Login problem
If nothing else helps, create a good backups of your personal data and reinstall. Might be the fastest way forward.
Well, create a good backup anyway! :sweat_smile:
My personal data is not a problem, but setting up the system again as I have it now (or better say: before it was messed) will take too long time, if at all possible.
I believe it is something easy to repair, but how? Why login doesn’t know my password?
In general using packages like this and bleachbit can be dangerous if you do not know what you are doing.
What packages could be broken and should be reinstalled?
pam
systemd
gdm
else?
Noted :wink:
Possibly you have a different keyboard layout set up, so check the password is being typed as expected.
This is also possible:
Locale is correct, but I have used fingerprint. Will read and try to understand your link, thanks.
Edit: Problem solved, thank you very much jonathon.
