Hey guys, switching from pop OS here. I have tried different proton versions, kernels and disabling the KDE compositor. nothing seems to be working. This was an issue on pop OS so I do not think it is specific to endeavor or Arch. I am hoping to get some assistance and attempt to figure out what the problem is.
I am a bit new to this so please let me know what you need me to run and what information you need from me.
Yes I followed the guide. I mostly just installed my graphics drivers, installed steam and proton-GE. I switched to the cachyOS kernel in hopes of getting a performance boost and it helped just a little bit but the difference was not really substantial. I made sure to disable the KDE compositor as well.
Thanks for the warm welcome! I have been enjoying Endeavor a ton so far.
It is anecdotal but 550.76 nvidia drivers cause stutter and crashes for me so I had to downgrade to 550.67.
Maybe you could try previous driver versions.
That’s the thing, it doesn’t happen on windows. If I’m getting 110 FPS on a game in windows, I get 50 FPS on Linux with stuttering. sometimes the stuttering goes away depending on the game but the FPS remains low. I think if it was a hardware issue then it would be unplayable on windows too, but it isn’t.
One thing I have noticed is that shaders or textures look different on Linux than they do on windows. Not sure if this is something that could help find the issue.
Well, what games do you play? Since your card is fairly old, pushing on 10 years now, it’s possible that solutions we found for Linux gaming are a bit too much for the card. Vulkan is a pretty recent development and I’m not sure how well baked it was back in 2016.
Guild Wars 2 mostly, that has been running well since it is more of a CPU heavy game. I play Hunt Showdown and that gets half the FPS in windows. Most games I have tried to play new or old get half the FPS that they get in windows, but maybe you’re right. It could just be the card not being well supported by Linux solutions, it is possible.
I fear that might be the case. It is what happened with my hardware until I got a modern laptop with a 3050 in it and I had the ability to actually play everything on Linux. Some games worked fine, since they were really simple, but some more difficult titles required me to switch to Windows to have decent performance. It’s unfortunate really, but yeah…
Just checked it, it is on performance with gamemode. I think it is either an issue with the driver or that my GPU is just too old, which I doubt since I get low performance with games that people get normal performance with using the same GPU. Not really sure what else I can try here.
Like i said, try with nouveau using nvk (that’s the vulkan-nouveau and lib32-vulkan-nouveau packages)for vulkan and zink for opengl applications. It’s a bit of a long shot maybe, but it is worth a try, those drivers may be new but they seem to be surprisingly good for a lot of games.
I suspect that maybe because your card is old nvidia has neglected support for it and you need to downgrade the drivers to an older version to fix it.
the 550 drivers have a lot of problems too even on new cards.
If you wanna try downgrading, assuming you’ve had the installation for a while and at some point had older drivers, you can go to /var/cache/pacman/pkg and install older packages from there, if not you could try the aur nvidia packages like nvidia-535xx-dkms or maybe even as far back as 470 or 390.
It is a fresh installation so no older drivers. I will figure out how to downgrade and try nouveau using nvk. I suspected the drivers but wanted to avoid the hassle of downgrading haha. I guess I will go through them and see what works best, thanks a lot for the help!
When downgrading the drivers, should I downgrade the nvidia-utils and things like that too?
