3.2-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libxxf86vm (1.1.5-2)
[2024-11-07T12:49:35-0600] [ALPM] installed llvm-libs (18.1.8-4)
[2024-11-07T12:49:35-0600] [ALPM] installed lm_sensors (1:3.6.0.r41.g31d1f125-3)
[2024-11-07T12:49:35-0600] [ALPM] installed default-cursors (3-1)
[2024-11-07T12:49:35-0600] [ALPM] installed wayland (1.23.1-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libomxil-bellagio (0.9.3-5)
[2024-11-07T12:49:35-0600] [ALPM] installed mesa (1:24.2.6-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libglvnd (1.7.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libepoxy (1.5.10-3)
[2024-11-07T12:49:35-0600] [ALPM] installed dav1d (1.4.3-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libdatrie (0.2.13-4)
[2024-11-07T12:49:35-0600] [ALPM] installed libthai (0.1.29-3)
[2024-11-07T12:49:35-0600] [ALPM] installed pango (1:1.54.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed librsvg (2:2.59.2-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libxcomposite (0.4.6-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libxcursor (1.2.3-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libxdamage (1.1.6-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libxinerama (1.1.5-2)
[2024-11-07T12:49:35-0600] [ALPM] installed xkeyboard-config (2.43-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libxkbcommon (1.7.0-2)
[2024-11-07T12:49:35-0600] [ALPM] installed libxrandr (1.5.4-1)
[2024-11-07T12:49:35-0600] [ALPM] installed json-glib (1.10.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed duktape (2.7.0-7)
[2024-11-07T12:49:35-0600] [ALPM] installed libproxy (0.5.9-1)
[2024-11-07T12:49:35-0600] [ALPM] installed glib-networking (1:2.80.0-3)
[2024-11-07T12:49:35-0600] [ALPM] installed libsoup3 (3.6.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed libstemmer (2.2.0-2)
[2024-11-07T12:49:35-0600] [ALPM] installed tinysparql (3.8.0-1)
[2024-11-07T12:49:35-0600] [ALPM] installed gtk-update-icon-cache (1:4.16.5-1)
[2024-11-07T12:49:36-0600] [ALPM] installed gtk3 (1:3.24.43-4)
[2024-11-07T12:49:36-0600] [ALPM] installed libxres (1.2.2-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xcb-util (0.4.1-2)
[2024-11-07T12:49:36-0600] [ALPM] installed startup-notification (0.12-8)
[2024-11-07T12:49:36-0600] [ALPM] installed libwnck3 (43.1-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libdecor (0.2.2-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libxkbcommon-x11 (1.7.0-2)
[2024-11-07T12:49:36-0600] [ALPM] installed vulkan-icd-loader (1.3.295-1)
[2024-11-07T12:49:36-0600] [ALPM] installed mesa-utils (9.0.0-5)
[2024-11-07T12:49:36-0600] [ALPM] installed mtdev (1.1.7-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libevdev (1.13.3-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libgudev (238-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libwacom (2.13.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libinput (1.26.2-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xf86-input-libinput (1.5.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xdpyinfo (1.3.4-2)
[2024-11-07T12:49:36-0600] [ALPM] installed libxfont2 (2.0.7-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xkbcomp (1.4.7-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-setxkbmap (1.3.4-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-server-common (21.1.14-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libunwind (1.8.1-3)
[2024-11-07T12:49:36-0600] [ALPM] installed libxcvt (0.1.2-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-server (21.1.14-1)
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] >>> xorg-server has now the ability to run without root rights with
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] the help of systemd-logind. xserver will fail to run if not launched
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] from the same virtual terminal as was used to log in.
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] Without root rights, log files will be in ~/.local/share/xorg/ directory.
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] Old behavior can be restored through Xorg.wrap config file.
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] See Xorg.wrap man page (man xorg.wrap).
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xauth (1.1.3-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xrdb (1.2.2-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xmodmap (1.0.11-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xinit (1.4.2-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xrandr (1.5.2-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xinput (1.6.4-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xkill (1.0.6-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xf86-video-amdgpu (23.0.0-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xf86-video-ati (1:22.0.0-2)
[2024-11-07T12:49:36-0600] [ALPM] installed b43-fwcutter (019-5)
[2024-11-07T12:49:36-0600] [ALPM] installed dkms (3.1.1-2)
[2024-11-07T12:49:36-0600] [ALPM] installed broadcom-wl-dkms (6.30.223.271-37)
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] Unload and load kernel modules (wl is provided by broadcom-wl-dkms):
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] rmmod b43 b43legacy bcm43xx bcma brcm80211 brcmfmac brcmsmac ssb tg3 wl
[2024-11-07T12:49:36-0600] [ALPM-SCRIPTLET] modprobe wl
[2024-11-07T12:49:36-0600] [ALPM] installed dnsmasq (2.90-1)
[2024-11-07T12:49:36-0600] [ALPM] installed dnssec-anchors (20190629-4)
[2024-11-07T12:49:36-0600] [ALPM] installed libmaxminddb (1.11.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libuv (1.49.2-1)
[2024-11-07T12:49:36-0600] [ALPM] installed jemalloc (1:5.3.0-4)
[2024-11-07T12:49:36-0600] [ALPM] installed bind (9.20.3-1)
[2024-11-07T12:49:36-0600] [ALPM] installed ethtool (1:6.9-1)
[2024-11-07T12:49:36-0600] [ALPM] installed ell (0.69-1)
[2024-11-07T12:49:36-0600] [ALPM] installed iwd (3.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libmbim (1.30.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libqrtr-glib (1.2.2-3)
[2024-11-07T12:49:36-0600] [ALPM] installed libqmi (1.34.0-2)
[2024-11-07T12:49:36-0600] [ALPM] installed mobile-broadband-provider-info (20240407-1)
[2024-11-07T12:49:36-0600] [ALPM] installed polkit (125-1)
[2024-11-07T12:49:36-0600] [ALPM] installed ppp (2.5.1-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libmm-glib (1.22.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed modemmanager (1.22.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libndp (1.9-1)
[2024-11-07T12:49:36-0600] [ALPM] installed gpm (1.20.7.r38.ge82d1a6-6)
[2024-11-07T12:49:36-0600] [ALPM] installed pcre (8.45-4)
[2024-11-07T12:49:36-0600] [ALPM] installed slang (2.3.3-3)
[2024-11-07T12:49:36-0600] [ALPM] installed libnewt (0.52.24-2)
[2024-11-07T12:49:36-0600] [ALPM] installed nspr (4.36-1)
[2024-11-07T12:49:36-0600] [ALPM] installed nss (3.106-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libnm (1.50.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libsodium (1.0.20-1)
[2024-11-07T12:49:36-0600] [ALPM] installed libpgm (5.3.128-3)
[2024-11-07T12:49:36-0600] [ALPM] installed zeromq (4.3.5-2)
[2024-11-07T12:49:36-0600] [ALPM] installed libteam (1.32-2)
[2024-11-07T12:49:36-0600] [ALPM] installed pcsclite (2.3.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed wpa_supplicant (2:2.11-2)
[2024-11-07T12:49:36-0600] [ALPM] installed networkmanager (1.50.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed vpnc (1:0.5.3.r539.r239-1)
[2024-11-07T12:49:36-0600] [ALPM] installed stoken (0.92-4)
[2024-11-07T12:49:36-0600] [ALPM] installed libxslt (1.1.42-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xmlsec (1.3.6-1)
[2024-11-07T12:49:36-0600] [ALPM] installed oath-toolkit (2.6.12-1)
[2024-11-07T12:49:36-0600] [ALPM] installed xorg-xset (1.2.5-2)
[2024-11-07T12:49:36-0600] [ALPM] installed xdg-utils (1.2.1-1)
[2024-11-07T12:49:36-0600] [ALPM] installed openconnect (1:9.12-2)
[2024-11-07T12:49:36-0600] [ALPM] installed networkmanager-openconnect (1.2.10-2)
[2024-11-07T12:49:36-0600] [ALPM] installed pkcs11-helper (1.30.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed openvpn (2.6.12-1)
[2024-11-07T12:49:36-0600] [ALPM] installed networkmanager-openvpn (1.12.0-1)
[2024-11-07T12:49:36-0600] [ALPM] installed nss-mdns (0.15.1-2)
[2024-11-07T12:49:36-0600] [ALPM] installed openssh (9.9p1-2)
[2024-11-07T12:49:36-0600] [ALPM] installed tcl (8.6.14-4)
[2024-11-07T12:49:37-0600] [ALPM] installed usb_modeswitch (2.6.1-4)
[2024-11-07T12:49:37-0600] [ALPM] installed xl2tpd (1.3.18-2)
[2024-11-07T12:49:37-0600] [ALPM] installed pacman-contrib (1.10.6-2)
[2024-11-07T12:49:37-0600] [ALPM] installed fzf (0.55.0-1)
[2024-11-07T12:49:37-0600] [ALPM] installed downgrade (11.4.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed pkgfile (22-1)
[2024-11-07T12:49:37-0600] [ALPM-SCRIPTLET] ==> Run 'pkgfile --update' to initialize the database
[2024-11-07T12:49:37-0600] [ALPM] installed parallel (20241022-1)
[2024-11-07T12:49:37-0600] [ALPM] installed pacutils (0.14.0-3)
[2024-11-07T12:49:37-0600] [ALPM] installed rebuild-detector (4.4.4-1)
[2024-11-07T12:49:37-0600] [ALPM] installed reflector (2023-2)
[2024-11-07T12:49:37-0600] [ALPM] installed perl-error (0.17029-7)
[2024-11-07T12:49:37-0600] [ALPM] installed perl-timedate (2.33-7)
[2024-11-07T12:49:37-0600] [ALPM] installed perl-mailtools (2.21-9)
[2024-11-07T12:49:37-0600] [ALPM] installed git (2.47.0-1)
[2024-11-07T12:49:37-0600] [ALPM] installed yay (12.4.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed accountsservice (23.13.9-2)
[2024-11-07T12:49:37-0600] [ALPM] installed bash-completion (2.14.0-2)
[2024-11-07T12:49:37-0600] [ALPM] installed alsa-topology-conf (1.2.5.1-4)
[2024-11-07T12:49:37-0600] [ALPM] installed alsa-ucm-conf (1.2.12-1)
[2024-11-07T12:49:37-0600] [ALPM] installed alsa-lib (1.2.12-1)
[2024-11-07T12:49:37-0600] [ALPM] installed bluez (5.79-1)
[2024-11-07T12:49:37-0600] [ALPM] installed bluez-utils (5.79-1)
[2024-11-07T12:49:37-0600] [ALPM] installed aom (3.10.0-1)
And here’s part 2
[2024-11-07T12:49:37-0600] [ALPM] installed gsm (1.0.22-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libpipewire (1:1.2.6-1)
[2024-11-07T12:49:37-0600] [ALPM] installed pipewire (1:1.2.6-1)
[2024-11-07T12:49:37-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/sockets.target.wants/pipewire.socket' -> '/usr/lib/systemd/user/pipewire.socket'.
[2024-11-07T12:49:37-0600] [ALPM] installed alsa-card-profiles (1:1.2.6-1)
[2024-11-07T12:49:37-0600] [ALPM] installed bluez-libs (5.79-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libfdk-aac (2.0.3-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libfreeaptx (0.1.1-2)
[2024-11-07T12:49:37-0600] [ALPM] installed liblc3 (1.1.1-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libldac (2.0.2.3-2)
[2024-11-07T12:49:37-0600] [ALPM] installed serd (0.32.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed zix (0.4.2-2)
[2024-11-07T12:49:37-0600] [ALPM] installed sord (0.16.16-1)
[2024-11-07T12:49:37-0600] [ALPM] installed lv2 (1.18.10-1)
[2024-11-07T12:49:37-0600] [ALPM] installed sratom (0.6.16-1)
[2024-11-07T12:49:37-0600] [ALPM] installed lilv (0.24.24-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libmysofa (1.3.3-1)
[2024-11-07T12:49:37-0600] [ALPM] installed opus (1.5.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed sbc (2.0-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libogg (1.3.5-2)
[2024-11-07T12:49:37-0600] [ALPM] installed flac (1.4.3-2)
[2024-11-07T12:49:37-0600] [ALPM] installed lame (3.100-5)
[2024-11-07T12:49:37-0600] [ALPM] installed libvorbis (1.3.7-3)
[2024-11-07T12:49:37-0600] [ALPM] installed mpg123 (1.32.9-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libsndfile (1.2.2-2)
[2024-11-07T12:49:37-0600] [ALPM] installed gtest (1.15.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed abseil-cpp (20240722.0-1)
[2024-11-07T12:49:37-0600] [ALPM] installed webrtc-audio-processing-1 (1.3-3)
[2024-11-07T12:49:37-0600] [ALPM] installed pipewire-audio (1:1.2.6-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libwireplumber (0.5.6-1)
[2024-11-07T12:49:37-0600] [ALPM] installed lua (5.4.7-1)
[2024-11-07T12:49:37-0600] [ALPM] installed wireplumber (0.5.6-1)
[2024-11-07T12:49:37-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/pipewire-session-manager.service' -> '/usr/lib/systemd/user/wireplumber.service'.
[2024-11-07T12:49:37-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/pipewire.service.wants/wireplumber.service' -> '/usr/lib/systemd/user/wireplumber.service'.
[2024-11-07T12:49:37-0600] [ALPM] installed pipewire-jack (1:1.2.6-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libunibreak (6.1-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libass (0.17.3-1)
[2024-11-07T12:49:37-0600] [ALPM] installed libraw1394 (2.1.2-4)
[2024-11-07T12:49:37-0600] [ALPM] installed libavc1394 (0.5.4-6)
[2024-11-07T12:49:37-0600] [ALPM] installed libbluray (1.3.4-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libbs2b (3.1.0-9)
[2024-11-07T12:49:37-0600] [ALPM] installed libdvdread (6.1.3-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libdvdnav (6.1.1-2)
[2024-11-07T12:49:37-0600] [ALPM] installed libiec61883 (1.2.0-8)
[2024-11-07T12:49:37-0600] [ALPM] installed giflib (5.2.2-1)
[2024-11-07T12:49:37-0600] [ALPM] installed gperftools (2.16-1)
[2024-11-07T12:49:37-0600] [ALPM] installed highway (1.2.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed imath (3.1.12-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libdeflate (1.22-1)
[2024-11-07T12:49:38-0600] [ALPM] installed openexr (3.2.4-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libjxl (0.11.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libmodplug (0.8.9.0-6)
[2024-11-07T12:49:38-0600] [ALPM] installed libasyncns (1:0.8+r3+g68cd5af-3)
[2024-11-07T12:49:38-0600] [ALPM] installed libpulse (17.0-3)
[2024-11-07T12:49:38-0600] [ALPM] installed portaudio (1:19.7.0-3)
[2024-11-07T12:49:38-0600] [ALPM] installed libopenmpt (0.7.11-1)
[2024-11-07T12:49:38-0600] [ALPM] installed spirv-tools (2024.2-1)
[2024-11-07T12:49:38-0600] [ALPM] installed glslang (14.3.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed shaderc (2024.2-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libdovi (3.3.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libplacebo (7.349.0-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libsoxr (0.1.3-4)
[2024-11-07T12:49:38-0600] [ALPM] installed libssh (0.11.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libtheora (1.1.1-6)
[2024-11-07T12:49:38-0600] [ALPM] installed libva (2.22.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libvdpau (1.5-3)
[2024-11-07T12:49:38-0600] [ALPM] installed libvpx (1.14.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libwebp (1.4.0-3)
[2024-11-07T12:49:38-0600] [ALPM] installed libxv (1.0.12-2)
[2024-11-07T12:49:38-0600] [ALPM] installed ocl-icd (2.3.2-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libvpl (2.13.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed opencore-amr (0.1.6-2)
[2024-11-07T12:49:38-0600] [ALPM] installed openjpeg2 (2.5.2-1)
[2024-11-07T12:49:38-0600] [ALPM] installed rav1e (0.7.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed fftw (3.3.10-7)
[2024-11-07T12:49:38-0600] [ALPM] installed libsamplerate (0.2.2-3)
[2024-11-07T12:49:38-0600] [ALPM] installed rubberband (3.3.0-2)
[2024-11-07T12:49:38-0600] [ALPM] installed hidapi (0.14.0-3)
[2024-11-07T12:49:38-0600] [ALPM] installed sdl2 (2.30.9-1)
[2024-11-07T12:49:38-0600] [ALPM] installed snappy (1.2.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed speexdsp (1.2.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed speex (1.2.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed srt (1.5.3-2)
[2024-11-07T12:49:38-0600] [ALPM] installed svt-av1 (2.2.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed v4l-utils (1.28.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed zimg (3.0.5-1)
[2024-11-07T12:49:38-0600] [ALPM] installed vapoursynth (R70-1)
[2024-11-07T12:49:38-0600] [ALPM] installed vid.stab (1.1.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed vmaf (3.0.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed l-smash (2.14.5-4)
[2024-11-07T12:49:38-0600] [ALPM] installed x264 (3:0.164.r3108.31e19f9-2)
[2024-11-07T12:49:38-0600] [ALPM] installed x265 (3.6-1)
[2024-11-07T12:49:38-0600] [ALPM] installed xvidcore (1.3.7-3)
[2024-11-07T12:49:38-0600] [ALPM] installed ffmpeg (2:7.0.2-3)
[2024-11-07T12:49:38-0600] [ALPM] installed ffmpegthumbnailer (2.2.3-2)
[2024-11-07T12:49:38-0600] [ALPM] installed gstreamer (1.24.9-1)
[2024-11-07T12:49:38-0600] [ALPM] installed orc (0.4.40-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gst-plugins-base-libs (1.24.9-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gst-libav (1.24.9-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gst-plugin-pipewire (1:1.2.6-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gssdp (1.6.3-2)
[2024-11-07T12:49:38-0600] [ALPM] installed gupnp (1:1.6.7-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gupnp-igd (1.6.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libnice (0.1.22-1)
[2024-11-07T12:49:38-0600] [ALPM] installed gst-plugins-bad-libs (1.24.9-1)
[2024-11-07T12:49:38-0600] [ALPM] installed chromaprint (1.5.1-8)
[2024-11-07T12:49:38-0600] [ALPM] installed faac (1.30-5)
[2024-11-07T12:49:38-0600] [ALPM] installed faad2 (2.11.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libinstpatch (1.1.6-3)
[2024-11-07T12:49:38-0600] [ALPM] installed fluidsynth (2.4.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libavtp (0.2.0-3)
[2024-11-07T12:49:38-0600] [ALPM] installed libdc1394 (2.2.7-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libdca (0.0.7-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libde265 (1.0.15-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libgme (0.6.3-5)
[2024-11-07T12:49:38-0600] [ALPM] installed raptor (2.0.16-5)
[2024-11-07T12:49:38-0600] [ALPM] installed liblrdf (0.6.1-5)
[2024-11-07T12:49:38-0600] [ALPM] installed libltc (1.3.2-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libmicrodns (0.2.0-2)
[2024-11-07T12:49:38-0600] [ALPM] installed libmpcdec (1:0.1+r475-6)
[2024-11-07T12:49:38-0600] [ALPM] installed libsrtp (1:2.6.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libdv (1.0.0-11)
[2024-11-07T12:49:38-0600] [ALPM] installed mjpegtools (2.2.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed neon (0.33.0-1)
[2024-11-07T12:49:38-0600] [ALPM] installed openal (1.23.1-2)
[2024-11-07T12:49:38-0600] [ALPM] installed openh264 (2.4.1-1)
[2024-11-07T12:49:38-0600] [ALPM] installed qrencode (4.1.1-3)
[2024-11-07T12:49:38-0600] [ALPM] installed rtmpdump (1:2.4.r105.6f6bb13-1)
[2024-11-07T12:49:38-0600] [ALPM] installed soundtouch (2.3.3-1)
[2024-11-07T12:49:38-0600] [ALPM] installed spandsp (0.0.6-5)
[2024-11-07T12:49:38-0600] [ALPM] installed svt-hevc (1.5.1-3)
[2024-11-07T12:49:38-0600] [ALPM] installed wildmidi (0.4.6-1)
[2024-11-07T12:49:38-0600] [ALPM] installed liblqr (0.4.3-1)
[2024-11-07T12:49:38-0600] [ALPM] installed libraqm (0.10.2-1)
[2024-11-07T12:49:39-0600] [ALPM] installed imagemagick (7.1.1.39-1)
[2024-11-07T12:49:39-0600] [ALPM] installed zbar (0.23.93-1)
[2024-11-07T12:49:39-0600] [ALPM] installed zvbi (0.2.42-1)
[2024-11-07T12:49:39-0600] [ALPM] installed zxing-cpp (2.2.1-1)
[2024-11-07T12:49:39-0600] [ALPM] installed gst-plugins-bad (1.24.9-1)
[2024-11-07T12:49:39-0600] [ALPM] installed a52dec (0.8.0-2)
[2024-11-07T12:49:39-0600] [ALPM] installed libcdio (2.1.0-4)
[2024-11-07T12:49:39-0600] [ALPM] installed libmpeg2 (0.5.1-10)
[2024-11-07T12:49:39-0600] [ALPM] installed gst-plugins-ugly (1.24.9-1)
[2024-11-07T12:49:39-0600] [ALPM] installed libdvdcss (1.4.3-2)
[2024-11-07T12:49:39-0600] [ALPM] installed libgsf (1.14.53-1)
[2024-11-07T12:49:39-0600] [ALPM] installed libopenraw (0.3.7-2)
[2024-11-07T12:49:39-0600] [ALPM] installed liburing (2.8-1)
[2024-11-07T12:49:39-0600] [ALPM] installed plocate (1.1.22-3)
[2024-11-07T12:49:39-0600] [ALPM] installed poppler (24.09.0-4)
[2024-11-07T12:49:39-0600] [ALPM] installed poppler-glib (24.09.0-4)
[2024-11-07T12:49:39-0600] [ALPM] installed xdg-user-dirs (0.18-2)
[2024-11-07T12:49:39-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/default.target.wants/xdg-user-dirs-update.service' -> '/usr/lib/systemd/user/xdg-user-dirs-update.service'.
[2024-11-07T12:49:39-0600] [ALPM] installed efitools (1.9.2-5)
[2024-11-07T12:49:39-0600] [ALPM] installed haveged (1.9.19-1)
[2024-11-07T12:49:39-0600] [ALPM] installed rpcbind (1.2.7-1)
[2024-11-07T12:49:39-0600] [ALPM] installed nfsidmap (2.8.1-1)
[2024-11-07T12:49:39-0600] [ALPM] installed ding-libs (0.6.2-2)
[2024-11-07T12:49:39-0600] [ALPM] installed gssproxy (0.9.2-1)
[2024-11-07T12:49:39-0600] [ALPM] installed nfs-utils (2.8.1-1)
[2024-11-07T12:49:39-0600] [ALPM] installed nilfs-utils (2.2.11-1)
[2024-11-07T12:49:39-0600] [ALPM] installed ntp (4.2.8.p18-2)
[2024-11-07T12:49:39-0600] [ALPM] installed smartmontools (7.4-2)
[2024-11-07T12:49:39-0600] [ALPM] installed unrar (1:7.1.1-1)
[2024-11-07T12:49:39-0600] [ALPM] installed unzip (6.0-21)
[2024-11-07T12:49:39-0600] [ALPM] installed noto-fonts (1:2024.11.01-1)
[2024-11-07T12:49:39-0600] [ALPM] installed noto-fonts-emoji (1:2.047-1)
[2024-11-07T12:49:40-0600] [ALPM] installed noto-fonts-cjk (20230817-2)
[2024-11-07T12:49:41-0600] [ALPM] installed noto-fonts-extra (1:2024.11.01-1)
[2024-11-07T12:49:41-0600] [ALPM] installed ttf-bitstream-vera (1.10-16)
[2024-11-07T12:49:41-0600] [ALPM] installed ttf-dejavu (2.37+18+g9b5d1b2f-7)
[2024-11-07T12:49:41-0600] [ALPM] installed ttf-liberation (2.1.5-2)
[2024-11-07T12:49:41-0600] [ALPM] installed ttf-opensans (1.101-3)
[2024-11-07T12:49:41-0600] [ALPM] installed alsa-firmware (1.2.4-4)
[2024-11-07T12:49:41-0600] [ALPM] installed alsa-plugins (1:1.2.12-3)
[2024-11-07T12:49:41-0600] [ALPM] installed alsa-utils (1.2.12-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libsigc++-3.0 (3.6.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed glibmm-2.68 (2.82.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed graphene (1.10.8-2)
[2024-11-07T12:49:41-0600] [ALPM] installed gtk4 (1:4.16.5-1)
[2024-11-07T12:49:41-0600] [ALPM] installed cairomm-1.16 (1.18.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed pangomm-2.48 (2.54.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed gtkmm-4.0 (4.16.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed tdb (1.4.12-1)
[2024-11-07T12:49:41-0600] [ALPM] installed sound-theme-freedesktop (0.8-6)
[2024-11-07T12:49:41-0600] [ALPM] installed libcanberra (1:0.30+r2+gc0620e4-4)
[2024-11-07T12:49:41-0600] [ALPM] installed pavucontrol (1:6.1-1)
[2024-11-07T12:49:41-0600] [ALPM] installed pipewire-pulse (1:1.2.6-1)
[2024-11-07T12:49:41-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/sockets.target.wants/pipewire-pulse.socket' -> '/usr/lib/systemd/user/pipewire-pulse.socket'.
[2024-11-07T12:49:41-0600] [ALPM] installed pipewire-alsa (1:1.2.6-1)
[2024-11-07T12:49:41-0600] [ALPM] installed rtkit (0.13-3)
[2024-11-07T12:49:41-0600] [ALPM] installed dmidecode (3.6-1)
[2024-11-07T12:49:41-0600] [ALPM] installed dmraid (1.0.0.rc16.3-15)
[2024-11-07T12:49:41-0600] [ALPM] installed hdparm (9.65-2)
[2024-11-07T12:49:41-0600] [ALPM] installed fd (10.2.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed ripgrep (14.1.1-1)
[2024-11-07T12:49:41-0600] [ALPM] installed sd (1.0.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed hwdetect (2024.07.29.0933-1)
[2024-11-07T12:49:41-0600] [ALPM] installed lsscsi (0.32-2)
[2024-11-07T12:49:41-0600] [ALPM] installed mtools (1:4.0.45-1)
[2024-11-07T12:49:41-0600] [ALPM] installed sg3_utils (1.48-1)
[2024-11-07T12:49:41-0600] [ALPM] installed sof-firmware (2024.09-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libplist (2.6.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libimobiledevice-glue (1.3.1-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libusbmuxd (2.1.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libimobiledevice (1.3.0-14)
[2024-11-07T12:49:41-0600] [ALPM] installed upower (1.90.6-1)
[2024-11-07T12:49:41-0600] [ALPM] installed power-profiles-daemon (0.23-1)
[2024-11-07T12:49:41-0600] [ALPM] installed endeavouros-theming (24.06.1.1-1)
[2024-11-07T12:49:41-0600] [ALPM] installed eos-translations (24.8-1)
[2024-11-07T12:49:41-0600] [ALPM] installed expac (10-11)
[2024-11-07T12:49:41-0600] [ALPM] installed python-dbus (1.3.2-4)
[2024-11-07T12:49:41-0600] [ALPM] installed eos-bash-shared (24.16.25-1)
[2024-11-07T12:49:41-0600] [ALPM] installed bubblewrap (0.11.0-1)
[2024-11-07T12:49:41-0600] [ALPM] installed enchant (2.8.2-1)
[2024-11-07T12:49:41-0600] [ALPM] installed harfbuzz-icu (10.0.1-1)
[2024-11-07T12:49:41-0600] [ALPM] installed hyphen (2.8.8-6)
[2024-11-07T12:49:41-0600] [ALPM] installed libyuv (r2426+464c51a03-1)
[2024-11-07T12:49:41-0600] [ALPM] installed libavif (1.1.1-2)
[2024-11-07T12:49:41-0600] [ALPM] installed libmanette (0.2.9-2)
[2024-11-07T12:49:41-0600] [ALPM] installed woff2 (1.0.2-5)
[2024-11-07T12:49:41-0600] [ALPM] installed xdg-dbus-proxy (0.1.6-1)
[2024-11-07T12:49:42-0600] [ALPM] installed webkit2gtk-4.1 (2.46.3-1)
[2024-11-07T12:49:42-0600] [ALPM] installed gtksourceview3 (1:3.24.11+r28+g73e57b57-2)
[2024-11-07T12:49:42-0600] [ALPM] installed gspell (1.14.0-1)
[2024-11-07T12:49:42-0600] [ALPM] installed yad (14.1-2.1)
[2024-11-07T12:49:42-0600] [ALPM] installed eos-apps-info (24.8.2-1)
[2024-11-07T12:49:42-0600] [ALPM] installed net-tools (2.10-3)
[2024-11-07T12:49:42-0600] [ALPM] installed eos-log-tool (24.8.1-1)
[2024-11-07T12:49:42-0600] [ALPM] installed libyaml (0.2.5-3)
[2024-11-07T12:49:42-0600] [ALPM] installed python-yaml (6.0.2-1)
[2024-11-07T12:49:42-0600] [ALPM] installed python-pyaml (24.7.0-1)
[2024-11-07T12:49:42-0600] [ALPM] installed eos-packagelist (2.3.1-1)
[2024-11-07T12:49:42-0600] [ALPM] installed double-conversion (3.3.0-2)
[2024-11-07T12:49:42-0600] [ALPM] installed libb2 (0.98.1-3)
[2024-11-07T12:49:42-0600] [ALPM] installed md4c (0.5.2-1)
[2024-11-07T12:49:42-0600] [ALPM] installed tslib (1.23-1)
[2024-11-07T12:49:42-0600] [ALPM] installed vulkan-headers (1:1.3.295-1)
[2024-11-07T12:49:42-0600] [ALPM] installed xcb-util-renderutil (0.3.10-2)
[2024-11-07T12:49:42-0600] [ALPM] installed xcb-util-image (0.4.1-3)
[2024-11-07T12:49:42-0600] [ALPM] installed xcb-util-cursor (0.1.5-1)
[2024-11-07T12:49:42-0600] [ALPM] installed xcb-util-keysyms (0.4.1-5)
[2024-11-07T12:49:42-0600] [ALPM] installed xcb-util-wm (0.4.2-2)
[2024-11-07T12:49:42-0600] [ALPM] installed qt6-translations (6.8.0-1)
[2024-11-07T12:49:42-0600] [ALPM] installed qt6-base (6.8.0-1)
[2024-11-07T12:49:43-0600] [ALPM] installed qt6-declarative (6.8.0-4)
[2024-11-07T12:49:43-0600] [ALPM] installed eos-quickstart (1.4.1-1)
[2024-11-07T12:49:43-0600] [ALPM] installed eos-rankmirrors (24.9.2-1)
[2024-11-07T12:49:43-0600] [ALPM] installed reflector-simple (2024.8.1-1)
[2024-11-07T12:49:45-0600] [ALPM] installed eos-qogir-icons (5-1)
[2024-11-07T12:49:45-0600] [ALPM] installed welcome (24.10-1)
[2024-11-07T12:49:45-0600] [ALPM] installed duf (0.8.1-3)
[2024-11-07T12:49:45-0600] [ALPM] installed fsarchiver (0.8.7-2)
[2024-11-07T12:49:45-0600] [ALPM] installed python-psutil (6.1.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-defusedxml (0.7.1-6)
[2024-11-07T12:49:45-0600] [ALPM] installed python-orjson (3.10.11-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-annotated-types (0.7.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-typing_extensions (4.12.2-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-pydantic-core (1:2.23.4-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-pydantic (2.9.2-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-packaging (24.1-1)
[2024-11-07T12:49:45-0600] [ALPM] installed glances (4.2.1-1)
[2024-11-07T12:49:45-0600] [ALPM] installed libx86emu (3.5-4)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-encode-locale (1.05-13)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-date (6.06-3)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-file-listing (6.16-4)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-html-tagset (3.24-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-clone (0.47-1)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-io-html (1.004-6)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-lwp-mediatypes (6.04-6)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-uri (5.29-1)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-message (6.46-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-html-parser (3.83-1)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-cookies (6.11-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-daemon (6.16-4)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-cookiejar (0.014-3)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-http-negotiate (6.01-14)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-net-http (6.23-4)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-try-tiny (0.32-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-www-robotrules (6.02-14)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-libwww (6.77-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-xml-parser (2.47-2)
[2024-11-07T12:49:45-0600] [ALPM] installed perl-xml-writer (0.900-4)
[2024-11-07T12:49:45-0600] [ALPM] installed hwinfo (23.3-1)
[2024-11-07T12:49:45-0600] [ALPM] installed inxi (3.3.36.1-1)
[2024-11-07T12:49:45-0600] [ALPM] installed gtksourceview4 (4.8.4-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-cairo (1.27.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed libgirepository (1.82.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed gobject-introspection-runtime (1.82.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-gobject (3.50.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed meld (3.22.2-3)
[2024-11-07T12:49:45-0600] [ALPM] installed nano-syntax-highlighting (2022.11.02.r102.gbb94603-1)
[2024-11-07T12:49:45-0600] [ALPM] installed pv (1.9.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed rsync (3.3.0-2)
[2024-11-07T12:49:45-0600] [ALPM] installed python-shtab (1.7.1-2)
[2024-11-07T12:49:45-0600] [ALPM] installed python-colorama (0.4.6-3)
[2024-11-07T12:49:45-0600] [ALPM] installed python-termcolor (2.4.0-2)
[2024-11-07T12:49:45-0600] [ALPM] installed tldr (3.3.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed vi (1:070224-6)
[2024-11-07T12:49:45-0600] [ALPM] installed wget (1.24.5-3)
[2024-11-07T12:49:45-0600] [ALPM] installed python-capng (0.8.5-2)
[2024-11-07T12:49:45-0600] [ALPM] installed firewalld (2.3.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed python-pyqt5-sip (12.15.0-1)
[2024-11-07T12:49:45-0600] [ALPM] installed qt5-translations (5.15.15-1)
[2024-11-07T12:49:46-0600] [ALPM] installed qt5-base (5.15.15+kde+r140-1)
[2024-11-07T12:49:46-0600] [ALPM] installed python-pyqt5 (5.15.11-1)
[2024-11-07T12:49:46-0600] [ALPM] installed glycin (1.1.1-2)
[2024-11-07T12:49:46-0600] [ALPM] installed libxmlb (0.3.21-1)
[2024-11-07T12:49:46-0600] [ALPM] installed appstream (1.0.3-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libadwaita (1:1.6.1-1)
[2024-11-07T12:49:46-0600] [ALPM] installed geocode-glib-common (3.26.4-4)
[2024-11-07T12:49:46-0600] [ALPM] installed geocode-glib-2 (3.26.4-4)
[2024-11-07T12:49:46-0600] [ALPM] installed libgweather-4 (4.4.4-1)
[2024-11-07T12:49:46-0600] [ALPM] installed loupe (47.1-1)
[2024-11-07T12:49:46-0600] [ALPM] installed djvulibre (3.5.28-6)
[2024-11-07T12:49:46-0600] [ALPM] installed gnome-desktop-common (1:44.1-1)
[2024-11-07T12:49:46-0600] [ALPM] installed gnome-desktop (1:44.1-1)
[2024-11-07T12:49:46-0600] [ALPM] installed gsfonts (20200910-4)
[2024-11-07T12:49:46-0600] [ALPM] installed fuse3 (3.16.2-1)
[2024-11-07T12:49:46-0600] [ALPM] installed gcr-4 (4.3.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libcdio-paranoia (10.2+2.0.2-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libatasmart (0.19-6)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed volume_key (0.3.12-9)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-crypto (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libbytesize (2.8-3)
[2024-11-07T12:49:46-0600] [ALPM] installed parted (3.6-2)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-fs (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-mdraid (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-loop (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libnvme (1.10-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-nvme (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-part (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libblockdev-swap (3.2.0-1)
[2024-11-07T12:49:46-0600] [ALPM] installed udisks2 (2.10.1-5)
[2024-11-07T12:49:46-0600] [ALPM] installed gvfs (1.56.1-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libgxps (0.3.2-5)
[2024-11-07T12:49:46-0600] [ALPM] installed libhandy (1.8.3-2)
[2024-11-07T12:49:46-0600] [ALPM] installed jbig2dec (0.20-1)
[2024-11-07T12:49:46-0600] [ALPM] installed libpaper (2.2.5-1)
[2024-11-07T12:49:46-0600] [ALPM] installed ijs (0.35-6)
[2024-11-07T12:49:46-0600] [ALPM] installed libidn (1.42-1)
[2024-11-07T12:49:46-0600] [ALPM] installed poppler-data (0.4.12-2)
[2024-11-07T12:49:47-0600] [ALPM] installed ghostscript (10.04.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libspectre (0.2.12-2)
[2024-11-07T12:49:47-0600] [ALPM] installed libsynctex (2024.2-3)
[2024-11-07T12:49:47-0600] [ALPM] installed evince (46.3.1-2)
[2024-11-07T12:49:47-0600] [ALPM] installed libnautilus-extension (47.0-3)
[2024-11-07T12:49:47-0600] [ALPM] installed libportal (0.8.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libportal-gtk4 (0.8.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed zip (3.0-11)
[2024-11-07T12:49:47-0600] [ALPM] installed file-roller (44.3-1)
[2024-11-07T12:49:47-0600] [ALPM] installed gcr (3.41.2-2)
[2024-11-07T12:49:47-0600] [ALPM] installed gnome-keyring (1:46.2-1)
[2024-11-07T12:49:47-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/user/sockets.target.wants/gnome-keyring-daemon.socket' -> '/usr/lib/systemd/user/gnome-keyring-daemon.socket'.
[2024-11-07T12:49:47-0600] [ALPM] installed gnome-desktop-4 (1:44.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed gnome-autoar (0.4.5-1)
[2024-11-07T12:49:47-0600] [ALPM] installed exiv2 (0.28.3-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libgexiv2 (0.14.3-1)
[2024-11-07T12:49:47-0600] [ALPM] installed exempi (2.6.5-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libcue (2.3.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libexif (0.6.24-3)
[2024-11-07T12:49:47-0600] [ALPM] installed libiptcdata (1.0.5-3)
[2024-11-07T12:49:47-0600] [ALPM] installed osinfo-db (20240701-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libosinfo (1.12.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed uchardet (0.0.8-3)
[2024-11-07T12:49:47-0600] [ALPM] installed totem-pl-parser (3.26.6+r30+g51b8439-1)
[2024-11-07T12:49:47-0600] [ALPM] installed localsearch (3.8.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed xdg-user-dirs-gtk (0.11-3)
[2024-11-07T12:49:47-0600] [ALPM] installed nautilus (47.0-3)
[2024-11-07T12:49:47-0600] [ALPM] installed geoclue (2.7.2-1)
[2024-11-07T12:49:47-0600] [ALPM] installed xdg-desktop-portal (1.18.4-1)
[2024-11-07T12:49:47-0600] [ALPM] installed xdg-desktop-portal-gtk (1.15.1-2)
[2024-11-07T12:49:47-0600] [ALPM] installed xdg-desktop-portal-gnome (47.1-2)
[2024-11-07T12:49:47-0600] [ALPM] installed gnome-session (47.0.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed js128 (128.4.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed gjs (2:1.82.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libnotify (0.8.3-1)
[2024-11-07T12:49:47-0600] [ALPM] installed gnome-settings-daemon (47.1-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libgdm (47.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libibus (1.5.30-3)
[2024-11-07T12:49:47-0600] [ALPM] installed libical (3.0.18-2)
[2024-11-07T12:49:47-0600] [ALPM] installed libnma-common (1.10.6-3)
[2024-11-07T12:49:47-0600] [ALPM] installed libnma-gtk4 (1.10.6-3)
[2024-11-07T12:49:47-0600] [ALPM] installed libgusb (0.4.9-1)
[2024-11-07T12:49:47-0600] [ALPM] installed colord (1.4.7-2)
[2024-11-07T12:49:47-0600] [ALPM] installed iio-sensor-proxy (3.5-2)
[2024-11-07T12:49:47-0600] [ALPM] installed libdisplay-info (0.2.0-1)
[2024-11-07T12:49:47-0600] [ALPM] installed libei (1.3.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed xorg-xwayland (24.1.4-1)
[2024-11-07T12:49:48-0600] [ALPM] installed mutter (47.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed webkitgtk-6.0 (2.46.3-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-shell (1:47.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gdm (47.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gtksourceview5 (5.14.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed libgee (0.20.6-2)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-calculator (47.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-clocks (47.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed libgtop (2.41.3-2)
[2024-11-07T12:49:48-0600] [ALPM] installed vte-common (0.78.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed vte4 (0.78.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-console (47.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed bolt (0.9.8-1)
[2024-11-07T12:49:48-0600] [ALPM] installed colord-gtk-common (0.3.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed colord-gtk4 (0.3.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed cups-pk-helper (0.2.7-2)
[2024-11-07T12:49:48-0600] [ALPM] installed gsound (1.0.3-3)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-bluetooth-3.0 (47.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-color-manager (3.36.0+r62+g82000f1d-1)
[2024-11-07T12:49:48-0600] [ALPM] installed librest (0.9.1-2)
[2024-11-07T12:49:48-0600] [ALPM] installed libgoa (3.52.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-online-accounts (3.52.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed libmalcontent (0.12.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed cracklib (2.10.2-1)
[2024-11-07T12:49:48-0600] [ALPM] installed libpwquality (1.4.5-5)
[2024-11-07T12:49:48-0600] [ALPM] installed libmd (1.1.0-2)
[2024-11-07T12:49:48-0600] [ALPM] installed libbsd (0.12.2-2)
[2024-11-07T12:49:48-0600] [ALPM] installed libwbclient (2:4.21.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed talloc (2.4.2-3)
[2024-11-07T12:49:48-0600] [ALPM] installed cifs-utils (7.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed tevent (1:0.16.1-3)
[2024-11-07T12:49:48-0600] [ALPM] installed ldb (2:4.21.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed smbclient (2:4.21.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed tecla (47.0-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-keybindings (47.1.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-control-center (47.1.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-disk-utility (46.1-1)
[2024-11-07T12:49:48-0600] [ALPM] installed whois (5.5.23-1)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-nettool (42.0-3)
[2024-11-07T12:49:48-0600] [ALPM] installed gnome-power-manager (43.0-2)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-screenshot (41.0+r39+ga362197-2)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-system-monitor (47.0-2)
[2024-11-07T12:49:49-0600] [ALPM] installed vte3 (0.78.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-terminal (3.54.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed editorconfig-core-c (0.12.9-1)
[2024-11-07T12:49:49-0600] [ALPM] installed libspelling (0.4.4-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-text-editor (47.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-themes-extra (3.28+r6+g45b1d457-2)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-tweaks (46.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-usage (46.0-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gnome-weather (47.0-1)
[2024-11-07T12:49:49-0600] [ALPM] installed usbmuxd (1.1.1-4)
[2024-11-07T12:49:49-0600] [ALPM] installed gvfs-afc (1.56.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed libheif (1.19.2-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gd (2.3.3-8)
[2024-11-07T12:49:49-0600] [ALPM] installed libgphoto2 (2.5.31-3)
[2024-11-07T12:49:49-0600] [ALPM] installed gvfs-gphoto2 (1.56.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed libmtp (1.1.21-2)
[2024-11-07T12:49:49-0600] [ALPM] installed gvfs-mtp (1.56.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed libnfs (5.0.3-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gvfs-nfs (1.56.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gvfs-smb (1.56.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gst-plugin-gtk (1.24.9-1)
[2024-11-07T12:49:49-0600] [ALPM] installed sushi (46.0-2)
[2024-11-07T12:49:49-0600] [ALPM] installed liboauth (1:1.0.3+r16+gc26f038-2)
[2024-11-07T12:49:49-0600] [ALPM] installed grilo (0.3.16-1)
[2024-11-07T12:49:49-0600] [ALPM] installed cdparanoia (10.2-9)
[2024-11-07T12:49:49-0600] [ALPM] installed gst-plugins-base (1.24.9-1)
[2024-11-07T12:49:49-0600] [ALPM] installed aalib (1.4rc5-18)
[2024-11-07T12:49:49-0600] [ALPM] installed freeglut (3.6.0-1)
[2024-11-07T12:49:49-0600] [ALPM] installed glu (9.0.3-2)
[2024-11-07T12:49:49-0600] [ALPM] installed imlib2 (1.12.3-2)
[2024-11-07T12:49:49-0600] [ALPM] installed libcaca (0.99.beta20-4)
[2024-11-07T12:49:49-0600] [ALPM] installed libshout (1:2.4.6-3)
[2024-11-07T12:49:49-0600] [ALPM] installed taglib (2.0.2-1)
[2024-11-07T12:49:49-0600] [ALPM] installed twolame (0.4.0-4)
[2024-11-07T12:49:49-0600] [ALPM] installed wavpack (5.7.0-1)
[2024-11-07T12:49:49-0600] [ALPM] installed gst-plugins-good (1.24.9-1)
[2024-11-07T12:49:49-0600] [ALPM] installed libpeas (1.36.0-5)
[2024-11-07T12:49:49-0600] [ALPM] installed libportal-gtk3 (0.8.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed totem (43.1-1)
[2024-11-07T12:49:49-0600] [ALPM] installed arc-gtk-theme-eos (20221218-2)
[2024-11-07T12:49:49-0600] [ALPM] installed eos-settings-gnome (2.2-1)
[2024-11-07T12:49:50-0600] [ALPM] transaction completed
[2024-11-07T12:49:50-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'gdm' with GID 120.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'ntp' with GID 87.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'locate' with GID 21.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'avahi' with GID 971.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'avahi' (Avahi mDNS/DNS-SD daemon) with UID 971 and GID 971.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'named' with GID 40.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'named' (BIND DNS Server) with UID 40 and GID 40.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'colord' with GID 970.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'colord' (Color management daemon) with UID 970 and GID 970.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'dnsmasq' with GID 969.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'dnsmasq' (dnsmasq daemon) with UID 969 and GID 969.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'gdm' (Gnome Display Manager) with UID 120 and GID 120.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'geoclue' with GID 968.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'geoclue' (Geoinformation service) with UID 968 and GID 968.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'git' with GID 967.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'git' (git daemon user) with UID 967 and GID 967.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'nm-openconnect' with GID 966.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'nm-openconnect' (NetworkManager OpenConnect) with UID 966 and GID 966.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'nm-openvpn' with GID 965.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'nm-openvpn' (NetworkManager OpenVPN) with UID 965 and GID 965.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'ntp' (Network Time Protocol) with UID 87 and GID 87.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'openvpn' with GID 964.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'openvpn' (OpenVPN) with UID 964 and GID 964.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'polkitd' with GID 102.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'polkitd' (User for polkitd) with UID 102 and GID 102.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'rpc' with GID 32.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'rpc' (Rpcbind Daemon) with UID 32 and GID 32.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'rpcuser' with GID 34.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'rpcuser' (RPC Service User) with UID 34 and GID 34.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'rtkit' with GID 133.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'rtkit' (RealtimeKit) with UID 133 and GID 133.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating group 'usbmux' with GID 140.
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Creating user 'usbmux' (usbmux user) with UID 140 and GID 140.
[2024-11-07T12:49:50-0600] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-11-07T12:49:50-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:49:50-0600] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-11-07T12:49:50-0600] [ALPM] running '30-systemd-hwdb.hook'...
[2024-11-07T12:49:51-0600] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-11-07T12:49:51-0600] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-11-07T12:49:51-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:49:51-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:49:51-0600] [ALPM] running '30-update-mime-database.hook'...
[2024-11-07T12:49:51-0600] [ALPM] running '40-fontconfig-config.hook'...
[2024-11-07T12:49:51-0600] [ALPM] running '70-dkms-install.hook'...
[2024-11-07T12:49:52-0600] [ALPM-SCRIPTLET] ==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 6.11.6-arch1-1
[2024-11-07T12:49:58-0600] [ALPM-SCRIPTLET] ==> depmod 6.11.6-arch1-1
[2024-11-07T12:50:01-0600] [ALPM] running '90-update-appstream-cache.hook'...
[2024-11-07T12:50:01-0600] [ALPM-SCRIPTLET] ? Metadata cache was updated successfully.
[2024-11-07T12:50:01-0600] [ALPM] running 'accounts-daemon-restart.hook'...
[2024-11-07T12:50:01-0600] [ALPM-SCRIPTLET] Running in chroot, ignoring command 'try-restart'
[2024-11-07T12:50:01-0600] [ALPM] running 'dbus-reload.hook'...
[2024-11-07T12:50:01-0600] [ALPM-SCRIPTLET] Skipped: Running in chroot.
[2024-11-07T12:50:01-0600] [ALPM] running 'detect-old-perl-modules.hook'...
[2024-11-07T12:50:01-0600] [ALPM] running 'fontconfig.hook'...
[2024-11-07T12:50:02-0600] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2024-11-07T12:50:02-0600] [ALPM] running 'gio-querymodules.hook'...
[2024-11-07T12:50:02-0600] [ALPM] running 'glib-compile-schemas.hook'...
[2024-11-07T12:50:02-0600] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2024-11-07T12:50:02-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-11-07T12:50:03-0600] [ALPM] running 'gtk4-querymodules.hook'...
[2024-11-07T12:50:03-0600] [ALPM] running 'gvfsd.hook'...
[2024-11-07T12:50:03-0600] [ALPM] running 'texinfo-install.hook'...
[2024-11-07T12:50:03-0600] [ALPM] running 'update-desktop-database.hook'...
[2024-11-07T12:50:03-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout amd-ucode'
[2024-11-07T12:50:04-0600] [ALPM] transaction started
[2024-11-07T12:50:04-0600] [ALPM] installed amd-ucode (20241017.22a6c7dc-1)
[2024-11-07T12:50:05-0600] [ALPM] transaction completed
[2024-11-07T12:50:05-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:05-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout intel-ucode'
[2024-11-07T12:50:07-0600] [ALPM] transaction started
[2024-11-07T12:50:07-0600] [ALPM] installed intel-ucode (20241029-1)
[2024-11-07T12:50:07-0600] [ALPM] transaction completed
[2024-11-07T12:50:07-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:07-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout firefox'
[2024-11-07T12:50:15-0600] [ALPM] transaction started
[2024-11-07T12:50:15-0600] [ALPM] installed libxss (1.2.4-2)
[2024-11-07T12:50:15-0600] [ALPM] installed mailcap (2.1.54-2)
[2024-11-07T12:50:16-0600] [ALPM] installed firefox (132.0.1-1)
[2024-11-07T12:50:16-0600] [ALPM] transaction completed
[2024-11-07T12:50:16-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:16-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-11-07T12:50:16-0600] [ALPM] running 'update-desktop-database.hook'...
[2024-11-07T12:50:16-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout aspell'
[2024-11-07T12:50:17-0600] [ALPM] transaction started
[2024-11-07T12:50:17-0600] [ALPM] installed aspell (0.60.8.1-2)
[2024-11-07T12:50:17-0600] [ALPM] transaction completed
[2024-11-07T12:50:18-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:18-0600] [ALPM] running 'texinfo-install.hook'...
[2024-11-07T12:50:18-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout linux-lts'
[2024-11-07T12:50:31-0600] [ALPM] transaction started
[2024-11-07T12:50:32-0600] [ALPM] installed linux-lts (6.6.59-1)
[2024-11-07T12:50:32-0600] [ALPM] transaction completed
[2024-11-07T12:50:32-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:32-0600] [ALPM] running '60-depmod.hook'...
[2024-11-07T12:50:33-0600] [ALPM] running '70-dkms-install.hook'...
[2024-11-07T12:50:33-0600] [ALPM-SCRIPTLET] ==> ERROR: Missing 6.6.59-1-lts kernel headers for module broadcom-wl/6.30.223.271.
[2024-11-07T12:50:33-0600] [PACMAN] Running 'pacman -S --noconfirm --noprogressbar --needed --disable-download-timeout linux-lts-headers'
[2024-11-07T12:50:37-0600] [ALPM] transaction started
[2024-11-07T12:50:39-0600] [ALPM] installed linux-lts-headers (6.6.59-1)
[2024-11-07T12:50:39-0600] [ALPM] transaction completed
[2024-11-07T12:50:39-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:39-0600] [ALPM] running '60-depmod.hook'...
[2024-11-07T12:50:40-0600] [ALPM] running '70-dkms-install.hook'...
[2024-11-07T12:50:40-0600] [ALPM-SCRIPTLET] ==> dkms install --no-depmod broadcom-wl/6.30.223.271 -k 6.6.59-1-lts
[2024-11-07T12:50:48-0600] [ALPM-SCRIPTLET] ==> depmod 6.6.59-1-lts
[2024-11-07T12:50:52-0600] [PACMAN] Running 'pacman -R --noconfirm amd-ucode'
[2024-11-07T12:50:52-0600] [ALPM] transaction started
[2024-11-07T12:50:52-0600] [ALPM] removed amd-ucode (20241017.22a6c7dc-1)
[2024-11-07T12:50:52-0600] [ALPM] transaction completed
[2024-11-07T12:50:52-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm virtualbox-guest-utils'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm qemu-guest-agent'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm spice-vdagent'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm open-vm-tools'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm gtkmm3'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm xf86-input-vmmouse'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rns --noconfirm xf86-video-vmware'
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rsn --noconfirm xf86-video-amdgpu'
[2024-11-07T12:50:53-0600] [ALPM] transaction started
[2024-11-07T12:50:53-0600] [ALPM] removed xf86-video-amdgpu (23.0.0-2)
[2024-11-07T12:50:53-0600] [ALPM] transaction completed
[2024-11-07T12:50:53-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rsn --noconfirm xf86-video-ati'
[2024-11-07T12:50:53-0600] [ALPM] removed xf86-video-ati (1:22.0.0-2)
[2024-11-07T12:50:53-0600] [PACMAN] Running 'pacman -Rsn --noconfirm broadcom-wl-dkms'
[2024-11-07T12:50:53-0600] [ALPM] running '71-dkms-remove.hook'...
[2024-11-07T12:50:54-0600] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 6.11.6-arch1-1
[2024-11-07T12:50:54-0600] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod broadcom-wl/6.30.223.271 -k 6.6.59-1-lts
[2024-11-07T12:50:54-0600] [ALPM-SCRIPTLET] ==> depmod 6.11.6-arch1-1
[2024-11-07T12:50:56-0600] [ALPM-SCRIPTLET] ==> depmod 6.6.59-1-lts
[2024-11-07T12:50:57-0600] [ALPM] transaction started
[2024-11-07T12:50:57-0600] [ALPM] removed broadcom-wl-dkms (6.30.223.271-37)
[2024-11-07T12:50:57-0600] [ALPM] removed dkms (3.1.1-2)
[2024-11-07T12:50:57-0600] [ALPM] transaction completed
[2024-11-07T12:50:57-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:50:58-0600] [PACMAN] Running 'pacman --noconfirm -Rcn mkinitcpio'
[2024-11-07T12:50:58-0600] [PACMAN] Running 'pacman --noconfirm -S kernel-install-for-dracut'
[2024-11-07T12:50:59-0600] [ALPM] transaction started
[2024-11-07T12:50:59-0600] [ALPM] installed kernel-install-for-dracut (1.10.1-1)
[2024-11-07T12:50:59-0600] [ALPM] transaction completed
[2024-11-07T12:50:59-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T12:58:32-0600] [PACMAN] Running 'pacman -Syyu'
[2024-11-07T12:58:32-0600] [PACMAN] synchronizing package lists
[2024-11-07T12:58:34-0600] [PACMAN] starting full system upgrade
[2024-11-07T12:58:46-0600] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2024-11-07T12:58:46-0600] [PACMAN] synchronizing package lists
[2024-11-07T13:00:26-0600] [PACMAN] Running 'pacman -S neofetch'
[2024-11-07T13:00:30-0600] [ALPM] transaction started
[2024-11-07T13:00:30-0600] [ALPM] installed neofetch (7.1.0-2)
[2024-11-07T13:00:30-0600] [ALPM] transaction completed
[2024-11-07T13:00:30-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T13:01:12-0600] [PACMAN] Running 'pacman -S armcord'
[2024-11-07T13:11:08-0600] [PACMAN] Running 'pacman -S discord'
[2024-11-07T13:11:21-0600] [ALPM] transaction started
[2024-11-07T13:11:22-0600] [ALPM] installed discord (0.0.73-1)
[2024-11-07T13:11:22-0600] [ALPM] transaction completed
[2024-11-07T13:11:22-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T13:11:22-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-11-07T13:11:22-0600] [ALPM] running 'update-desktop-database.hook'...
[2024-11-07T13:11:36-0600] [PACMAN] Running 'pacman -S element'
[2024-11-07T13:12:48-0600] [PACMAN] Running 'pacman -S element-desktop'
[2024-11-07T13:13:03-0600] [ALPM] transaction started
[2024-11-07T13:13:03-0600] [ALPM] installed element-web (1.11.81-1)
[2024-11-07T13:13:03-0600] [ALPM] installed c-ares (1.34.2-1)
[2024-11-07T13:13:03-0600] [ALPM] installed minizip (1:1.3.1-2)
[2024-11-07T13:13:03-0600] [ALPM] installed electron32 (32.2.2-1)
[2024-11-07T13:13:04-0600] [ALPM] installed element-desktop (1.11.81-1)
[2024-11-07T13:13:04-0600] [ALPM] transaction completed
[2024-11-07T13:13:04-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T13:13:04-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-11-07T13:13:04-0600] [ALPM] running 'update-desktop-database.hook'...
[2024-11-07T13:14:14-0600] [PACMAN] Running 'pacman -S bitwarden'
[2024-11-07T13:14:28-0600] [ALPM] transaction started
[2024-11-07T13:14:29-0600] [ALPM] installed electron31 (31.7.3-1)
[2024-11-07T13:14:29-0600] [ALPM] installed libnss_nis (3.2-2)
[2024-11-07T13:14:29-0600] [ALPM] installed bitwarden (2024.9.0-1)
[2024-11-07T13:14:29-0600] [ALPM] transaction completed
[2024-11-07T13:14:29-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T13:14:29-0600] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-11-07T13:14:29-0600] [ALPM] running 'update-desktop-database.hook'...
[2024-11-07T13:20:19-0600] [PACMAN] Running 'pacman -S steam'
[2024-11-07T13:21:30-0600] [ALPM] transaction started
[2024-11-07T13:21:30-0600] [ALPM] installed eglexternalplatform (1.2-2)
[2024-11-07T13:21:30-0600] [ALPM] installed egl-wayland (4:1.1.16-1)
[2024-11-07T13:21:30-0600] [ALPM] installed egl-gbm (1.1.2-1)
[2024-11-07T13:21:32-0600] [ALPM] installed nvidia-utils (565.57.01-1)
[2024-11-07T13:21:32-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
[2024-11-07T13:21:32-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
[2024-11-07T13:21:32-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' → '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2024-11-07T13:21:32-0600] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' → '/usr/lib/systemd/system/nvidia-suspend.service'.
[2024-11-07T13:21:32-0600] [ALPM] installed zenity (4.0.3-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lsof (4.99.3-2)
[2024-11-07T13:21:32-0600] [ALPM] installed libxcrypt-compat (4.4.36-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-glibc (2.40+r16+gaa533d58ff-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxcrypt (4.4.36-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxcrypt-compat (4.4.36-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxdmcp (1.1.5-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxau (1.0.11-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxcb (1.17.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libx11 (1.8.10-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxext (1.3.6-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-expat (2.6.3-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-gcc-libs (14.2.1+r134+gab884fffe3fc-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-zlib (1.3.1-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libpciaccess (0.18.1-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libdrm (2.4.123-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-bzip2 (1.0.8-4)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-brotli (1.1.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-e2fsprogs (1.47.1-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-keyutils (1.6.3-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-openssl (1:3.4.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libldap (2.6.8-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-krb5 (1.21.3-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libunistring (1.2-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libidn2 (2.3.7-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libnghttp2 (1.64.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libnghttp3 (1.6.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libpsl (0.21.5-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libssh2 (1.11.0-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-zstd (1.5.6-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-curl (8.11.0-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-json-c (0.18-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-xz (5.6.3-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libelf (0.192-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxfixes (6.0.1-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxshmfence (1.3.2-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libxxf86vm (1.1.5-2)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-libffi (3.4.6-1)
[2024-11-07T13:21:32-0600] [ALPM] installed lib32-ncurses (6.5-1)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-icu (75.1-1)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-libxml2 (2.13.4-1)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-llvm-libs (18.1.8-1)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-lm_sensors (1:3.6.0.r41.g31d1f125-3)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-wayland (1.23.1-1)
[2024-11-07T13:21:33-0600] [ALPM] installed lib32-mesa (1:24.2.6-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-nvidia-utils (565.57.01-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-libglvnd (1.7.0-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-libxss (1.2.4-2)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-alsa-lib (1.2.12-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-alsa-plugins (1.2.12-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-libgpg-error (1.50-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-nspr (4.36-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-libtasn1 (4.19.0-2)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-p11-kit (0.25.5-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-sqlite (3.46.1-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-nss (3.106-1)
[2024-11-07T13:21:34-0600] [ALPM] installed lib32-vulkan-icd-loader (1.3.295-1)
[2024-11-07T13:21:34-0600] [ALPM] installed steam (1.0.0.81-2)
[2024-11-07T13:21:34-0600] [ALPM] transaction completed
[2024-11-07T13:21:34-0600] [ALPM] running '20-systemd-sysusers.hook'...
[2024-11-07T13:21:34-0600] [ALPM-SCRIPTLET] Creating group 'nvidia-persistenced' with GID 143.
[2024-11-07T13:21:34-0600] [ALPM-SCRIPTLET] Creating user 'nvidia-persistenced' (NVIDIA Persistence Daemon) with UID 143 and GID 143.
[2024-11-07T13:21:34-0600] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-11-07T13:21:34-0600] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-11-07T13:21:35-0600] [ALPM] running '30-systemd-update.hook'...
[2024-11-07T13:21:35-0600] [ALPM] running '90-kernel-install.hook'...
[2024-11-07T13:21:36-0600] [ALPM-SCRIPTLET] Running kernel-install for 6.11.6-arch1-1
[2024-11-07T13:21:38-0600] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd-fallback 6.11.6-arch1-1
[2024-11-07T13:21:41-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-11-07T13:21:41-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-11-07T13:21:41-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-pcrphase ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: modsign ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: btrfs ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-11-07T13:21:42-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lvm ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: mdraid ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: nvdimm ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu-net ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fido2 ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pkcs11 ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lunmask ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: resume ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-11-07T13:21:45-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: virtiofs ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-11-07T13:21:46-0600] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-11-07T13:21:47-0600] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-11-07T13:21:47-0600] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Constructing GenuineIntel.bin ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-11-07T13:21:48-0600] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd-fallback' ***
[2024-11-07T13:21:54-0600] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd-fallback' done ***
[2024-11-07T13:21:54-0600] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/3861d2ceb2174d54be2a0cac90e33e8e/6.11.6-arch1-1/initrd 6.11.6-arch1-1
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-11-07T13:21:56-0600] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
grep: (standard input): binary file matches
please learn how to use grep and narrow your searches down.
for this particular we only need the time of the incident.
see the structure of the above command to help narrow the search for your issue try this command
cat /var/log/pacman.log | grep “[2024-11-07T13” adjusting the time as needed
doing this will be easier for people to follow what is going on, Remember we are just volunteers and we dont’ always have time to spend a long time going through logs.
The file /var/log/pacman.log is just a text file and you can open it in any text editor, if you are running Plasma, then Kate is probably your text editor. Open the pacman.log file in /var/log and scroll all the way to the end of the file. Begin scrolling upwards until you reach the first line the reads (ignore my date/time stamp since that won’t be the same for you):
[2024-11-18T10:29:42-0700] [PACMAN] Running ‘pacman -Syu’
Copy everything from that line to the end of the file and paste the text between code tags.
[2024-11-18T23:15:40-0600] [PACMAN] Running 'pacman -Syyu'
[2024-11-18T23:15:40-0600] [PACMAN] synchronizing package lists
[2024-11-18T23:15:41-0600] [PACMAN] starting full system upgrade
To be fair, I did actually use grep there. I posted the exact command you had told me to use.
you did, but I though you may have a clue as to what you were doing I was wrong.
Welcome to the community @Flannel_Bear, I feel like it’s been a bit of a rough start for you.
As mentioned, we’ll need to see the errors you’re getting so we can try to help. As far as I can tell, what you’ve shared so far has no errors mentioned.
To get the ball rolling, can you copy and paste an example of “this error” please.
Ok, it’s a lot of code that shows up, which is why I didn’t really post it at first, but here we go.
error: failed to commit transaction (conflicting files)
qt6-declarative: /usr/bin/qml6 exists in filesystem
qt6-declarative: /usr/bin/qmleasing6 exists in filesystem
qt6-declarative: /usr/bin/qmlls6 exists in filesystem
qt6-declarative: /usr/bin/qmlpreview6 exists in filesystem
qt6-declarative: /usr/bin/qmlscene6 exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/6.8.0/QtLabsAnimation/private/qqmlanimationglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/6.8.0/QtLabsAnimation/private/qquickboundaryrule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/QtLabsAnimation exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/QtLabsAnimationDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/QtLabsAnimationVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/qtlabsanimationexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsAnimation/qtlabsanimationversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/6.8.0/QtLabsFolderListModel/private/fileinfothread_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/6.8.0/QtLabsFolderListModel/private/fileproperty_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/6.8.0/QtLabsFolderListModel/private/qquickfolderlistmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/6.8.0/QtLabsFolderListModel/private/qquickfolderlistmodelglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/QtLabsFolderListModel exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/QtLabsFolderListModelDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/QtLabsFolderListModelVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/qtlabsfolderlistmodelexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsFolderListModel/qtlabsfolderlistmodelversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformcolordialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformfiledialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformfolderdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformfontdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformicon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformiconloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmenu_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmenubar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmenuitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmenuitemgroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmenuseparator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformmessagedialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformstandardpaths_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qquicklabsplatformsystemtrayicon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatform_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformcolordialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformfiledialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformfontdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformmenu_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformmenuitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformmessagedialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/6.8.0/QtLabsPlatform/private/qwidgetplatformsystemtrayicon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/QtLabsPlatform exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/QtLabsPlatformDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/QtLabsPlatformVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/qtlabsplatformexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsPlatform/qtlabsplatformversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/6.8.0/QtLabsQmlModels/private/qqmldelegatecomponent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/6.8.0/QtLabsQmlModels/private/qqmlmodelsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/6.8.0/QtLabsQmlModels/private/qqmltablemodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/6.8.0/QtLabsQmlModels/private/qqmltablemodelcolumn_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/QtLabsQmlModels exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/QtLabsQmlModelsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/QtLabsQmlModelsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/qtlabsqmlmodelsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsQmlModels/qtlabsqmlmodelsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/6.8.0/QtLabsSettings/private/qqmlsettings_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/6.8.0/QtLabsSettings/private/qqmlsettingsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/QtLabsSettings exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/QtLabsSettingsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/QtLabsSettingsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/qtlabssettingsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSettings/qtlabssettingsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/6.8.0/QtLabsSharedImage/private/qsharedimageloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/6.8.0/QtLabsSharedImage/private/qsharedimageprovider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/6.8.0/QtLabsSharedImage/private/qtlabssharedimageglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/QtLabsSharedImage exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/QtLabsSharedImageDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/QtLabsSharedImageVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/qtlabssharedimageexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsSharedImage/qtlabssharedimageversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/6.8.0/QtLabsWavefrontMesh/private/qqmlwavefrontmeshglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/6.8.0/QtLabsWavefrontMesh/private/qwavefrontmesh_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/QtLabsWavefrontMesh exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/QtLabsWavefrontMeshDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/QtLabsWavefrontMeshVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/qtlabswavefrontmeshexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtLabsWavefrontMesh/qtlabswavefrontmeshversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/6.8.0/QtPacketProtocol/private/qpacket_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/6.8.0/QtPacketProtocol/private/qpacketprotocol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/6.8.0/QtPacketProtocol/private/qversionedpacket_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/QtPacketProtocol exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/QtPacketProtocolDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/QtPacketProtocolVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtPacketProtocol/qtpacketprotocolversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/inlinecomponentutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qabstractanimationjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qanimationgroupjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qanimationjobutil_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qbipointer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qcontinuinganimationgroupjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qdoubleendedlist_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qfieldlist_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qfinitestack_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qhashedstring_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qintrusivelist_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qjsengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qjsvalue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qjsvalueiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qlazilyallocated_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qlinkedstringhash_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qml_compile_hash_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qparallelanimationgroupjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qpauseanimationjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qpodvector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qprimefornumbits_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlabstractbinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlabstractprofileradapter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlanybinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlapplicationengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlbinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlboundsignal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlbuiltinfunctions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlbuiltins_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcomponent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcomponentandaliasresolver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcomponentattached_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlconfigurabledebugservice_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcontextdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcppbinding_p.h exists in filesystemqt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcpponassignment_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcpptypehelpers_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlcustomparser_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldatablob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugconnector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugpluginmanager_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugserver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugserverconnection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugservice_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugservicefactory_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugserviceinterfaces_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugstatesdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldebugtranslationprotocol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldelayedcallqueue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldirdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmldirparser_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlenumdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlenumvalue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlexpression_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlextensionplugin_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlfileselector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlfinalizer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlguard_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlguardedcontextdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlimport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlimportresolver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlincubator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlirbuilder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlirloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljavascriptexpression_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsast_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsastfwd_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsastvisitor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsdiagnosticmessage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsfixedpoolarray_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsgrammar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljskeywords_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljslexer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsmemorypool_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljsparser_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmljssourcelocation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmllist_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmllistwrapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmllocale_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlloggingcategorybase_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlmetaobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlmetatype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlmetatypedata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlnotifier_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlnullablevalue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlobjectcreator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlobjectorgadget_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlopenmetaobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlplatform_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpluginimporter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlprofiler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlprofilerdefinitions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlproperty_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertybinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertycache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertycachecreator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertycachemethodarguments_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertycachevector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertydata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertyindex_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertyresolver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertytopropertybinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertyvalidator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlpropertyvalueinterceptor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlproxymetaobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlrefcount_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlscriptblob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlscriptdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlscriptstring_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlsignalnames_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlsourcecoordinate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlstringconverters_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltcobjectcreationhelper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlthread_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltranslation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltype_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypecompiler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypedata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypeloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypeloadernetworkreplyproxy_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypeloaderqmldircontent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypeloaderthread_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypemodule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypemoduleversion_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypenamecache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmltypewrapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlvaluetype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlvaluetypeproxybinding_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlvaluetypewrapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlvme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlvmemetaobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qqmlxmlhttprequest_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qrecursionwatcher_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qrecyclepool_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qsequentialanimationgroupjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qstringhash_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qtqml-config_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qtqmlcompilerglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qtqmlglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4alloca_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4argumentsobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4arraybuffer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4arraydata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4arrayiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4arrayobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4assemblercommon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4atomics_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4baselineassembler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4baselinejit_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4booleanobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4bytecodegenerator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4bytecodehandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4calldata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4codegen_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compilationunitmapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compileddata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compiler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compilercontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compilercontrolflow_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compilerglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4compilerscanfunctions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4context_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4dataview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4dateobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4debugging_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4domerrors_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4engine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4enginebase_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4errorobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4estable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4executableallocator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4executablecompilationunit_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4function_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4functionobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4functiontable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4generatorobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4global_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4globalobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4heap_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4identifierhash_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4identifierhashdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4identifiertable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4include_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4instr_moth_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4internalclass_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4iterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4jscall_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4jsonobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4lookup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4managed_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4mapiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4mapobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4math_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4mathobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4memberdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4mm_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4mmdefs_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4module_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4numberobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4object_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4objectiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4objectproto_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4persistent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4profiling_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4promiseobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4property_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4propertykey_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4proxy_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4qmetaobjectwrapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4qmlcontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4qobjectwrapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4referenceobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4reflect_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4regexp_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4regexpobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4resolvedtypereference_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4runtime_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4runtimeapi_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4runtimecodegen_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4scopedvalue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4script_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4sequenceobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4setiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4setobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4sparsearray_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4sqlerrors_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4stackframe_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4stacklimits_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4staticvalue_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4string_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4stringiterator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4stringobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4stringtoarrayindex_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4symbol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4typedarray_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4urlobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4util_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4value_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4variantobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4vme_moth_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4vtable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/6.8.0/QtQml/private/qv4writebarrier_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSEngine exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSList exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSListForInIterator exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSListForOfIterator exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSListIndexClamp exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSManagedValue exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSNumberCoercion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSPrimitiveValue exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSValue exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSValueIterator exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QJSValueList exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlAbstractUrlInterceptor exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlApplicationEngine exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlComponent exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlContext exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlDebuggingEnabler exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlEngine exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlEngineExtensionInterface exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlEngineExtensionPlugin exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlError exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlExpression exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlExtensionInterface exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlExtensionPlugin exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlFile exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlFileSelector exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlImageProviderBase exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlIncubationController exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlIncubator exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlInfo exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlListProperty exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlListReference exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlModuleRegistration exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlNetworkAccessManagerFactory exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlParserStatus exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlProperties exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlProperty exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlPropertyMap exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlPropertyValueSource exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlScriptString exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlTypeInfo exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlTypeNotAvailable exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QQmlTypesExtensionInterface exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QtQml exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QtQmlDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/QtQmlVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsengine.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjslist.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsmanagedvalue.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsnumbercoercion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsprimitivevalue.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsvalue.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qjsvalueiterator.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqml.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlabstracturlinterceptor.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlapplicationengine.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlcomponent.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlcontext.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmldebug.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlengine.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlerror.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlexpression.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlextensioninterface.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlextensionplugin.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlfile.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlfileselector.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlincubator.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlinfo.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmllist.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlmoduleregistration.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlnetworkaccessmanagerfactory.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlparserstatus.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlprivate.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlproperty.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlpropertymap.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlpropertyvaluesource.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlregistration.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qqmlscriptstring.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qtqml-config.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qtqmlcompilerglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qtqmlexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qtqmlglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQml/qtqmlversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlAssetDownloader/6.8.0/QtQmlAssetDownloader/private/qqmlassetdownloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlAssetDownloader/QtQmlAssetDownloader exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlAssetDownloader/QtQmlAssetDownloaderDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlAssetDownloader/QtQmlAssetDownloaderVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlAssetDownloader/qtqmlassetdownloaderversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qcoloroutput_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qdeferredpointer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsannotation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsbasicblocks_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscodegenerator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscompilepass_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscompiler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscompilerstats_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscompilerstatsreporter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljscontextualtypes_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsfunctioninitializer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsimporter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsimportvisitor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljslinter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljslintercodegen_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsliteralbindingcheck_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsloadergenerator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljslogger_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsloggingutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsmetatypes_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsoptimizations_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsregistercontent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsresourcefilemapper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsscope_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsscopesbyid_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsshadowcheck_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsstoragegeneralizer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljstypedescriptionreader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljstypepropagator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljstypereader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljstyperesolver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmljsvaluetypefromstringcheck_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmlsa_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qqmlsasourcelocation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/6.8.0/QtQmlCompiler/private/qresourcerelocater_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/QtQmlCompiler exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/QtQmlCompilerDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/QtQmlCompilerVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qqmljsloggingutils.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qqmlsa.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qqmlsaconstants.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qqmlsasourcelocation.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qtqmlcompilerexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCompiler/qtqmlcompilerversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/6.8.0/QtQmlCore/private/qqmlcoreglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/6.8.0/QtQmlCore/private/qqmlpermissions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/6.8.0/QtQmlCore/private/qqmlsettings_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/6.8.0/QtQmlCore/private/qqmlstandardpaths_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/6.8.0/QtQmlCore/private/qqmlsysteminformation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/QtQmlCore exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/QtQmlCoreDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/QtQmlCoreVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/qtqmlcoreexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlCore/qtqmlcoreversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmldebugclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmldebugclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmldebugconnection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmldebugmessageclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmldebugtranslationclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlenginecontrolclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlenginecontrolclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlenginedebugclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlenginedebugclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlinspectorclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlinspectorclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlpreviewclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlpreviewclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilerclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilerclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilerclientdefinitions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilerevent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilereventlocation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilereventreceiver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilereventtype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qqmlprofilertypedevent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qv4debugclient_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/6.8.0/QtQmlDebug/private/qv4debugclient_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/QtQmlDebug exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/QtQmlDebugDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/QtQmlDebugVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDebug/qtqmldebugversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldom_fwd_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldom_utils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomastcreator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomastdumper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomattachedinfo_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomcodeformatter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomcomments_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomcompare_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomconstants_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomelements_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomerrormessage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomexternalitems_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomfieldfilter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomfilewriter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomfunctionref_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomindentinglinewriter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomlinewriter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldommock_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldommoduleindex_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomoutwriter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldompath_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomreformatter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomscanner_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomscriptelements_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomstringdumper_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomtop_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/6.8.0/QtQmlDom/private/qqmldomtypesreader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/QtQmlDom exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/QtQmlDomDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/QtQmlDomVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/qqmldom_global.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlDom/qtqmldomversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlIntegration/QtQmlIntegration exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlIntegration/QtQmlIntegrationDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlIntegration/QtQmlIntegrationVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlIntegration/qqmlintegration.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlIntegration/qtqmlintegrationversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qdochtmlparser_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qlanguageserver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qlspcustomtypes_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlbasemodule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlcodemodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlcompletioncontextstrings_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlcompletionsupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlfindusagessupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlformatting_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlgotodefinitionsupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlgototypedefinitionsupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlhighlightsupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlhover_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllanguageserver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllintsuggestions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllscompletion_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllscompletionplugin_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllshelpplugininterface_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllshelputils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllsplugin_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmllsutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlrangeformatting_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlrenamesymbolsupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qqmlsemantictokens_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qtextblock_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qtextcursor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qtextdocument_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qtextsynchronization_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/6.8.0/QtQmlLS/private/qworkspace_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/QtQmlLS exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/QtQmlLSDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/QtQmlLSVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLS/qtqmllsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/6.8.0/QtQmlLocalStorage/private/qqmllocalstorage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/6.8.0/QtQmlLocalStorage/private/qqmllocalstorageglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/QtQmlLocalStorage exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/QtQmlLocalStorageDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/QtQmlLocalStorageVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/qtqmllocalstorageexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlLocalStorage/qtqmllocalstorageversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmlbind_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmlconnections_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmllocaleenums_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmlloggingcategory_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmlmetadependencies_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/6.8.0/QtQmlMeta/private/qqmltimer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/QtQmlMeta exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/QtQmlMetaDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/QtQmlMetaVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/qtqmlmetaexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlMeta/qtqmlmetaversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlabstractdelegatecomponent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmladaptormodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmladaptormodelenginedata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlchangeset_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmldelegatemodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmldelegatemodel_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmldmabstractitemmodeldata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmldmlistaccessordata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmldmobjectdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlinstantiator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlinstantiator_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmllistaccessor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmllistcompositor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmllistmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmllistmodel_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmllistmodelworkeragent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlmodelindexvaluetype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlmodelsmodule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmlobjectmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmltableinstancemodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qqmltreemodeltotablemodel_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qquickpackage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qtqmlmodels-config_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/6.8.0/QtQmlModels/private/qtqmlmodelsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/QtQmlModels exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/QtQmlModelsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/QtQmlModelsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/qtqmlmodels-config.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/qtqmlmodelsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/qtqmlmodelsglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlModels/qtqmlmodelsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/6.8.0/QtQmlNetwork/private/qqmlnetworkinformation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/6.8.0/QtQmlNetwork/private/qqmlsslconfiguration_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/6.8.0/QtQmlNetwork/private/qqmlsslkey_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/6.8.0/QtQmlNetwork/private/qqmlsslnamespace_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/6.8.0/QtQmlNetwork/private/qqmlsslsocketnamespace_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/QtQmlNetwork exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/QtQmlNetworkDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/QtQmlNetworkVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/qtqmlnetworkexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlNetwork/qtqmlnetworkversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/6.8.0/QtQmlToolingSettings/private/qqmltoolingsettings_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/6.8.0/QtQmlToolingSettings/private/qqmltoolingutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/QtQmlToolingSettings exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/QtQmlToolingSettingsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/QtQmlToolingSettingsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlToolingSettings/qtqmltoolingsettingsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qanystringviewutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qmetatypesjsonprocessor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmljsstreamwriter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmltyperegistrar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmltyperegistrarconstants_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmltyperegistrarutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmltypesclassdescription_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/6.8.0/QtQmlTypeRegistrar/private/qqmltypescreator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/QtQmlTypeRegistrar exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/QtQmlTypeRegistrarDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/QtQmlTypeRegistrarVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlTypeRegistrar/qtqmltyperegistrarversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/6.8.0/QtQmlWorkerScript/private/qquickworkerscript_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/6.8.0/QtQmlWorkerScript/private/qtqmlworkerscriptglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/6.8.0/QtQmlWorkerScript/private/qv4serialize_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/QtQmlWorkerScript exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/QtQmlWorkerScriptDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/QtQmlWorkerScriptVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/qtqmlworkerscriptexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/qtqmlworkerscriptglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlWorkerScript/qtqmlworkerscriptversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/6.8.0/QtQmlXmlListModel/private/qqmlxmllistmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/6.8.0/QtQmlXmlListModel/private/qtqmlxmllistmodelglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/QtQmlXmlListModel exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/QtQmlXmlListModelDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/QtQmlXmlListModelVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/qtqmlxmllistmodelexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQmlXmlListModel/qtqmlxmllistmodelversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qaccessiblequickitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qaccessiblequickview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qqmldesignermetaobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquadpath_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickabstractpaletteprovider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickaccessibleattached_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickaccessiblefactory_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanchors_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanchors_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatedimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatedimage_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatedsprite_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatedsprite_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimation_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimationcontroller_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimator_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatorcontroller_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickanimatorjob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickapplication_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickbehavior_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickborderimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickborderimage_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcanvascontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcanvasitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickclipnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcolorgroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcontext2d_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcontext2dcommandbuffer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcontext2dtexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickcontext2dtile_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdeliveryagent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdeliveryagent_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignercustomobjectdata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignercustomparserobject_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupportitems_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupportmetainfo_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupportproperties_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupportpropertychanges_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdesignersupportstates_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdrag_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdrag_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdragaxis_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdraghandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickdroparea_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickevents_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickflickable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickflickable_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickflickablebehavior_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickflipable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickfocusscope_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickfontloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickfontmetrics_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickforeignutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickframeanimation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickgraphicsconfiguration_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickgraphicsdevice_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickgraphicsinfo_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickgridview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickhandlerpoint_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickhoverhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimage_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimagebase_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimagebase_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimageprovider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimplicitsizeitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickimplicitsizeitem_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickinputmethod_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemanimation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemanimation_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemchangelistener_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemsmodule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemviewfxitem_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickitemviewtransition_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicklistview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickloader_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickmousearea_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickmousearea_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickmultipointhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickmultipointhandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickmultipointtoucharea_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpainteditem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpalette_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpalettecolorprovider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpaletteproviderprivatebase_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpath_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpath_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpathinterpolator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpathview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpathview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpincharea_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpincharea_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpinchhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpixmap_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpixmapcache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpointerdevicehandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpointerdevicehandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpointerhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpointerhandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpointhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpositioners_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpositioners_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickprofiler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickpropertychanges_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrectangle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrectangle_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrendercontrol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrendertarget_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrepeater_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrepeater_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickrhiitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickscalegrid_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickscreen_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickselectable_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickshadereffect_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickshadereffect_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickshadereffectmesh_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickshadereffectsource_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickshortcut_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksinglepointhandler_p.h exists in filesystem
Part 2
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksinglepointhandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksmoothedanimation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksmoothedanimation_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickspringanimation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksprite_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickspriteengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickspritesequence_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickspritesequence_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstate_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstatechangescript_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstategroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstateoperations_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickstyledtext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksvgparser_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicksystempalette_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktableview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktableview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktaphandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktext_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextcontrol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextcontrol_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextdocument_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextedit_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextedit_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextinput_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextinput_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextinterface_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextmetrics_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextnodeengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextselection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktextutil_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktimeline_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktransition_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktransitionmanager_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktranslate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktreeview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquicktreeview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickvalidator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickvaluetypes_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwheelhandler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwheelhandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwindow_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwindowattached_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwindowcontainer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwindowmodule_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qquickwindowmodule_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgabstractrenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgabstractrenderer_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgabstractsoftwarerenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgadaptationlayer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgareaallocator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgbasicglyphnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgbasicinternalimagenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgbasicinternalrectanglenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgbatchrenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcompressedatlastexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcompressedtexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcontextplugin_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurveabstractnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurvefillnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurvefillnode_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurveglyphatlas_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurveglyphnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurveprocessor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurvestrokenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgcurvestrokenode_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultcontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultglyphnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultglyphnode_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultimagenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultinternalimagenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultinternalrectanglenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultninepatchnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultpainternode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultrectanglenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultrendercontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdefaultspritenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdistancefieldglyphnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgdistancefieldglyphnode_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsggeometry_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsggradientcache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsginternaltextnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgmaterialshader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgnodeupdater_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgplaintexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrenderloop_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrendernode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhiatlastexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhidistancefieldglyphcache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhiinternaltextnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhilayer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhishadereffectnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhisupport_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhitextureglyphcache_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgrhivisualizer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwareadaptation_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarecontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwareglyphnode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwareinternalimagenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwareinternalrectanglenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarelayer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarepainternode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarepixmaprenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarepixmaptexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarepublicnodes_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarerenderablenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarerenderablenodeupdater_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarerenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarerenderlistbuilder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarerenderloop_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarespritenode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgsoftwarethreadedrenderloop_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgtexture_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgtexturematerial_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgtexturereader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgthreadedrenderloop_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qsgtransform_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qtquick-config_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/6.8.0/QtQuick/private/qtquickglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickAsyncImageProvider exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickFramebufferObject exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickGraphicsConfiguration exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickGraphicsDevice exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickImageProvider exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickImageResponse exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickItem exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickItemGrabResult exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickOpenGLUtils exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickPaintedItem exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickRenderControl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickRenderTarget exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickRhiItem exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickRhiItemRenderer exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickTextDocument exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickTextureFactory exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickTransform exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickView exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QQuickWindow exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGBasicGeometryNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGClipNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGDynamicTexture exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGFlatColorMaterial exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGGeometry exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGGeometryNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGImageNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGMaterial exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGMaterialShader exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGNinePatchNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGNodeVisitor exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGOpacityNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGOpaqueTextureMaterial exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGRectangleNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGRenderNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGRendererInterface exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGRootNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGSimpleRectNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGSimpleTextureNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGTextNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGTexture exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGTextureMaterial exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGTextureProvider exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGTransformNode exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QSGVertexColorMaterial exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QtQuick exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QtQuickDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/QtQuickVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickframebufferobject.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickgraphicsconfiguration.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickgraphicsdevice.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickimageprovider.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickitem.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickitemgrabresult.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickopenglutils.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickpainteditem.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickrendercontrol.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickrendertarget.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickrhiitem.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquicktextdocument.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickview.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qquickwindow.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgflatcolormaterial.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsggeometry.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgimagenode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgmaterial.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgmaterialshader.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgmaterialtype.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgninepatchnode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgnode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgrectanglenode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgrendererinterface.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgrendernode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgsimplerectnode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgsimpletexturenode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgtextnode.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgtexture.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgtexture_platform.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgtexturematerial.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgtextureprovider.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qsgvertexcolormaterial.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qtquick-config.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qtquickexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qtquickglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuick/qtquickversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/6.8.0/QtQuickControls2/private/qquickstyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/6.8.0/QtQuickControls2/private/qquickstyleplugin_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/6.8.0/QtQuickControls2/private/qtquickcontrols2-config_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/QQuickAttachedPropertyPropagator exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/QQuickStyle exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/QtQuickControls2 exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/QtQuickControls2Depends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/QtQuickControls2Version exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qquickattachedpropertypropagator.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qquickstyle.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qtquickcontrols2-config.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qtquickcontrols2exports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qtquickcontrols2global.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2/qtquickcontrols2version.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/6.8.0/QtQuickControls2Basic/private/qquickbasicstyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/6.8.0/QtQuickControls2Basic/private/qquickbasictheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/6.8.0/QtQuickControls2Basic/private/qtquickcontrols2basicforeign_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/QtQuickControls2Basic exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/QtQuickControls2BasicDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/QtQuickControls2BasicVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/qtquickcontrols2basicexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Basic/qtquickcontrols2basicversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/6.8.0/QtQuickControls2BasicStyleImpl/private/qquickbasicbusyindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/6.8.0/QtQuickControls2BasicStyleImpl/private/qquickbasicdial_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/6.8.0/QtQuickControls2BasicStyleImpl/private/qquickbasicprogressbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/QtQuickControls2BasicStyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/QtQuickControls2BasicStyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/QtQuickControls2BasicStyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/qtquickcontrols2basicstyleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2BasicStyleImpl/qtquickcontrols2basicstyleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/6.8.0/QtQuickControls2FluentWinUI3StyleImpl/private/qquickfluentwinui3focusstroke_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/QtQuickControls2FluentWinUI3StyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/QtQuickControls2FluentWinUI3StyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/QtQuickControls2FluentWinUI3StyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/qtquickcontrols2fluentwinui3styleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FluentWinUI3StyleImpl/qtquickcontrols2fluentwinui3styleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/6.8.0/QtQuickControls2Fusion/private/qquickfusionstyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/6.8.0/QtQuickControls2Fusion/private/qquickfusiontheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/QtQuickControls2Fusion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/QtQuickControls2FusionDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/QtQuickControls2FusionVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/qtquickcontrols2fusionexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Fusion/qtquickcontrols2fusionversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/6.8.0/QtQuickControls2FusionStyleImpl/private/qquickfusionbusyindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/6.8.0/QtQuickControls2FusionStyleImpl/private/qquickfusiondial_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/6.8.0/QtQuickControls2FusionStyleImpl/private/qquickfusionknob_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/QtQuickControls2FusionStyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/QtQuickControls2FusionStyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/QtQuickControls2FusionStyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/qtquickcontrols2fusionstyleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2FusionStyleImpl/qtquickcontrols2fusionstyleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/6.8.0/QtQuickControls2Imagine/private/qquickimaginestyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/6.8.0/QtQuickControls2Imagine/private/qquickimaginetheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/QtQuickControls2Imagine exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/QtQuickControls2ImagineDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/QtQuickControls2ImagineVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/qtquickcontrols2imagineexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Imagine/qtquickcontrols2imagineversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2ImagineStyleImpl/QtQuickControls2ImagineStyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2ImagineStyleImpl/QtQuickControls2ImagineStyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2ImagineStyleImpl/QtQuickControls2ImagineStyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2ImagineStyleImpl/qtquickcontrols2imaginestyleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2ImagineStyleImpl/qtquickcontrols2imaginestyleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickanimatednode_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickchecklabel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickclippedtext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickcolor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickcolorimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickiconimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickiconimage_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickiconlabel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickiconlabel_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickimageselector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickitemgroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickmnemoniclabel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickninepatchimage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickpaddedrectangle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickplaceholdertext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquickplatformtheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qquicktumblerview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/6.8.0/QtQuickControls2Impl/private/qtquickcontrols2implglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/QtQuickControls2Impl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/QtQuickControls2ImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/QtQuickControls2ImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/qtquickcontrols2implexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Impl/qtquickcontrols2implversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/6.8.0/QtQuickControls2Material/private/qquickmaterialstyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/6.8.0/QtQuickControls2Material/private/qquickmaterialtheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/QtQuickControls2Material exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/QtQuickControls2MaterialDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/QtQuickControls2MaterialVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/qtquickcontrols2materialexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Material/qtquickcontrols2materialversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/6.8.0/QtQuickControls2MaterialStyleImpl/private/qquickmaterialbusyindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/6.8.0/QtQuickControls2MaterialStyleImpl/private/qquickmaterialplaceholdertext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/6.8.0/QtQuickControls2MaterialStyleImpl/private/qquickmaterialprogressbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/6.8.0/QtQuickControls2MaterialStyleImpl/private/qquickmaterialripple_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/6.8.0/QtQuickControls2MaterialStyleImpl/private/qquickmaterialtextcontainer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/QtQuickControls2MaterialStyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/QtQuickControls2MaterialStyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/QtQuickControls2MaterialStyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/qtquickcontrols2materialstyleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2MaterialStyleImpl/qtquickcontrols2materialstyleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/6.8.0/QtQuickControls2Universal/private/qquickuniversalstyle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/6.8.0/QtQuickControls2Universal/private/qquickuniversaltheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/QtQuickControls2Universal exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/QtQuickControls2UniversalDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/QtQuickControls2UniversalVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/qtquickcontrols2universalexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2Universal/qtquickcontrols2universalversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/6.8.0/QtQuickControls2UniversalStyleImpl/private/qquickuniversalbusyindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/6.8.0/QtQuickControls2UniversalStyleImpl/private/qquickuniversalfocusrectangle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/6.8.0/QtQuickControls2UniversalStyleImpl/private/qquickuniversalprogressbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/QtQuickControls2UniversalStyleImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/QtQuickControls2UniversalStyleImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/QtQuickControls2UniversalStyleImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/qtquickcontrols2universalstyleimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControls2UniversalStyleImpl/qtquickcontrols2universalstyleimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/6.8.0/QtQuickControlsTestUtils/private/controlstestutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/6.8.0/QtQuickControlsTestUtils/private/dialogstestutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/6.8.0/QtQuickControlsTestUtils/private/qtest_quickcontrols_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/QtQuickControlsTestUtils exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/QtQuickControlsTestUtilsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/QtQuickControlsTestUtilsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickControlsTestUtils/qtquickcontrolstestutilsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickabstractdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickcolordialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickfiledialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickfolderdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickfontdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qquickmessagedialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qtquickdialogs2foreign_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/6.8.0/QtQuickDialogs2/private/qtquickdialogs2global_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/QtQuickDialogs2 exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/QtQuickDialogs2Depends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/QtQuickDialogs2Version exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/qtquickdialogs2exports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2/qtquickdialogs2version.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickabstractcolorpicker_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickabstractcolorpicker_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickcolordialogimpl_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickcolordialogimpl_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickcolordialogutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickcolorinputs_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickdialogimplfactory_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfiledialogdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfiledialogimpl_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfiledialogimpl_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfolderbreadcrumbbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfolderbreadcrumbbar_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfolderdialogimpl_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfolderdialogimpl_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfontdialogimpl_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickfontdialogimpl_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickmessagedialogimpl_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickmessagedialogimpl_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickplatformcolordialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickplatformfiledialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickplatformfolderdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickplatformfontdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquickplatformmessagedialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qquicksaturationlightnesspicker_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qtquickdialogs2quickimplforeign_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/6.8.0/QtQuickDialogs2QuickImpl/private/qtquickdialogs2quickimplglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/QtQuickDialogs2QuickImpl exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/QtQuickDialogs2QuickImplDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/QtQuickDialogs2QuickImplVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/qtquickdialogs2quickimplexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2QuickImpl/qtquickdialogs2quickimplversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/6.8.0/QtQuickDialogs2Utils/private/qquickdialogtype_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/6.8.0/QtQuickDialogs2Utils/private/qquickfilenamefilter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/6.8.0/QtQuickDialogs2Utils/private/qtquickdialogs2utilsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/QtQuickDialogs2Utils exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/QtQuickDialogs2UtilsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/QtQuickDialogs2UtilsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/qtquickdialogs2utilsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickDialogs2Utils/qtquickdialogs2utilsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/6.8.0/QtQuickEffects/private/qgfxsourceproxy_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/6.8.0/QtQuickEffects/private/qquickmultieffect_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/6.8.0/QtQuickEffects/private/qquickmultieffect_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/6.8.0/QtQuickEffects/private/qtquickeffectsglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/QtQuickEffects exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/QtQuickEffectsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/QtQuickEffectsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/qtquickeffectsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickEffects/qtquickeffectsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquickgridlayoutengine_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquicklayout_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquicklayoutglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquicklayoutitemproxy_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquicklayoutstyleinfo_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquicklinearlayout_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/6.8.0/QtQuickLayouts/private/qquickstacklayout_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/QtQuickLayouts exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/QtQuickLayoutsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/QtQuickLayoutsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/qtquicklayoutsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickLayouts/qtquicklayoutsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickangledirection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickcumulativedirection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickcustomaffector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickdirection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickellipseextruder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickfriction_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickgravity_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickgroupgoal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickimageparticle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickitemparticle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquicklineextruder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickmaskextruder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticleaffector_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticleemitter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticleextruder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticlegroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticlepainter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickparticlesystem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickpointattractor_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickpointdirection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickrectangleextruder_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickspritegoal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquicktargetdirection_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquicktrailemitter_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickturbulence_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickv4particledata_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qquickwander_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/6.8.0/QtQuickParticles/private/qtquickparticlesglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/QtQuickParticles exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/QtQuickParticlesDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/QtQuickParticlesVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/qtquickparticlesexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickParticles/qtquickparticlesversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshape_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshape_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshapecurverenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshapecurverenderer_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshapegenericrenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshapesglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/6.8.0/QtQuickShapes/private/qquickshapesoftwarerenderer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/QtQuickShapes exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/QtQuickShapesDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/QtQuickShapesVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/qquickshapesglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/qtquickshapesexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickShapes/qtquickshapesversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qaccessiblequickpage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickabstractbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickabstractbutton_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickaction_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickactiongroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickapplicationwindow_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickbusyindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickbutton_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickbuttongroup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcalendar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcalendarmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcheckbox_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcheckdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcombobox_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcontainer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcontainer_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcontentitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcontrol_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickcontrol_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdayofweekmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdayofweekrow_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdeferredexecute_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdeferredpointer_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdelaybutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdial_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdialog_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdialog_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdialogbuttonbox_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdialogbuttonbox_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdrawer_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickdrawer_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickframe_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickframe_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickgroupbox_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickheaderview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickheaderview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickicon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickindicatorbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickitemdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickitemdelegate_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicklabel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicklabel_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenu_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenu_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenubar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenubar_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenubaritem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenubaritem_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenuitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenuitem_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmenuseparator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmonthgrid_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickmonthmodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicknativeicon_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicknativeiconloader_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicknativemenuitem_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickoverlay_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickoverlay_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpage_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpage_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpageindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpane_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpane_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopup_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopup_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopupanchors_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopupanchors_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopupitem_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopuppositioner_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpopupwindow_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickpresshandler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickprogressbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickradiobutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickradiodelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickrangeslider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickroundbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickscrollbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickscrollbar_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickscrollindicator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickscrollview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickselectionrectangle_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickselectionrectangle_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickshortcutcontext_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickslider_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickspinbox_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicksplitview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickstackelement_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickstacktransition_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickstackview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickstackview_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswipe_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswipedelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswipedelegate_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswipeview_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswitch_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickswitchdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktabbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktabbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktextarea_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktextarea_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktextfield_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktextfield_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktheme_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktheme_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktoolbar_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktoolbutton_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktoolseparator_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktooltip_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktreeviewdelegate_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktumbler_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquicktumbler_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickvelocitycalculator_p_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickweeknumbercolumn_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qquickweeknumbermodel_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qtquicktemplates2-config_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/6.8.0/QtQuickTemplates2/private/qtquicktemplates2global_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/QtQuickTemplates2 exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/QtQuickTemplates2Depends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/QtQuickTemplates2Version exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/qtquicktemplates2-config.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/qtquicktemplates2exports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTemplates2/qtquicktemplates2version.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/qtestoptions_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/quicktest_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/quicktestevent_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/quicktestglobal_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/quicktestresult_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/6.8.0/QtQuickTest/private/quicktestutil_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/QtQuickTest exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/QtQuickTestDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/QtQuickTestVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/qtquicktestexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/qtquicktestversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/quicktest.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTest/quicktestglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/geometrytestutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/platforminputcontext_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/platformquirks_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/qmlutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/testhttpserver_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/viewtestutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/6.8.0/QtQuickTestUtils/private/visualtestutils_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/QtQuickTestUtils exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/QtQuickTestUtilsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/QtQuickTestUtilsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickTestUtils/qtquicktestutilsversion.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/6.8.0/QtQuickWidgets/private/qaccessiblequickwidget_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/6.8.0/QtQuickWidgets/private/qaccessiblequickwidgetfactory_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/6.8.0/QtQuickWidgets/private/qquickwidget_p.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/QQuickWidget exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/QtQuickWidgets exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/QtQuickWidgetsDepends exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/QtQuickWidgetsVersion exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/qquickwidget.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/qtquickwidgetsexports.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/qtquickwidgetsglobal.h exists in filesystem
qt6-declarative: /usr/include/qt6/QtQuickWidgets/qtquickwidgetsversion.h exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6BuildInternals/StandaloneTests/QtDeclarativeTestsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsAnimation/Qt6LabsAnimationVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsFolderListModel/Qt6LabsFolderListModelVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsPlatform/Qt6LabsPlatformVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsQmlModels/Qt6LabsQmlModelsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSettings/Qt6LabsSettingsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsSharedImage/Qt6LabsSharedImageVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6LabsWavefrontMesh/Qt6LabsWavefrontMeshVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6PacketProtocolPrivate/Qt6PacketProtocolPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6LabsPlatformpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlAssetDownloaderpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QmlNetworkpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickControlsTestUtilsPrivatepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6QuickTestpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6effectspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsanimationpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginTargets-relwithdebinfo.cmake exists in filesystem
Part 3 (the end of this is roughly two thirds of the way through the code that shows up)
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6labsmodelspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6modelspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6particlespluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlfolderlistmodelpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmllocalstoragepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlsettingspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlshapespluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlwavefrontmeshpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qmlxmllistmodelpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qquicklayoutspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtqmlcorepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquick2pluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstyleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2basicstylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3styleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fluentwinui3stylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstyleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2fusionstylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestyleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2imaginestylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2implpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstyleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2materialstylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2nativestylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2pluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstyleimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickcontrols2universalstylepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogs2quickimplpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquickdialogspluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6qtquicktemplates2pluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quicktoolingTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6quickwindowTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6sharedimagepluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/QmlPlugins/Qt6workerscriptpluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QDebugMessageServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QLocalClientConnectionFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebugServerFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlDebuggerServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlInspectorServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugConnectorFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlNativeDebugServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlPreviewServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQmlProfilerServiceFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QQuickProfilerAdapterFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QTcpServerConnectionFactoryPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlBuildInternals.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlConfigExtras.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlDeploySupport.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlFindQmlscInternal.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlMacros.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlModuleDirMappingTemplate.qrc.in exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlPluginTemplate.cpp.in exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlPlugins.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlPublicCMakeHelpers.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmlVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6QmltcFileMappingTemplate.qrc.in exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6qmldirTemplate.cmake.in exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Qml/Qt6qt.conf.in exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlAssetDownloader/Qt6QmlAssetDownloaderVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerPlugins.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlCompilerVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCompiler/Qt6QmlLintQuickPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlCore/Qt6QmlCoreVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDebugPrivate/Qt6QmlDebugPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlDomPrivate/Qt6QmlDomPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlImportScanner/Qt6QmlImportScannerConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlImportScanner/Qt6QmlImportScannerConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlImportScanner/Qt6QmlImportScannerConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlImportScanner/Qt6QmlImportScannerDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlIntegration/Qt6QmlIntegrationVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivatePlugins.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLSPrivate/Qt6QmlLSQuickPluginTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlLocalStorage/Qt6QmlLocalStorageVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlMeta/Qt6QmlMetaVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlModels/Qt6QmlModelsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlNetwork/Qt6QmlNetworkVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlToolingSettingsPrivate/Qt6QmlToolingSettingsPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTools/Qt6QmlToolsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlTypeRegistrarPrivate/Qt6QmlTypeRegistrarPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlWorkerScript/Qt6QmlWorkerScriptVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QmlXmlListModel/Qt6QmlXmlListModelVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickPlugins.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6Quick/Qt6QuickVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2AdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2Config.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2ConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2ConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2Dependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2Targets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2Targets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2VersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2/Qt6QuickControls2VersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Basic/Qt6QuickControls2BasicVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2BasicStyleImpl/Qt6QuickControls2BasicStyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FluentWinUI3StyleImpl/Qt6QuickControls2FluentWinUI3StyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Fusion/Qt6QuickControls2FusionVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2FusionStyleImpl/Qt6QuickControls2FusionStyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Imagine/Qt6QuickControls2ImagineVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2ImagineStyleImpl/Qt6QuickControls2ImagineStyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Impl/Qt6QuickControls2ImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Material/Qt6QuickControls2MaterialVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2MaterialStyleImpl/Qt6QuickControls2MaterialStyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2Universal/Qt6QuickControls2UniversalVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControls2UniversalStyleImpl/Qt6QuickControls2UniversalStyleImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickControlsTestUtilsPrivate/Qt6QuickControlsTestUtilsPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2AdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2Config.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2ConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2ConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2Dependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2Targets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2Targets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2VersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2/Qt6QuickDialogs2VersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplTargets-relwithdebinfo.cmake exists in filesystemqt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2QuickImpl/Qt6QuickDialogs2QuickImplVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickDialogs2Utils/Qt6QuickDialogs2UtilsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickEffectsPrivate/Qt6QuickEffectsPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickLayouts/Qt6QuickLayoutsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickParticlesPrivate/Qt6QuickParticlesPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateAdditionalTargetInfo.cmake exists in filesystemqt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickShapesPrivate/Qt6QuickShapesPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2AdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2Config.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2ConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2ConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2Dependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2Targets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2Targets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2VersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTemplates2/Qt6QuickTemplates2VersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTest/Qt6QuickTestVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickTestUtilsPrivate/Qt6QuickTestUtilsPrivateVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsAdditionalTargetInfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsConfig.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsConfigVersion.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsConfigVersionImpl.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsDependencies.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsTargets-relwithdebinfo.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsVersionlessAliasTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/cmake/Qt6QuickWidgets/Qt6QuickWidgetsVersionlessTargets.cmake exists in filesystem
qt6-declarative: /usr/lib/libQt6LabsAnimation.prl exists in filesystem
qt6-declarative: /usr/lib/libQt6LabsAnimation.so exists in filesystem
qt6-declarative: /usr/lib/libQt6LabsAnimation.so.6 exists in filesystem
qt6-declarative: /usr/lib/libQt6LabsAnimation.so.6.8.0 exists in filesystem
qt6-declarative: /usr/lib/libQt6LabsFolderListModel.prl exists in filesystem
