Specifically no! In general, I followed mostly stuff from :
On/off-topic
It’s the first time trying an Arch-based distribution, and I was playing around quite a bit. I didn’t take care to note things down. Now that I like the system, I am trying to iron out problems/annoyances.
Issues :
suspend/hibernate – first asked at Configure encrypt and resume hooks for mkinitcpio ,
encryption related – solved at Passphrase for LUKS encrypted partitions asked twice during boot - #6 by NikosAlexandris ,
I do this Black screen after login - #14 by NikosAlexandris to work around the black screen after login
there is also these systemd stuff for the nvidia driver?
usr/lib/systemd/system/nvidia-hibernate.service
usr/lib/systemd/system/nvidia-persistenced.service
usr/lib/systemd/system/nvidia-powerd.service
usr/lib/systemd/system/nvidia-resume.service
usr/lib/systemd/system/nvidia-suspend.service
Echoa
January 28, 2023, 9:25pm
23
What is your motherboard manufacturer/system manufacturer?
Certain ones you basically need to give up on hibernation and suspend will be a coin toss
Gigabyte for instance is notorious for broken acpi, hibernation, and questionable suspend on anything but windows and when told about it will dismiss the issue as won’t fix
mine had issues with hibernation and suspend too but currently working nicely… gigabyte B550 GAMING X V2
only to validate by false proof indeed
Echoa
January 28, 2023, 11:39pm
25
not one of my gigabyte boards has ever been able to hibernate/suspend successfully
I have a timer setup to shut the system down instead as suspend causes issues with acpi and hibernation just failed to resume. Ive tried with Gigabyte for 10yrs now to have it work so next time i might go with Asus for better luck
The motherboard of a ThinkPad T14, 1st Gen with an Intel CPU. See https://psref.lenovo.com/Product/ThinkPad/ThinkPad_T14_Gen_1_Intel .
Suspend was working in the beginning. With Gnome and Xorg, I think!
Echoa
January 29, 2023, 9:08am
27
That system should be good with it, i just wanted to make sure youre not beat a dead horse lol
the thinkpad line usually does fairly well ootb on linux with little issues that are hardware related.
After some latest updates, suspend and resume works . What is still a bit weird, I have to sort of close-open quickly the lid, right after waking up from sleep, to get to see the lock screen from which I can unlock and continue working.
Again in trying to explain it correctly: the system suspends, wakes up after opening the lid but the screen is still black at that point. Connecting to an external display, or else, switching to another virtual terminal, ensured that it’s just a matter of the display to power-up. Then, a quick close-open action, or approaching the lid to close but not really closing it, is what power’s up the display correctly. This is the last annoyance I experience.
Some “context”, maybe it’ll be useful for someone.
sudo lsinitrd | grep resume
resume
-rwxr-xr-x 1 root root 14288 May 7 17:30 usr/lib/systemd/systemd-hibernate-resume
-rwxr-xr-x 1 root root 14520 May 7 17:30 usr/lib/systemd/system-generators/systemd-hibernate-resume-generator
-rw-r--r-- 1 root root 680 May 7 17:30 usr/lib/systemd/system/systemd-hibernate-resume@.service
The standard logind.conf
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#UserStopDelaySec=10
#HandlePowerKey=poweroff
#HandlePowerKeyLongPress=ignore
#HandleRebootKey=reboot
#HandleRebootKeyLongPress=poweroff
#HandleSuspendKey=suspend
#HandleSuspendKeyLongPress=hibernate
#HandleHibernateKey=hibernate
#HandleHibernateKeyLongPress=ignore
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
#HandleLidSwitchDocked=ignore
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=yes
#RebootKeyIgnoreInhibited=no
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodesMax=
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
#StopIdleSessionSec=infinity
inxi -Fxxxz
Kernel: 6.3.6-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
Desktop: sway v: 1.8.1 info: waybar vt: 2 dm: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Laptop System: LENOVO product: 20S0CTO1WW v: ThinkPad T14 Gen 1
Mobo: LENOVO model: 20S0CTO1WW serial: <superuser required> UEFI: LENOVO
v: N2XET23W (1.13 ) date: 08/26/2020
Battery:
ID-1: BAT0 charge: 35.9 Wh (85.1%) condition: 42.2/51.0 Wh (82.8%)
volts: 11.9 min: 11.5 model: Celxpert 5B10W13954 type: Li-poly
serial: <filter> status: discharging cycles: 845
Info: quad core model: Intel Core i7-10610U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 512 KiB
L2: 2 MiB L3: 64 MiB
Speed (MHz): avg: 1492 high: 2300 min/max: 400/4900 cores: 1: 2300 2: 2300
3: 2300 4: 2300 5: 700 6: 656 7: 687 8: 695 bogomips: 36812
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 ports: active: HDMI-A-2,eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Lenovo driver: nvidia
v: 530.41.03 arch: Pascal pcie: speed: 2.5 GT/s lanes: 4 bus-ID: 2d:00.0
chip-ID: 10de:1d16 class-ID: 0302
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-8:3 chip-ID: 04f2:b6d0 class-ID: fe01
serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: sway v: 1.8.1 driver: X: loaded: intel,nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: i965 gpu: i915
d-rect: 5760x2160 display-ID: 1
Monitor-1: HDMI-A-2 pos: primary,left model: LG (GoldStar) TV SSCR2
serial: <filter> res: 1920x1080 hz: 60 dpi: 30 scale: 1
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 pos: right model: BOE Display 0x08ce res: 3840x2160
hz: 60 dpi: 316 scale: 2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
modes: 3840x2160
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0403
API: ALSA v: k6.3.6-arch1-1 status: kernel-api
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4e class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: disabled
Local Storage: total: 1.82 TiB used: 485.88 GiB (26.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
size: 1.82 TiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
ID-1: / size: 125.43 GiB used: 41.52 GiB (33.1%) fs: ext4 dev: /dev/dm-0
mapped: luks-a9001606-80a3-47d8-bc48-e2a79a3a95be
ID-2: /boot/efi size: 1022 MiB used: 472 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 125.43 GiB used: 94.4 GiB (75.3%) fs: ext4
dev: /dev/dm-2 mapped: luks-03e0680d-6510-4bda-a1c2-698e71e0448a
ID-1: swap-1 type: partition size: 93.63 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 mapped: luks-0b2e5609-b174-45aa-875c-727ae046ea13
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 411 Uptime: 1d 8h 22m wakeups: 944 Memory: available: 46.81 GiB
used: 14.26 GiB (30.5%) Init: systemd v: 253 default: graphical Compilers:
gcc: 13.1.1 clang: 15.0.7 Packages: 1861 pm: pacman pkgs: 1851 pm: flatpak
pkgs: 10 Shell: Bash v: 5.1.16 running-in: terminology inxi: 3.3.27
Defaults in /etc/systemd/sleep.conf
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendMode=
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#HibernateState=disk
#HybridSleepMode=suspend platform shutdown
#HybridSleepState=disk
#HibernateDelaySec=
#SuspendEstimationSec=60min
Relevant environment variables
WAYBAR_WEATHER_UNITS=metric
QT_WAYLAND_DISABLE_WINDOWDECORATION=1
I3SOCK=/run/user/1000/sway-ipc.1000.1493.sock
XDG_SESSION_TYPE=wayland
WAYBAR_WEATHER_EXCLUDE=minutely,hourly,daily
XDG_CURRENT_DESKTOP=sway
SWAYSOCK=/run/user/1000/sway-ipc.1000.1493.sock
WAYLAND_DISPLAY=wayland-1
WAYBAR_WEATHER_LAT=45.799
QT_QPA_PLATFORM=wayland
WAYBAR_WEATHER_APIKEY=5ad143b61b08cba5670f6eb5fcc20a8a
MOZ_ENABLE_WAYLAND=1
WAYBAR_WEATHER_LON=8.643
QT_AUTO_SCREEN_SCALE_FACTOR=1
Under /etc/dracut.conf.d/
calamares-luks.conf
# force installing /etc/crypttab even if hostonly="no", install the keyfile
install_items+=" /etc/crypttab /crypto_keyfile.bin "
# enable automatic resume from swap
add_device+=" /dev/disk/by-uuid/0b2e5609-b174-45aa-875c-727ae046ea13 "
eos-defaults.conf
omit_dracutmodules+=" network "
compress="zstd"
resume.conf
add_dracutmodules+=" resume "
nvidia.conf
force_drivers+=" nvidia nvidia_modeset nvidia_uvm nvidia_drm "
ostree.conf
add_dracutmodules+=" ostree systemd "
reproducible=yes
swap partition
/dev/mapper/luks-0b2e5609-b174-45aa-875c-727ae046ea13 swap swap defaults 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
/etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT='nowatchdog nvme_load=YES rd.luks.uuid=a9001606-80a3-47d8-bc48-e2a79a3a95be rd.luks.uuid=0b2e5609-b174-45aa-875c-727ae046ea13 resume=/dev/mapper/luks-0b2e5609-b174-45aa-875c-727ae046ea13 loglevel=3 rd.driver.blacklist=nouveau nvidia-drm.modeset=1'
Closing this issue.
