However, after installation have something like that
ERROR: device '/dev/mapper/vg0-root' not found, Skipping fsck.
mount: /new_root: special device /dev/mapper/vg0-root does not exist.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ]#
Most probably grub need to be updated due to problem that it use /dev/disk/by-uuid instead of /dev/sda. I can change file grub.cfg, but what is next, how to chroot the system to update grub configuration.
thank you all for welcoming)
Do you need to use tutorial to install LVM on LUKS?
No, i did not.
So, I sorted it out.
What was done
sudo su
Mount from live
mount /dev/mapper/vg0-root /mnt
mkdir -p /mnt/boot/efi
mount /dev/sda1 /mnt/boot
mount /dev/sda1 /mnt/boot/efi
mkdir -p /mnt/home
mount /dev/mapper/vg0-home /mnt/home
Change the HOOKS=… line by adding encrypt and resume
