I have been running Endeavouros on my Macbook Pro 2011 for a couple of years now. It has been a great solution for breathing some new life in this machine.
I keep having this problem with my Wifi dropping randomly though. I have to reboot the machine, in order for the Wifi to be back up.
Sometimes the wifi will drop randomly, but there also seems to be a pattern of it happening when it’s under heavier load. Like when I am updating, I have been resorting to doing it via cable lately, for the wifi not to drop on me mid update.
Also the wifi seems to drop, when I wake up the machine, after a “hibernation”.
I suspect it might be the Wifi drivers, or maybe a power saving issue?
I am still a newbie at linux, so bear with me.
This is my inxi -FAZ --no-host output:
Kernel: 6.11.7-arch1-1 arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: EndeavourOS
Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
serial: <superuser required> UEFI: Apple v: MBP81.88Z.0050.B00.1804101331
date: 04/10/18
Battery:
ID-1: BAT0 charge: 0.7 Wh (100.0%) condition: 0.7/58.8 Wh (1.2%)
Info: dual core model: Intel Core i5-2415M bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 831 min/max: 800/2900 cores: 1: 831 2: 831 3: 831 4: 831
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel
Device-2: Apple FaceTime HD Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.14 driver: X: loaded: intel
unloaded: modesetting dri: i965 gpu: i915 resolution: 1280x800~60Hz
API: EGL v: 1.5 drivers: crocus,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.2.6-arch1.1
renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
driver: snd_hda_intel
API: ALSA v: k6.11.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.6 status: active
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
IF: enp2s0f0 state: down mac: c8:2a:14:2e:d8:96
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: wl
IF: wlan0 state: up mac: e4:ce:8f:0f:9e:44
Bluetooth:
Device-1: Apple Bluetooth Host Controller driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: E4:CE:8F:0F:9E:45 bt-v: 2.1
Local Storage: total: 465.76 GiB used: 345.86 GiB (74.3%)
ID-1: /dev/sda vendor: Western Digital model: WD Blue SA510 2.5 500GB
ID-1: / size: 456.41 GiB used: 345.76 GiB (75.8%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 75.0 C mobo: 0.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.53 GiB used: 2.2 GiB (14.1%)
Processes: 204 Uptime: 40m Shell: Bash inxi: 3.3.36
Hope some of you gurus are able to help me diagnose it, or point me in the direction of how to solve this. Much appreciated!
