Login loop with second monitor
Hello,
after today update i have problem:
v1 if second monitor is connected to notebook, I have two independed login screen, if I login on notebook - login loops, if I login on monitor - everything hangs.
v2 if I dissconnect second monitor and login - everything working fine, uuntil I connect second monitor - after that login scren appear and v1 starts
inxi - Fzxx output
Kernel: 6.11.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: GIGABYTE product: AORUS 17 XE5 v: N/A
serial: Chassis: type: 10 v: y.y
serial:
Mobo: GIGABYTE model: AORUS 17 XE5 v: WIN11 serial:
part-nu: X7PXVE5 UEFI: American Megatrends LLC. v: FB08 date: 03/07/2022
Battery:
ID-1: BAT1 charge: 95.7 Wh (96.7%) condition: 99.0/99.0 Wh (100.0%)
volts: 16.8 min: 15.2 model: GIGABYTE Aorus 17 serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: charge: 100% (should be ignored)
status: discharging
Info: 14-core (6-mt/8-st) model: 12th Gen Intel Core i7-12700H bits: 64
type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 1.2 MiB L2: 11.5 MiB
L3: 24 MiB
Speed (MHz): avg: 400 min/max: 400/4600:4700:3500 cores: 1: 400 2: 400
3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400
bogomips: 107560
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-12.2 ports: active: eDP-1
empty: DP-2, DP-3, DP-4, DP-5 bus-ID: 00:02.0 chip-ID: 8086:46a6
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: Gigabyte
driver: nvidia v: 560.35.03 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:24a0
Device-3: Goodong USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 3-9:4 chip-ID: 3252:0004
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
drv: iris x11: drv: iris inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 display-ID: :1.0
API: Vulkan v: 1.3.295 surfaces: xcb,xlib,wayland device: 0
type: discrete-gpu driver: nvidia device-ID: 10de:24a0
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:51c8
Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:228b
API: ALSA v: k6.11.3-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0
IF: wlan0 state: up mac:
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 2d:00.0 chip-ID: 10ec:8125
IF: enp45s0 state: down mac:
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 bus-ID: 2-1.4:3 chip-ID: 0bda:8153
IF: enp0s13f0u1u4 state: down mac:
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-10:6 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: bt-v: 5.3 lmp-v: 12
Local Storage: total: 476.94 GiB used: 114.12 GiB (23.9%)
ID-1: /dev/nvme0n1 vendor: Gigabyte model: AG4512G-SI B10 size: 476.94 GiB
speed: 63.2 Gb/s lanes: 4 serial: temp: 31.9 C
ID-1: / size: 467.39 GiB used: 113.84 GiB (24.4%) fs: ext4
dev: /dev/nvme0n1p2
System Temperatures: cpu: 39.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.02 GiB used: 8.17 GiB (26.3%)
Processes: 414 Power: uptime: 17m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: pm: pacman pkgs: 1247 Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
Blockquote
downgrade kwin to 6.2.0.2 resolve v2 problem, but not v1.
