this is my journalctl -f with this steps:
I wrote journalctl -f to watch for events, then restarted ath10k_pci module and waited to connect to my wifi automatically
(cleaned:)
Summary
Jan 17 16:52:50 Rootiens kernel: audit: type=1300 audit(XXX): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=7f48c3913450 a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:52:50 Rootiens kernel: audit: type=1327 audit(XXX): proctitle="/usr/bin/charon-systemd"
Jan 17 16:52:50 Rootiens audit: PROCTITLE proctitle="/usr/bin/charon-systemd"
Jan 17 16:52:50 Rootiens charon-systemd[355]: installed bypass policy for XXX/24
Jan 17 16:52:50 Rootiens dunst[8746]: No players found
Jan 17 16:52:50 Rootiens dunst[8754]: No players found
Jan 17 16:52:51 Rootiens NetworkManager[379]: <info> [1673961771.0922] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 17 16:53:00 Rootiens systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jan 17 16:53:00 Rootiens audit[1]: SERVICE_STOP pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:00 Rootiens kernel: audit: type=1131 audit(1673961780.824:185): pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:26 Rootiens dbus-daemon[352]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.74' (uid=0 pid=8918 comm="sudo modprobe -r ath10k_pci")
Jan 17 16:53:26 Rootiens audit[8918]: USER_ACCT pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="rootiens" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens dbus-daemon[352]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 17 16:53:26 Rootiens sudo[8918]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 17 16:53:26 Rootiens sudo[8918]: rootiens : TTY=pts/2 ; PWD=/home/rootiens ; USER=root ; COMMAND=/usr/bin/modprobe -r ath10k_pci
Jan 17 16:53:26 Rootiens audit[8918]: CRED_REFR pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens kernel: audit: type=1101 audit(XXX.481:186): pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="rootiens" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens kernel: audit: type=1110 audit(XXX.481:187): pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens audit[8918]: USER_START pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens sudo[8918]: pam_unix(sudo:session): session opened for user root(uid=0) by rootiens(uid=1000)
Jan 17 16:53:26 Rootiens kernel: audit: type=1105 audit(XXX.485:188): pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens kernel: wlan0: deauthenticating from XXX by local choice (Reason: 3=DEAUTH_LEAVING)
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: wlan0: CTRL-EVENT-DISCONNECTED bssid=XXX reason=3 locally_generated=1
Jan 17 16:53:26 Rootiens charon-systemd[355]: interface wlan0 deactivated
Jan 17 16:53:26 Rootiens avahi-daemon[337]: Interface wlan0.IPv6 no longer relevant for mDNS.
Jan 17 16:53:26 Rootiens avahi-daemon[337]: Leaving mDNS multicast group on interface wlan0.IPv6 with address XXX.
Jan 17 16:53:26 Rootiens charon-systemd[355]: XXX disappeared from wlan0
Jan 17 16:53:26 Rootiens charon-systemd[355]: interface wlan0 deleted
Jan 17 16:53:26 Rootiens avahi-daemon[337]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6485] device (wlan0): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jan 17 16:53:26 Rootiens avahi-daemon[337]: Leaving mDNS multicast group on interface wlan0.IPv4 with address XXX.
Jan 17 16:53:26 Rootiens avahi-daemon[337]: Withdrawing address record for XXX on wlan0.
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6689] dhcp4 (wlan0): canceled DHCP transaction
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6689] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6689] dhcp4 (wlan0): state changed no lease
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6692] dhcp6 (wlan0): canceled DHCP transaction
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6693] dhcp6 (wlan0): state changed no lease
Jan 17 16:53:26 Rootiens systemd[1]: Starting Load/Save RF Kill Switch Status...
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6821] manager: NetworkManager state is now DISCONNECTED
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6878] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Jan 17 16:53:26 Rootiens dbus-daemon[352]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=379 comm="/usr/bin/NetworkManager --no-daemon")
Jan 17 16:53:26 Rootiens NetworkManager[379]: <info> [XXX.6885] radio killswitch /sys/devices/pci0000:00/0000:00:1d.2/0000:03:00.0/ieee80211/phy2/rfkill5 disappeared
Jan 17 16:53:26 Rootiens kernel: audit: type=1130 audit(XXX.691:189): pid=1 uid=0 auid=XXX ses=XXX msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:26 Rootiens audit[1]: SERVICE_START pid=1 uid=0 auid=XXX ses=XXX msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:26 Rootiens systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 17 16:53:26 Rootiens systemd[1]: Started Load/Save RF Kill Switch Status.
Jan 17 16:53:26 Rootiens NetworkManager[379]: <warn> [XXX.7090] dns-sd-resolved[0fc867fcbc52ef3c]: send-updates SetLinkDomains@5 failed: GDBus.Error:org.freedesktop.resolve1.NoSuchLink: Link 5 not known
Jan 17 16:53:26 Rootiens audit[1]: SERVICE_START pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:26 Rootiens dbus-daemon[352]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 17 16:53:26 Rootiens systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 17 16:53:26 Rootiens kernel: audit: type=1130 audit(XXX.711:190): pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Jan 17 16:53:26 Rootiens audit: MAC_IPSEC_EVENT op=SPD-delete auid=XXX ses=XXX res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Jan 17 16:53:26 Rootiens audit[355]: SYSCALL arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7f48c2911580 a2=50 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:26 Rootiens audit: PROCTITLE proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:26 Rootiens audit: MAC_IPSEC_EVENT op=SPD-delete auid=XXX ses=XXX res=1 src=XXX src_prefixlen=24 dst=XXX dst_prefixlen=24
Jan 17 16:53:26 Rootiens kernel: audit: type=1415 audit(XXX.738:191): op=SPD-delete auid=XXX ses=XXX res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Jan 17 16:53:26 Rootiens kernel: audit: type=1300 audit(XXX.738:191): arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7f48c2911580 a2=50 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:26 Rootiens kernel: audit: type=1327 audit(XXX.738:191): proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:26 Rootiens kernel: audit: type=1415 audit(XXX.738:192): op=SPD-delete auid=XXX ses=XXX res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Jan 17 16:53:26 Rootiens kernel: audit: type=1300 audit(XXX.738:192): arch=c000003e syscall=44 success=yes exit=80 a0=9 a1=7f48c2911580 a2=50 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:26 Rootiens audit[8918]: USER_END pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens audit[8918]: CRED_DISP pid=8918 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens sudo[8918]: pam_unix(sudo:session): session closed for user root
Jan 17 16:53:26 Rootiens systemd-resolved[313]: Switching to fallback DNS server 1.1.1.1#cloudflare-dns.com.
Jan 17 16:53:26 Rootiens charon-systemd[355]: uninstalling bypass policy for fe80::/64
Jan 17 16:53:26 Rootiens charon-systemd[355]: uninstalling bypass policy for XXX/24
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: Could not read interface p2p-dev-wlan0 flags: No such device
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Jan 17 16:53:26 Rootiens wpa_supplicant[472]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Jan 17 16:53:26 Rootiens dbus-daemon[352]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.78' (uid=0 pid=8946 comm="sudo modprobe ath10k_pci")
Jan 17 16:53:26 Rootiens sudo[8946]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 17 16:53:26 Rootiens audit[8946]: USER_ACCT pid=8946 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="rootiens" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens audit[8946]: CRED_REFR pid=8946 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens sudo[8946]: rootiens : TTY=pts/2 ; PWD=/home/rootiens ; USER=root ; COMMAND=/usr/bin/modprobe ath10k_pci
Jan 17 16:53:26 Rootiens dunst[8957]: No players found
Jan 17 16:53:26 Rootiens sudo[8946]: pam_unix(sudo:session): session opened for user root(uid=0) by rootiens(uid=1000)
Jan 17 16:53:26 Rootiens audit[8946]: USER_START pid=8946 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:26 Rootiens dunst[8971]: No players found
Jan 17 16:53:26 Rootiens kernel: ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Jan 17 16:53:27 Rootiens audit[8946]: USER_END pid=8946 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:27 Rootiens audit[8946]: CRED_DISP pid=8946 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Jan 17 16:53:27 Rootiens sudo[8946]: pam_unix(sudo:session): session closed for user root
Jan 17 16:53:27 Rootiens kernel: ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 11ad:08a6
Jan 17 16:53:27 Rootiens kernel: ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
Jan 17 16:53:27 Rootiens kernel: ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
Jan 17 16:53:27 Rootiens kernel: ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
Jan 17 16:53:27 Rootiens kernel: ath10k_pci 0000:03:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
Jan 17 16:53:27 Rootiens kernel: ath: EEPROM regdomain: 0x69
Jan 17 16:53:27 Rootiens kernel: ath: EEPROM indicates we should expect a direct regpair map
Jan 17 16:53:27 Rootiens kernel: ath: Country alpha2 being used: 00
Jan 17 16:53:27 Rootiens kernel: ath: Regpair used: 0x69
Jan 17 16:53:27 Rootiens NetworkManager[379]: <info> [XXX.4598] device (wlan0): driver supports Access Point (AP) mode
Jan 17 16:53:27 Rootiens NetworkManager[379]: <info> [XXX.4605] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/9)
Jan 17 16:53:27 Rootiens NetworkManager[379]: <info> [XXX.4624] rfkill6: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1d.2/0000:03:00.0/ieee80211/phy3/rfkill6) (driver ath10k_pci)
Jan 17 16:53:27 Rootiens NetworkManager[379]: <info> [XXX.4726] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 17 16:53:27 Rootiens charon-systemd[355]: interface wlan0 activated
Jan 17 16:53:27 Rootiens charon-systemd[355]: interface wlan0 deactivated
Jan 17 16:53:27 Rootiens NetworkManager[379]: <info> [XXX.8240] device (wlan0): set-hw-addr: set MAC address to XXX (scanning)
Jan 17 16:53:28 Rootiens charon-systemd[355]: interface wlan0 activated
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1394] device (wlan0): supplicant interface state: internal-starting -> disconnected
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1396] Wi-Fi P2P device controlled by interface wlan0 created
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1403] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/10)
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1412] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1428] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jan 17 16:53:28 Rootiens NetworkManager[379]: <info> [1673961808.1444] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens systemd[1]: systemd-rfkill.service: Deactivated successfully.
Jan 17 16:53:32 Rootiens audit[1]: SERVICE_STOP pid=1 uid=0 auid=XXX ses=XXX msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:32 Rootiens kernel: kauditd_printk_skb: 20 callbacks suppressed
Jan 17 16:53:32 Rootiens kernel: audit: type=1131 audit(XXX.488:204): pid=1 uid=0 auid=XXX ses=XXX msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7047] policy: auto-activating connection 'Peyman' (5f42657d-a1f4-4e6d-8fe8-f6996da16308)
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7072] device (wlan0): Activation: starting connection 'Peyman' (5f42657d-a1f4-4e6d-8fe8-f6996da16308)
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7079] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7097] manager: NetworkManager state is now CONNECTING
Jan 17 16:53:32 Rootiens charon-systemd[355]: interface wlan0 deactivated
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7275] device (wlan0): set-hw-addr: reset MAC address to XXX (preserve)
Jan 17 16:53:32 Rootiens charon-systemd[355]: interface wlan0 activated
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7330] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7334] device (wlan0): Activation: (wifi) access point 'Peyman' has security, but secrets are required.
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7335] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7338] sup-iface[dd61f143006affb2,3,wlan0]: wps: type pbc start...
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7343] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7343] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> interface_disabled
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7356] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7362] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7367] device (wlan0): Activation: (wifi) connection 'Peyman' has security, and secrets exist. No new secrets needed.
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7367] Config: added 'ssid' value 'Peyman'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7368] Config: added 'scan_ssid' value '1'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7368] Config: added 'bgscan' value 'simple:30:-70:86400'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7368] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7368] Config: added 'auth_alg' value 'OPEN'
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7369] Config: added 'psk' value '<hidden>'
Jan 17 16:53:32 Rootiens stremio[1891]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Jan 17 16:53:32 Rootiens nekoray[679]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/1”"
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: WPS-CANCEL
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7630] device (wlan0): supplicant interface state: interface_disabled -> inactive
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.7631] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: SME: Trying to authenticate with XXX (SSID='Peyman' freq=2452 MHz)
Jan 17 16:53:32 Rootiens kernel: wlan0: authenticate with XXX
Jan 17 16:53:32 Rootiens kernel: wlan0: 80 MHz not supported, disabling VHT
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8150] device (wlan0): supplicant interface state: inactive -> authenticating
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8151] device (p2p-dev-wlan0): supplicant management interface state: inactive -> authenticating
Jan 17 16:53:32 Rootiens kernel: wlan0: send auth to XXX (try 1/3)
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: Trying to associate with XXX (SSID='Peyman' freq=2452 MHz)
Jan 17 16:53:32 Rootiens kernel: wlan0: authenticated
Jan 17 16:53:32 Rootiens kernel: wlan0: associate with XXX (try 1/3)
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8190] device (wlan0): supplicant interface state: authenticating -> associating
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8191] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
Jan 17 16:53:32 Rootiens kernel: wlan0: RX AssocResp from XXX (capab=0x411 status=0 aid=1)
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: Associated with XXX
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Jan 17 16:53:32 Rootiens kernel: wlan0: associated
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8332] device (wlan0): supplicant interface state: associating -> 4way_handshake
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.8333] device (p2p-dev-wlan0): supplicant management interface state: associating -> 4way_handshake
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: WPA: Key negotiation completed with XXX [PTK=CCMP GTK=CCMP]
Jan 17 16:53:32 Rootiens wpa_supplicant[472]: wlan0: CTRL-EVENT-CONNECTED - Connection to XXX completed [id=0 id_str=]
Jan 17 16:53:32 Rootiens kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.9249] device (wlan0): supplicant interface state: 4way_handshake -> completed
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.9250] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Peyman"
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.9251] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX.9258] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:32 Rootiens NetworkManager[379]: <info> [XXX] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 17 16:53:32 Rootiens charon-systemd[355]: XXX appeared on wlan0
Jan 17 16:53:32 Rootiens avahi-daemon[337]: Joining mDNS multicast group on interface wlan0.IPv6 with address XXX.
Jan 17 16:53:32 Rootiens avahi-daemon[337]: New relevant interface wlan0.IPv6 for mDNS.
Jan 17 16:53:32 Rootiens avahi-daemon[337]: Registering new address record for XXX on wlan0.*.
Jan 17 16:53:33 Rootiens audit: MAC_IPSEC_EVENT op=SPD-add auid=XXX ses=XXX res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Jan 17 16:53:33 Rootiens kernel: audit: type=1415 audit(XXX): op=SPD-add auid=XXX ses=XXX res=1 src=fe80:0000:0000:0000:0000:0000:0000:0000 src_prefixlen=64 dst=fe80:0000:0000:0000:0000:0000:0000:0000 dst_prefixlen=64
Jan 17 16:53:33 Rootiens kernel: audit: type=1300 audit(XXX): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:33 Rootiens kernel: audit: type=1327 audit(XXX): proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:33 Rootiens audit[355]: SYSCALL arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:33 Rootiens audit: PROCTITLE proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:33 Rootiens charon-systemd[355]: installed bypass policy for fe80::/64
Jan 17 16:53:33 Rootiens wpa_supplicant[472]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=-115 txrate=1000
Jan 17 16:53:34 Rootiens charon-systemd[355]: flags changed for XXX on wlan0
Jan 17 16:53:35 Rootiens NetworkManager[379]: <info> [1673961815.0801] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jan 17 16:53:35 Rootiens NetworkManager[379]: <info> [1673961815.0824] policy: set 'Peyman' (wlan0) as default for IPv6 routing and DNS
Jan 17 16:53:36 Rootiens systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jan 17 16:53:36 Rootiens audit[1]: SERVICE_STOP pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7033] dhcp4 (wlan0): state changed new lease, address=XXX
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7058] policy: set 'Peyman' (wlan0) as default for IPv4 routing and DNS
Jan 17 16:53:40 Rootiens systemd-resolved[313]: wlan0: Bus client set search domain list to: domain.name
Jan 17 16:53:40 Rootiens systemd-resolved[313]: wlan0: Bus client set default route setting: yes
Jan 17 16:53:40 Rootiens avahi-daemon[337]: Joining mDNS multicast group on interface wlan0.IPv4 with address XXX.
Jan 17 16:53:40 Rootiens avahi-daemon[337]: New relevant interface wlan0.IPv4 for mDNS.
Jan 17 16:53:40 Rootiens charon-systemd[355]: XXX appeared on wlan0
Jan 17 16:53:40 Rootiens avahi-daemon[337]: Registering new address record for XXX on wlan0.IPv4.
Jan 17 16:53:40 Rootiens systemd-resolved[313]: wlan0: Bus client set DNS server list to: XXX, XXX
Jan 17 16:53:40 Rootiens dbus-daemon[352]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=379 comm="/usr/bin/NetworkManager --no-daemon")
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7306] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:40 Rootiens systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 17 16:53:40 Rootiens dbus-daemon[352]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 17 16:53:40 Rootiens systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 17 16:53:40 Rootiens audit[1]: SERVICE_START pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:40 Rootiens kernel: kauditd_printk_skb: 1 callbacks suppressed
Jan 17 16:53:40 Rootiens kernel: audit: type=1130 audit(XXX.781:209): pid=1 uid=0 auid=XXX ses=XXX msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7882] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7887] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7911] manager: NetworkManager state is now CONNECTED_SITE
Jan 17 16:53:40 Rootiens NetworkManager[379]: <info> [XXX.7927] device (wlan0): Activation: successful, device activated.
Jan 17 16:53:40 Rootiens charon-systemd[355]: using forecast interface wlan0
Jan 17 16:53:40 Rootiens charon-systemd[355]: joining forecast multicast groups: 224.0.0.1,224.0.0.22,224.0.0.251,224.0.0.252,239.255.255.250
Jan 17 16:53:40 Rootiens charon-systemd[355]: installed bypass policy for XXX/24
Jan 17 16:53:40 Rootiens audit: MAC_IPSEC_EVENT op=SPD-add auid=XXX ses=XXX res=1 src=XXX src_prefixlen=24 dst=XXX dst_prefixlen=24
Jan 17 16:53:40 Rootiens audit[355]: SYSCALL arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:40 Rootiens audit: PROCTITLE proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:40 Rootiens kernel: audit: type=1415 audit(XXX.818:210): op=SPD-add auid=XXX ses=XXX res=1 src=XXX src_prefixlen=24 dst=XXX dst_prefixlen=24
Jan 17 16:53:40 Rootiens kernel: audit: type=1300 audit(XXX.818:210): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:40 Rootiens kernel: audit: type=1327 audit(XXX.818:210): proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:40 Rootiens kernel: audit: type=1415 audit(XXX.818:211): op=SPD-add auid=XXX ses=XXX res=1 src=XXX src_prefixlen=24 dst=XXX dst_prefixlen=24
Jan 17 16:53:40 Rootiens kernel: audit: type=1300 audit(XXX.818:211): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:40 Rootiens kernel: audit: type=1327 audit(XXX.818:211): proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:40 Rootiens kernel: audit: type=1415 audit(XXX.818:212): op=SPD-add auid=XXX ses=XXX res=1 src=XXX src_prefixlen=24 dst=XXX dst_prefixlen=24
Jan 17 16:53:40 Rootiens kernel: audit: type=1300 audit(XXX.818:212): arch=c000003e syscall=44 success=yes exit=184 a0=9 a1=XXX a2=b8 a3=0 items=0 ppid=1 pid=355 auid=XXX uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=XXX comm="charon-systemd" exe="/usr/bin/charon-systemd" key=(null)
Jan 17 16:53:40 Rootiens kernel: audit: type=1327 audit(XXX.818:212): proctitle="/usr/bin/charon-systemd"
Jan 17 16:53:40 Rootiens dunst[9036]: No players found
Jan 17 16:53:40 Rootiens dunst[9044]: No players found
Jan 17 16:53:41 Rootiens NetworkManager[379]: <info> [XXX.0896] manager: NetworkManager state is now CONNECTED_GLOBAL
