Manual partitioning with btrfs
Hi
I am a Manjaro user, and I try to install the same as Manjaro in manual partitioning;
first, install Windows on 25% of 4TB of disk, and after it, try to install endeavors with manual partitioning
  1. use btrfs for root mount set \ & set root flag
  2. use windows efi as efi
I have an error in setting the bootloader at the end of the installation …
But try to install a clean disk with btrfs in clean installation work as a charm …
Have any advice for manual partitioning with btrfs?
Make sure you choose grub as your bootloader if you want to use the tiny WIndows EFI partition. Also, make sure you have fast startup disabled in windows. If you don’t disable that, the EFI partition will be marked dirty and be read-only preventing the bootloader from installing.
