So this is absolutely wild and weird. I can’t boot linux-lts or linux-lqx for pretty much the exact same reasons, slightly differently reported. In their normal initramfs.
linux and linux-zen work fine, and linux-lts with initrd fallback works too, but not the normal initrd. (Note, I’m using dracut, not mkinitcpio).
The problem is, it’s stalling on mounting the / filesystem from nvme0n1p3, which is BtrFS, and on NVMe.
On linux-lts, it reports this as if /dev/dev/disab3e-5de13dd60e2f - on linux-lqx it’s correctly reported as /dev/disk/by-uuid/d6972f3e-0865-4440-ab3e-5de13dd60e2f, and in systemd.log_level in debug mode, on linux-lts, it even mentions this, as shown here: https://i.imgur.com/V7e9Jyj.jpeg (systemd debug_log)
https://i.imgur.com/1tb5vzD.jpeg (normal boot)
What gets me is linux, and linux-zen work fine, but a 3rd party kernel, linux-lqx has the exact same issue, however instea of the /dev/dis*, it’s actually showing the /dev/disk/by-uuid/UUID path.
For technical information, here’s fstab:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f / btrfs subvol=/@,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=9316a7ca-f21a-466c-bd89-b9ef4199df77 /boot ext4 noatime 0 2
UUID=4A5B-032B /boot/efi vfat fmask=0137,dmask=0027 0 2
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /home btrfs subvol=/@home,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/cache btrfs subvol=/@cache,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/log btrfs subvol=/@log,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /srv btrfs subvol=/@srv,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /opt btrfs subvol=/@opt,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /usr/local btrfs subvol=/@usrlocal,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/lib/crash btrfs subvol=/@crash,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/lib/containers btrfs subvol=/@containers,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/lib/libvirt/images btrfs subvol=/@libvirt,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/lib/machines btrfs subvol=/@machines,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/lib/portables btrfs subvol=/@portables,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/spool btrfs subvol=/@spool,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/tmp btrfs subvol=/@tmp,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /var/www btrfs subvol=/@www,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /root btrfs subvol=/@root,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f /.snapshots btrfs subvol=/.snapshots,noatime,space_cache=v2,compress=zstd:1,ssd,discard=async 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
# Mounts
UUID=2114b1b9-74af-4025-878c-7cd91515faf6 /mnt/ssd xfs defaults 0 0
UUID=74111e09-5c37-4244-b140-2f588f4ad070 /mnt/storage xfs defaults 0 0
UUID=acf970c6-711f-47ef-b24a-0fb6271956d9 /mnt/home ext4 defaults 0 0
# Spare OS: Fedora
UUID=462b254d-e309-47a3-960e-34e10fb63f52 /mnt/fedora-root btrfs subvolid=5,compress=zstd:1,noatime,space_cache=v2,ssd,discard=async 0 0
UUID=946c05ab-a723-4ee2-b40b-3346007ee6c2 /mnt/fedora-boot ext4 defaults 0 0
UUID=2993-BBD3 /mnt/fedora-efi vfat fmask=0137,dmask=0027 0 0
and grub.cfg:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod btrfs
search --no-floppy --fs-uuid --set=root d6972f3e-0865-4440-ab3e-5de13dd60e2f
font="/@/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=1920x1080x32,auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_CA
insmod gettext
fi
terminal_output gfxterm
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root 9316a7ca-f21a-466c-bd89-b9ef4199df77
insmod gfxmenu
loadfont ($root)/grub/themes/fallout-grub-theme/fixedsys-regular-32.pf2
insmod png
set theme=($root)/grub/themes/fallout-grub-theme/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/00_tuned ###
set tuned_params=""
export tuned_params
set tuned_initrd=""
export tuned_initrd
### END /etc/grub.d/00_tuned ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'EndeavourOS Linux' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux linux-zen ...'
linux /vmlinuz-linux-zen root=UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f rw rootflags=subvol=@ quiet splash video=1920x1080@165 bgrt_disable nowatchdog nvme_load=YES splash loglevel=3 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff mitigations=off
echo 'Loading initial ramdisk ...'
initrd /initramfs-linux-zen.img
submenu 'Advanced options for EndeavourOS Linux' $menuentry_id_option 'gnulinux-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
menuentry 'EndeavourOS Linux, with Linux linux-zen' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-zen-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
menuentry 'EndeavourOS Linux, with Linux linux-zen (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-zen-fallback-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /initramfs-linux-zen-fallback.img
menuentry 'EndeavourOS Linux, with Linux linux-lts' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux linux-lts ...'
linux /vmlinuz-linux-lts root=UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f rw rootflags=subvol=@ quiet splash video=1920x1080@165 bgrt_disable nowatchdog nvme_load=YES splash loglevel=3 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff mitigations=off
initrd /initramfs-linux-lts.img
menuentry 'EndeavourOS Linux, with Linux linux-lts (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts-fallback-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /initramfs-linux-lts-fallback.img
menuentry 'EndeavourOS Linux, with Linux linux-lts.old' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lts.old-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux linux-lts.old ...'
linux /vmlinuz-linux-lts.old root=UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f rw rootflags=subvol=@ quiet splash video=1920x1080@165 bgrt_disable nowatchdog nvme_load=YES splash loglevel=3 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff mitigations=off
initrd /initramfs-linux-lts.img.old
menuentry 'EndeavourOS Linux, with Linux linux-lqx' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lqx-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux linux-lqx ...'
linux /vmlinuz-linux-lqx root=UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f rw rootflags=subvol=@ quiet splash video=1920x1080@165 bgrt_disable nowatchdog nvme_load=YES splash loglevel=3 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff mitigations=off
initrd /initramfs-linux-lqx.img
menuentry 'EndeavourOS Linux, with Linux linux-lqx (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-lqx-fallback-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /initramfs-linux-lqx-fallback.img
menuentry 'EndeavourOS Linux, with Linux linux' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-advanced-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux linux ...'
linux /vmlinuz-linux root=UUID=d6972f3e-0865-4440-ab3e-5de13dd60e2f rw rootflags=subvol=@ quiet splash video=1920x1080@165 bgrt_disable nowatchdog nvme_load=YES splash loglevel=3 amd_pstate=active amdgpu.ppfeaturemask=0xffffffff mitigations=off
initrd /initramfs-linux.img
menuentry 'EndeavourOS Linux, with Linux linux (fallback initramfs)' --class endeavouros --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-linux-fallback-d6972f3e-0865-4440-ab3e-5de13dd60e2f' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /initramfs-linux-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/15_ostree ###
### END /etc/grub.d/15_ostree ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/25_bli ###
if [ "$grub_platform" = "efi" ]; then
insmod bli
fi
### END /etc/grub.d/25_bli ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
fwsetup --is-supported
if [ "$?" = 0 ]; then
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
fwsetup
fi
fi
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/35_fwupd ###
### END /etc/grub.d/35_fwupd ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/41_snapshots-btrfs ###
if [ ! -e "${prefix}/grub-btrfs.cfg" ]; then
echo ""
else
submenu 'EndeavourOS snapshots' {
configfile "${prefix}/grub-btrfs.cfg"
fi
### END /etc/grub.d/41_snapshots-btrfs ###
