daniel
October 28, 2021, 3:47pm
1
I added a new key to luks via
cryptsetup luksAddKey
and removed old keys via
cryptsetup luksKillSlot
Now, after entering the passphrase on the usual GRUB screen, I get the message
No key available with this passphrase.
Invalid keyfile. Reverting to passphrase.
A password is required to access the luks-b8e…
Enter passphrase for /dev/nvme0n1p2:
After entering the same passphrase as before again, it boots into the os.
The following image sequence shows the process.
dalto
October 28, 2021, 3:53pm
2
The way it is configured by default it is unlocked by grub via the passphrase and then unlocked in the initramfs via a keyfile.
If you:
daniel:
You probably removed the access to the keyfile as well.
You should re-add the keyfile.
daniel
October 28, 2021, 5:20pm
3
So the luks partition gets unlocked twice? So I need to add a luks slot entry where the “password” is that keyfile, where do I find that keyfile?
daniel
October 28, 2021, 10:25pm
5
That worked, thanks! Can you point me to some endeavouros documentation where I could have figured that out myself. Using search engines didn’t help me.
mbod
October 29, 2021, 6:19am
6
I believe this setup with /crypto_keyfile.bin
is not specific to EndeavourOS or Arch. This mechanism is also being used by other distros.
A good starting point to read is the Arch wiki:
https://wiki.archlinux.org/title/dm-crypt/Device_encryption#With_a_keyfile_embedded_in_the_initramfs
dalto
October 29, 2021, 10:00am
7
It is the default mechanism used by Calamares.
system
Closed
October 31, 2021, 10:01am
8
