Hi all!
I’m having an issue where my PC refuses to negotiate any linkrate higher than 54MBit/s on wifi. My hardware is:
Gigabyte X570s Aorus Master (Which uses the intel AX210 WiFi chip)
Ryzen 5 5600X
Evga RTX 2080 super
2x 1TB NVMe drives (I have EndeavourOS installed on one and windows 10 on another)
All connecting to a Ubiquiti AC PRO access point
I have tried all number of things but I can’t get any higher speeds while my phone in the same room manages to connect to the same AP at around 450MBit/s. I have also tried connecting to my phones hotspot but it’s the same. I have set 11n_disable=1, swcrypto=1, and have also tried disable_AX=1 in ‘/etc/modprobe.d/iwlwifi.conf’ but none of these changes made any difference. Here is an output of ‘iw dev wlan0 link’ :
Connected to 1e:e8:29:ee:0e:f6 (on wlan0)
SSID: *MY SSID*
freq: 5220
RX: 388375 bytes (1505 packets)
TX: 243101 bytes (714 packets)
signal: -59 dBm
rx bitrate: 54.0 MBit/s
tx bitrate: 54.0 MBit/s
bss flags: short-slot-time
dtim period: 3
beacon int: 100
I am currently using 5.16.3-zen kernel but the issue happens with then original and the LTS kernels as well. The AP is showing that all other devices connecting to it are all at a much higher capacity than my PC so I don’t think thats the issue. I’m relatively new to linux in general but I am savvy enough to work out most issues but this one has me stumped. My router is on the other side of the house so I can’t try ethernet to compare unfortunately. Any help would be greatly appreciated!
