Hi all from a cold and wet east coast of Australia.
I don’t know how but my system is out-of-Whack.
Trying to login with the right password> Loops back to login.
ctl+alt-F2
login ok
password gives this result.
"/home/$USER: change directory failed permission denied
logging in with home “/” "
FSTAB reads.
UUID=739405e0-a8af-40b0-b986-03efec09ca73 / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=739405e0-a8af-40b0-b986-03efec09ca73 /home btrfs subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=739405e0-a8af-40b0-b986-03efec09ca73 /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=739405e0-a8af-40b0-b986-03efec09ca73 /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0```
"journalctl -b -0"
[here](https://clbin.com/lRtWL)
Hopefully someone can brighten up my evening.
Many thanks in advance. :sunglasses:
Thanks @petsam
I have learn’t an humbling lesson not tinker with the system while imbibing alcoholic beverages !!
“chmod 755 -R /home” done the trick
thanking you.
Not about the solution.
It’s about the problem. Each problem has a different solution.
My question was about the problem…
Usually some users with problem logging in DE and having lost Xorg/GUI/DE, try to login in TTY using sudo , which changes their user $HOME owner, so you fix it changing folder (and contents) owner.
You changed permissions, not owner. Thus my question
In journalctl -b -0 it reported
Can’t create dir /home/hassom/Desktop
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Downloads
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Templates
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Public
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Documents
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Music
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Pictures
May 09 20:33:01 dave-osos xdg-user-dirs-update[903]: Can’t create dir /home/hassom/Videos
So I assumed it was just a permission prob. But I wanted to hear from someone that has more experience than I. Which would be probably everyone on this forum.
permissios on my home folder was 544. Wow that was a shock!
I believe it was something to do with Timeshift.
I have my snapshots on on another internal hard drive partition. I couldnt get in to that partition to see the snapshots so after tinkering with that partiton, I would say I buggered my home folder recursively somehow. I gave up, uninstalled Timeshift reformatted that partition. This is all I can think of.
Turned computer off. Came back to it after a couple of days, well you know as much as I do from there.
Anyway thanks for your help. It is truly appreciated.
Just saw that image. Gave me a good chuckle!!
