I recently switched from fedora to Endeavour. However, the refresh rate is always around 30fps by “balance mode” so that the animation is pretty laggy.(To be precise, the FPS stays at 60 if I do nothing, but as long as I switch to another virtual desktop or something else, it drops to 30-38fps. ) This problem could be solved by switching to “performance mode”, which provides 60fps animation but will sacrifice the battery life.
afaik EndeavourOS uses power-profiles-daemon as default power manager. Are there any ways to change the configuration or to help me solve this problem?
thanks for reading.
