It is stuck at this, i didn’t noticed any error or warning. Hp victus i7 rtx 3050ti. Tpm and secure boot is off. Right now i am on popos using ventoy
Edit- i am also able to boot live artix. I am gonna tryna install latest endeavouros iso
There is an issue with the nvidia drivers and newer Intel CPUs. Press e at the boot menu and add ibt=off to the list of kernel options.
what bootloader do you use ?
if it is GRUB, do the command there
it’s not possible in bootorder of BIOS (F12)
Ok, i found out the how to edit at boot/grub menu, having doubts where to add the parameter
into the line beginning with — linux
Edit- it is working, i am really happy. Do you have any tips and advises for nvidia cards. Thank you,
congrats…
Can you help me editing the boot file to add the parameter, i am using systemd boot. Also you can tell me other helpful command for booting.
Add it to the file /etc/kernel/cmdline then run sudo reinstall-kernels
also, how do i remove all the commands that come during boot?
You can add quiet to the same file if you don’t want to see the output during boot.
thanks ![]()
