To begin with, I am running on
./o. nik@t14
./sssso- -------
`:osssssss+- OS: EndeavourOS Linux x86_64
`:+sssssssssso/. Host: 20S0CTO1WW ThinkPad T14 Gen 1
`-/ossssssssssssso/. Kernel: 6.1.1-arch1-1
`-/+sssssssssssssssso+:` Uptime: 44 mins
`-:/+sssssssssssssssssso+/. Packages: 1181 (pacman), 2 (flatpak)
`.://osssssssssssssssssssso++- Shell: bash 5.1.16
.://+ssssssssssssssssssssssso++: Resolution: 1920x1200
.:///ossssssssssssssssssssssssso++: WM: sway
`:////ssssssssssssssssssssssssssso+++. Theme: Adwaita [GTK2/3]
`-////+ssssssssssssssssssssssssssso++++- Icons: Adwaita [GTK2/3]
`..-+oosssssssssssssssssssssssso+++++/` Terminal: terminology
./++++++++++++++++++++++++++++++/:. CPU: Intel i7-10610U (8) @ 4.900GHz
`:::::::::::::::::::::::::------`` GPU: Intel CometLake-U GT2 [UHD Graphics]
GPU: NVIDIA GeForce MX330
Memory: 5093MiB / 47940MiB
Then, the content of /etc/ostree-mkinitcpio.conf is
HOOKS="base systemd ostree autodetect modconf block filesystems keyboard fsck"
There is no other
mkinitcpiorelated file – at leastlocate mkinitcpio(after anupdatedb) does not report any other filename that contains the string in question.
encrypt hook
When I turn on my laptop, I am asked for a passphrase to unlock the root partition. Also encrypted are other partitions, such a /var and the [SWAP]. The partition that holds the /boot/efi part, however, is not encrypted.
I wonder how the HOOKS array and in particular the https://wiki.archlinux.org/title/Dm-crypt/Encrypting_an_entire_system#Configuring_mkinitcpio related to my setup. encrypt is mentioned as a required (?) hook. At this point, I am questioning how different my setup is and how does it work without the encrypt hook listed among others – given that /etc/ostree-mkinitcpio.conf is indeed used to re-create the initial ramdisk, for example after installing a new kernel.
resume hook
In addition, if I leave my system unattented for some time, it goes to suspend mode but then never wakes up. I have to force a power-off. Is the resume hook, as described at https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Configure_the_initramfs, related?
