This is a little ridiculous, but I’ve just accidentally pressed Super+b (I think), instead of Super+v like I meant to, and am now locked out of my machine:
# Lock the system
# lock with a picture:
#bindsym $mod+l exec i3lock -i ~/.config/i3/i3-lock-screen.png -p default|win -t
# lock by blurring the screen:
bindsym $mod+l exec ~/.config/i3/scripts/blur-lock
Type your login password…try again…try again.
If that fails switch to a virtual terminal, login, and kill the process.
And if this bothers, either uninstall the software or unconfigure it.
And then be locked out by PAM policy for another 10 minutes.
@reclusiveAlgorithm Your login password should work. Num Lock on the screen just mean that you have Num Lock enabled on your keyboard (same goes for Caps Lock).
Best to do is press backspace several times before you input the password. Talking from my own experience I usually have some missclick before I write the password - you should see “No Input” when it is good.
Lol, you know that I have never goofed my password enough to have learned that PAM lockout is enabled on a home system. I’ve certainly been there on commercial Unix systems.
I did try backspacing first, caps lock on, caps lock off, num lock on, num lock off… maybe I was typing it wrong the whole time? Seems unlikely but stranger things have happened!
Maybe my persistence did upset PAM. Sorry, PAM. Probably won’t happen again.
