LXQT without Num-Lock enabled from the start
It depends on how and what you install in OpenBox.
I editted xml file to have little bit of tiling
I mean the lxqt part of config for the openbox, i can move the window with the key (edit)
That’s good.
The easiest way to do this is via LXQt Session Settings (this works here from the beginning with LXQt):
numlock_on
only numlockx will also set on :wink: thats default
You’re absolutely right, I didn’t really look on that side. That’s good to know!
Thank you. :slight_smile:
