Apologies, I’m in a bit of a crisis. I’ve been using EndeavourOS since last autumn without problems. No dualboot, just pure EOS. Full disk luks encryption - not sure what the file system is.
This morning I booted my computer and found that I cannot decrypt my hard disk (see below error).
I have attempted to reboot multiple times. I know the keyboard layout is in EN_US and that shouldn’t cause the issue. The password is also correct - typed it in plain text in rescue mode to verify.
I have had issues previously with the password being unrecognised once, maybe twice, but never have been locked out for an entire hour.
Tried searching for answers, most unusable as I can’t actually log in.
Try booting into a live environment and decrypting your root partition using sudo cryptsetup open.
Luks headers can corrupt, although it is not common, always a good idea to back them up using sudo cryptsetup luksHeaderBackup.
For this reason I always image backup the root filesystem within a luks partition, this way if the luks header corrupts I can just create a new luks container and restore the root filesystem into it.
It is also possible that a specific keyslot info has been corrupted, although I don’t know how to specifically test for this. Restoring a luksHeader should remedy this.
If you are positive your password is correct, keymap is correct, and you have no luksHeader backup then re-install would be your only option.
This is the double edged sword of at rest encryption.
