Hi. So I have been using EndeavourOS on my Intel NUC 11 Enthusiast just fine with no issues. I decided to upgrade to the NUC 12 Enthusiast and followed the same procedures, but I cannot get the Live USB to be detected. Secure boot and fast boot are both off. I tried different USB sticks and redownloading the file from a different mirror and no luck. Simply does not detect it. I tried Fedora KDE to test it out and it detected it no problem. How can I fix this?
I have the latest BIOS version installed. I don’t see a legacy boot option. I attached a photo of the further options I can edit in the boot section of bios. Right now I have exhausted all options of writing the file, I cannot understand why it does not detect it. Ive flashed from macos and linux both. I used balena, suse writer, popsicle. No luck
I tried Ventoy as well. No luck. I also tried to install Arch Linux official ISO, and it’s the same issue as EndeavourOS. Does not detect the live USB.
All other distros such as fedora, mint, Ubuntu, pop_os work. This sucks, I insist on using Endeavour.
I may have had a similar problem recently, though I’m not entirely sure if it was with the EOS iso or another distro’s. However, using Rufus completely removed this problem for me. Hope this helps.
Not sure if this is relevant, but apparently, Intel NUC products only allow GPT partition style for UEFI boot. Is your USB drive using a GPT partition table?
