So I fired up Lutris to install a game yesterday and I get this sort of output:
~/games
❯ python --version
Python 3.13.3
~/games
❯ pip list
Package Version
pip 25.0.1
~/games
❯ lutris
Error importing Lutris application module: No module named 'lutris'
I’ve also tried pyenv’s 3.12 and 3.11 with no change. python /usr/bin/lutris
gives the same error.
None of what I see online is helping. Anyone have an idea?
I’m freshly updated yesterday. My system specs if relevant:
Summary
Host: endeavouros Kernel: 6.15.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_wayland vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x
serial: part-nu: SKU uuid:
UEFI: American Megatrends v: 2003 date: 03/10/2021
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: 66-c2-ad-de
charge: 55% (should be ignored) rechargeable: yes status: discharging
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP smt: enabled
arch: Zen 3+ rev: 2 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 3710 min/max: 561/4654 boost: enabled cores: 1: 3710
2: 3710 3: 3710 4: 3710 5: 3710 6: 3710 7: 3710 8: 3710 9: 3710 10: 3710
11: 3710 12: 3710 bogomips: 88807
Device-1: NVIDIA AD103 [GeForce RTX 4070 Ti SUPER] vendor: PNY
driver: nvidia v: 575.57.08 arch: Lovelace pcie: speed: 16 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 08:00.0
chip-ID: 10de:2705 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-3 model: ViewSonic VA3456-WQHD serial: WCK211500764 res:
mode: 2560x1080 hz: 60 scale: 100% (1) dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.57.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti
SUPER/PCIe/SSE2 display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 9 surfaces: N/A device: 0
type: discrete-gpu driver: nvidia device-ID: 10de:2705
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA vendor: PNY driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:22bb class-ID: 0403
API: ALSA v: k6.15.2-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: fc:34:97:a5:0d:60
Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
driver: r8152 type: USB rev: 3.2 speed: 5 Gb/s lanes: 1 bus-ID: 2-2:2
chip-ID: 2357:0601 class-ID: 0000 serial: 000001
IF: enp2s0f0u2 state: up speed: 1000 Mbps duplex: full
mac: 54:af:97:5c:38:56
IF-ID-1: br-2d8baad960f4 state: up speed: 10000 Mbps duplex: unknown
mac: 3a:22:46:33:0e:38
IF-ID-2: br-51648204f30e state: up speed: 10000 Mbps duplex: unknown
mac: 1e:89:1a:8a:08:98
IF-ID-3: br-54909c48cfa7 state: up speed: 10000 Mbps duplex: unknown
mac: fe:22:af:9b:40:c3
IF-ID-4: br-96717aedabdb state: up speed: 10000 Mbps duplex: unknown
mac: c2:ca:4a:e2:e5:8a
IF-ID-5: br-9a49783db23a state: up speed: 10000 Mbps duplex: unknown
mac: 1e:d5:2b:60:ad:7c
IF-ID-6: br-c0fc987df1ae state: up speed: 10000 Mbps duplex: unknown
mac: 36:3e:e4:e7:81:01
IF-ID-7: docker0 state: down mac: 36:39:05:5b:e5:00
IF-ID-8: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-9: veth41d8481 state: up speed: 10000 Mbps duplex: full
mac: 66:80:7b:06:25:a5
IF-ID-10: veth7ffaab0 state: up speed: 10000 Mbps duplex: full
mac: 12:6d:37:ae:fb:42
IF-ID-11: vethb590e93 state: up speed: 10000 Mbps duplex: full
mac: fe:09:f7:2f:f7:32
IF-ID-12: vethb67e831 state: up speed: 10000 Mbps duplex: full
mac: 96:78:a4:78:16:1b
IF-ID-13: vethc8c61b3 state: up speed: 10000 Mbps duplex: full
mac: fe:fa:e9:4e:94:b5
IF-ID-14: vethce01653 state: up speed: 10000 Mbps duplex: full
mac: 6a:5e:e1:12:dd:06
Local Storage: total: 10.03 TiB used: 2.02 TiB (20.1%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT2000P3PSSD8 size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: 2423E8B711AE fw-rev: P9CR40D
temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Silicon Power model: SPCC M.2 PCIE SSD
size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: 30012119521
fw-rev: HBAF28FT temp: 34.9 C scheme: GPT
ID-3: /dev/sda vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
speed: 6.0 Gb/s tech: SSD serial: 2137E5D1AD0F fw-rev: 043 scheme: GPT
ID-4: /dev/sdb vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
speed: 6.0 Gb/s tech: SSD serial: 2105E4F09DDD fw-rev: 033 scheme: GPT
ID-5: /dev/sdc vendor: Toshiba model: HDWE140 size: 3.64 TiB
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: 28LSK8Z8F58D fw-rev: FP2A
scheme: GPT
ID-1: / size: 1.78 TiB used: 633.51 GiB (34.8%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 41.0 C mobo: 28.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1914 fan-3: 1198 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 1272
Memory: total: 96 GiB note: est. available: 94.18 GiB
used: 21.64 GiB (23.0%)
Processes: 352 Power: uptime: 9h 41m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
Packages: 1556 pm: pacman pkgs: 1541 pm: flatpak pkgs: 15 Compilers:
clang: 20.1.6 gcc: 15.1.1 alt: 14 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.38
