Linux Freezing randomly with fresh installs, can't find errors
Hello, good evening.
Last days ive been trying to get into linux from windows, so i installed Pop os onto my 2nd ssd in my asus laptop with nvidia gpu and amd cpu
I often got frozen screens, sometimes i could use it for hours, sometimes it would do it immediately… unpredictable, sometimes i think its because of an app like for example discord but i dont get a consistent patern…
Then i thought it was POP os!, so i tried mint… same problem… now im using Endeavour OS
right after that sentence it froze, and it froze again after nothing was even launched, no discord nothing :thinking: i tried different linux kernels.
I had my browser throw errors like sigil or sigiv, so i tried doing a mem86 and memtester but no errors with 1 pass
i also saw with a random command i typed in:
fixing recursive fault but reboot is needed.
right now Brave browser just randomly crashed, also random…
so there is a lot going on, but even with just any clean linux install, something is off. idk if its because of my peripherals, like bluetooth mouse, usb keyboard, hdmi connected monitor
i just dont know how to troubleshoot this at all. i rlly dont want to give up on using linux as a daily driver because of my laptop, so any help would be appreciated.
2 solutions found: see ddnn solution (x11):
or solution 2 : install nvidia beta drivers. I installed nvidia-dkms-beta, after uninstalling all the conflicting packages that are shown when installing nvidia-dkms-beta, also install nvidia-utils-beta.
If you get audio problems through hdmi because of this, see for @anon93652015 solution down below about wireplumber.
Would help others to diagnose whats going on
Don’t do this EVER - if you are unsure ask and wait, better to chew up a little time than chew up heaps
The random command was a journalctl command so i didnt think it would be harmful, its for seeing logs i assumed.
Sorry for the bad formatting
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Root Complex [1022:14b5] (rev 01)
	Subsystem: ASUSTeK Computer Inc. Device [1043:1cb2]
	Flags: fast devsel
00:00.2 IOMMU [0806]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h IOMMU [1022:14b6]
	Flags: bus master, fast devsel, latency 0, IRQ 24
	Capabilities: <access denied>
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge [1022:14b7] (rev 01)
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge [1022:14b8] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: f000-ffff [size=4K] [16-bit]
	Memory behind bridge: fb000000-fc0fffff [size=17M] [32-bit]
	Prefetchable memory behind bridge: 7c00000000-7e01ffffff [size=8224M] [32-bit]
	Kernel driver in use: pcieport
00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge [1022:14b8] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: [disabled] [32-bit]
	Memory behind bridge: fcc00000-fccfffff [size=1M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge [1022:14b7] (rev 01)
	Flags: fast devsel, IOMMU group 3
00:02.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge [1022:14ba] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 4
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	Memory behind bridge: fcb00000-fcbfffff [size=1M] [32-bit]
00:02.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge [1022:14ba] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 5
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: e000-efff [size=4K] [16-bit]
	Memory behind bridge: fca00000-fcafffff [size=1M] [32-bit]
00:02.4 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge [1022:14ba] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 6
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	Memory behind bridge: fc900000-fc9fffff [size=1M] [32-bit]
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge [1022:14b7] (rev 01)
	Flags: fast devsel, IOMMU group 7
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge [1022:14b7] (rev 01)
	Flags: fast devsel, IOMMU group 8
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge [1022:14b7] (rev 01)
	Flags: fast devsel, IOMMU group 9
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h Internal PCIe GPP Bridge [1022:14b9] (rev 10) (prog-if 00 [Normal decode])
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h-19h Internal PCIe GPP Bridge [1022:14b9]
	Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 10
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	I/O behind bridge: d000-dfff [size=4K] [16-bit]
	Memory behind bridge: fc200000-fc5fffff [size=4M] [32-bit]
	Prefetchable memory behind bridge: 7e10000000-7e201fffff [size=258M] [32-bit]
00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h-19h Internal PCIe GPP Bridge [1022:14b9] (rev 10) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 11
	Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
	Memory behind bridge: fc600000-fc8fffff [size=3M] [32-bit]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 71)
	Flags: 66MHz, medium devsel, IOMMU group 12
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 12
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 0 [1022:1679]
	Flags: fast devsel, IOMMU group 13
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 1 [1022:167a]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 2 [1022:167b]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 3 [1022:167c]
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 4 [1022:167d]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 5 [1022:167e]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 6 [1022:167f]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 7 [1022:1680]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] [10de:2520] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: ASUSTeK Computer Inc. Device [1043:1bcc]
	Physical Slot: 0
	Flags: bus master, fast devsel, latency 0, IRQ 82, IOMMU group 14
	Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
	Memory at 7c00000000 (64-bit, prefetchable) [size=8G]
	Memory at 7e00000000 (64-bit, prefetchable) [size=32M]
	I/O ports at f000 [size=128]
	Expansion ROM at fc000000 [virtual] [disabled] [size=512K]
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GA106 High Definition Audio Controller [10de:228e] (rev a1)
	Physical Slot: 0
	Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 14
	Memory at fc080000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
02:00.0 Non-Volatile memory controller [0108]: Micron Technology Inc 2450 NVMe SSD [HendrixV] (DRAM-less) [1344:5411] (rev 01) (prog-if 02 [NVM Express])
	Subsystem: Micron Technology Inc Device [1344:2100]
	Flags: bus master, fast devsel, latency 0, IRQ 54, IOMMU group 15
	Memory at fcc00000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
	Kernel modules: nvme
03:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
	DeviceName: Onboard LAN Brodcom
	Subsystem: Intel Corporation Wi-Fi 6 AX200NGW [8086:0084]
	Flags: bus master, fast devsel, latency 0, IRQ 83, IOMMU group 16
	Memory at fcb00000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
	Subsystem: ASUSTeK Computer Inc. Device [1043:208f]
	Flags: bus master, fast devsel, latency 0, IRQ 55, IOMMU group 17
	I/O ports at e000 [size=256]
	Memory at fca00000 (64-bit, non-prefetchable) [size=64K]
	Memory at fca10000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
05:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO [144d:a80a] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd SSD 980 PRO [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 55, IOMMU group 18
	Memory at fc900000 (64-bit, non-prefetchable) [size=16K]
06:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt [Radeon 680M] [1002:1681] (rev c8) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 46, IOMMU group 19
	Memory at 7e10000000 (64-bit, prefetchable) [size=256M]
	Memory at 7e20000000 (64-bit, prefetchable) [size=2M]
	I/O ports at d000 [size=256]
	Memory at fc500000 (32-bit, non-prefetchable) [size=512K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
06:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 19h PSP/CCP [1022:1649]
	Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 20
	Memory at fc400000 (32-bit, non-prefetchable) [size=1M]
	Memory at fc5c8000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: ccp
	Kernel modules: ccp
06:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #3 [1022:161d] (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 45, IOMMU group 21
	Memory at fc300000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
06:00.4 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #4 [1022:161e] (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 47, IOMMU group 22
	Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
06:00.5 Multimedia controller [0480]: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor [1022:15e2] (rev 60)
	Subsystem: ASUSTeK Computer Inc. Device [1043:12cf]
	Flags: bus master, fast devsel, latency 0, IRQ 101, IOMMU group 23
	Memory at fc580000 (32-bit, non-prefetchable) [size=256K]
	Kernel driver in use: snd_pci_acp6x
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
06:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller [1022:15e3]
	DeviceName: HD Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 102, IOMMU group 24
	Memory at fc5c0000 (32-bit, non-prefetchable) [size=32K]
07:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #8 [1022:161f] (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 49, IOMMU group 25
	Memory at fc800000 (64-bit, non-prefetchable) [size=1M]
07:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #5 [1022:15d6] (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 51, IOMMU group 26
	Memory at fc700000 (64-bit, non-prefetchable) [size=1M]
07:00.4 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #6 [1022:15d7] (prog-if 30 [XHCI])
	Flags: bus master, fast devsel, latency 0, IRQ 53, IOMMU group 27
	Memory at fc600000 (64-bit, non-prefetchable) [size=1M]
#################### lsusb ########################
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0b05:19b6 ASUSTek Computer, Inc. N-KEY Device
Bus 001 Device 003: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1b1c:1ba4 Corsair CORSAIR K55 RGB PRO Gaming Keyboard
Bus 003 Device 003: ID 03f0:104c HP, Inc HP 430 Mouse
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
#################### inxi -Fxxc0z ########################
  Kernel: 6.6.34-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM Distro: EndeavourOS
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Strix G713RM_G713RM v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: G713RM v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
    v: G713RM.327 date: 02/16/2023
Battery:
  ID-1: BAT0 charge: 70.5 Wh (100.0%) condition: 70.5/90.0 Wh (78.4%) volts: 16.8 min: 15.9
    model: AS3GWAF3KC GA50358 serial: <filter> status: full
  Info: 8-core model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3+
    rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
  Speed (MHz): avg: 810 high: 2191 min/max: 400/4785 cores: 1: 2191 2: 400 3: 400 4: 400 5: 1799
    6: 400 7: 400 8: 400 9: 1585 10: 400 11: 1434 12: 400 13: 1558 14: 400 15: 400 16: 400
    bogomips: 102254
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia
    v: 550.90.07 arch: Ampere pcie: speed: 2.5 GT/s lanes: 8 ports: active: none off: HDMI-A-1
    empty: DP-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2520
  Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6
    bus-ID: 06:00.0 chip-ID: 1002:1681 temp: 50.0 C
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
    driver: X: loaded: modesetting,nvidia dri: radeonsi gpu: nvidia,amdgpu d-rect: 3840x1080
    display-ID: 0
  Monitor-1: HDMI-A-1 pos: right res: 1920x1080 size: N/A
  Monitor-2: eDP-2 pos: primary,left res: 1920x1080 size: N/A
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast
    gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt LLVM 17.0.6 DRM 3.54
    6.6.34-1-lts) device-ID: 1002:1681 display-ID: :1.0
  API: Vulkan v: 1.3.279 surfaces: xcb,xlib,wayland device: 0 type: discrete-gpu driver: nvidia
    device-ID: 10de:2520
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    pcie: speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:228e
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: snd_pci_acp6x v: kernel
    pcie: speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.6.34-1-lts status: kernel-api
  Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: speed: 5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 8086:2723
  Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: 5 GT/s
    lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8125
  IF: enp4s0 state: down mac: <filter>
[eray@UncleEray ~]$ journalctl -b -0 | grep fail
Jun 18 21:21:19 UncleEray kernel: ACPI: _OSC evaluation for CPUs failed, trying _PDC
Jun 18 21:21:20 UncleEray kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jun 18 21:21:20 UncleEray kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Jun 18 21:21:24 UncleEray kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Jun 18 21:21:24 UncleEray kernel: cfg80211: failed to load regulatory.db
Jun 18 21:21:24 UncleEray kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Jun 18 21:21:25 UncleEray kernel: asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
Jun 18 21:21:30 UncleEray dbus-broker-launch[844]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jun 18 21:21:32 UncleEray dbus-broker-launch[844]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jun 18 21:21:37 UncleEray dbus-broker-launch[844]: Activation request for 'org.freedesktop.ModemManager1' failed: The systemd unit 'dbus-org.freedesktop.ModemManager1.service' could not be found.
                                        "Could not activate remote peer 'org.freedesktop.ModemManager1': activation request failed: unknown unit"
Jun 18 21:21:38 UncleEray kwin_wayland[1168]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:21:38 UncleEray kwin_wayland[1168]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:22:49 UncleEray brave[2235]: [2235:2235:0618/212249.215517:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
Jun 18 21:22:49 UncleEray brave[2235]: [2235:2235:0618/212249.220092:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Jun 18 21:23:08 UncleEray brave[2235]: [2235:2235:0618/212308.548715:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
Jun 18 21:24:34 UncleEray wireplumber[1222]: wp-event-dispatcher: <WpAsyncEventHook:0x5dea3d2c9bf0> failed: <WpSiStandardLink:0x5dea3d1ca9c0> link failed: 1 of 1 PipeWire links failed to activate
[eray@UncleEray ~]$
i dont know what other logs i should provide
Please edit this post, copy the text again and paste it. Then select all the text and click the button highlighted below.
The edit button is the pencil icon:
Thank you! I got scared when i saw all that unformatted text, i hope it’s a bit better now.
Yeah, it’s all good now. No worries. :sweat_smile:
So, to confirm: you have an Asus laptop, with peripherals that include a monitor, and EndeavourOS is installed on an SSD?
As far as freezing is concerned: When was the last time you updated your BIOS?
Just noticed it.
You still have Windows installed, correct?
Indeed, I have tried using it without the monitor, and only on the laptop itself but that seemed to also freeze after a while. Currently i am surviving for 30 mins without freeze.
I have 1 ssd with windows, and another with EOS, and a partition for free space for windows.
I also use a bluetooth mouse if that matters.
My bios is up to date, there havent been any new bios updates for my system in a long time, for over 1 or 2 years.
… speaking of the devil, after i wrote freeze, this page gave me a sigiv error code, then afterwards it froze EOS ( i have had instances where i got sigiv or sigil code in a browser, and could keep using EOS without freezes )
Hmm. Okay.
So you mean SIGSEGV?
Yes 317 is the latest bios provided by the asus website.
I have windows on 1 ssd, and EOS on 2nd ssd, after a partition for windows storage.
Indeed, Sigsegv. but i dont always get that error, most of the times, the freezes happen without that appearing. but i’ve noticed sigsegv and sigil appear in browsers too, often before a freeze. This doesn’t ever happen in browsers in windows
Okay. So memory issues, KDE, Nvidia, Wayland…
Have you tried using an X11/Xorg session?
I have not heard of x11 or xorg no, nor how to use it.
Okay. That’s fine.
  • Log out, then look for something that says “Wayland” or has the KDE logo or EndeavourOS logo.
  • Click on it, then select the one that says “X11/Xorg”.
  • Finally, log back in and use your laptop like normal to see if you have any issues.
Of course, it would take a while for any issues to happen, if any, so no need to reply for a while. But let us know how it goes. :wink:
On SDDM with the default theme this should be on the bottom left
It sure seems like using X11, for now, fixed it? i am not so sure, i have been able to go with wayland for an hour too.
i had an issue where i randomyl just logged out, not sure if thats related but afterwards i tried wayland again, and it froze after 10 mins, and when back to x11… it works
i am confused why, i checked some logs from wayland with journalctl | grep -i 'wayland.*]: ’
and got this:
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: No backend specified, automatically choosing drm
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: OpenGL vendor string:                   AMD
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: OpenGL renderer string:                 AMD Radeon 680M (radeonsi, rembrandt, LLVM 17.0.6, DRM 3.54, 6.6.34-1-lts)
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: OpenGL version string:                  4.6 (Core Profile) Mesa 24.1.1-arch1.1
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: OpenGL shading language version string: 4.60
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: Driver:                                 Unknown
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: GPU class:                              Unknown
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: OpenGL version:                         4.6
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: GLSL version:                           4.60
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: Mesa version:                           24.1.1
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: Requires strict binding:                no
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: Virtual Machine:                        no
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: Timer query support:                    yes
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT"
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:21:36 UncleEray kwin_wayland[1168]: kwin_wayland_drm: Failed to create framebuffer: Invalid argument
Jun 18 21:21:37 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: > Warning:          Unsupported maximum keycode 708, clipping.
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: >                   X11 cannot support keycodes above 255.
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrevgrou
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: > Warning:          Could not resolve keysym XF86KbdInputAssistNextgrou
Jun 18 21:21:37 UncleEray kwin_wayland_wrapper[1299]: Errors from xkbcomp are not fatal to the X server
Jun 18 21:21:38 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:21:38 UncleEray kwin_wayland[1168]: kwin_core: Could not find window with uuid "{f6b37d4e-5148-40b0-ae79-26a3f4e1eaee}"
Jun 18 21:21:42 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:21:42 UncleEray kwin_wayland[1168]: kwin_scene_opengl: 0x2: GL_INVALID_VALUE in glTexStorage2D(width, height or depth < 1)
Jun 18 21:21:42 UncleEray kwin_wayland[1168]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:21:42 UncleEray kwin_wayland[1168]: kwin_scene_opengl: Can't enable invalid framebuffer object!
Jun 18 21:21:42 UncleEray kwin_wayland[1168]: kwin_scene_opengl: 0x2: GL_INVALID_FRAMEBUFFER_OPERATION in glClear(incomplete framebuffer)
Jun 18 21:22:49 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:23:42 UncleEray kwin_wayland[1168]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x63f8628cc950)
Jun 18 21:24:37 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:24:52 UncleEray kwin_wayland[1168]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Jun 18 21:24:52 UncleEray kwin_wayland[1168]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Jun 18 21:25:57 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:27:23 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:27:24 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:34:22 UncleEray kwin_wayland[1168]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:34:25 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:35:42 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:38:05 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:38:06 UncleEray kwin_wayland[1168]: This plugin does not support raise()
Jun 18 21:40:35 UncleEray kwin_wayland[1173]: No backend specified, automatically choosing drm
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: OpenGL vendor string:                   AMD
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: OpenGL renderer string:                 AMD Radeon 680M (radeonsi, rembrandt, LLVM 17.0.6, DRM 3.54, 6.6.34-1-lts)
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: OpenGL version string:                  4.6 (Core Profile) Mesa 24.1.1-arch1.1
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: OpenGL shading language version string: 4.60
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: Driver:                                 Unknown
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: GPU class:                              Unknown
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: OpenGL version:                         4.6
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: GLSL version:                           4.60
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: Mesa version:                           24.1.1
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: Requires strict binding:                no
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: Virtual Machine:                        no
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: Timer query support:                    yes
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT"
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:40:36 UncleEray kwin_wayland[1173]: kwin_wayland_drm: Failed to create framebuffer: Invalid argument
Jun 18 21:40:37 UncleEray kwin_wayland[1173]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: > Warning:          Unsupported maximum keycode 708, clipping.
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: >                   X11 cannot support keycodes above 255.
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrevgrou
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: > Warning:          Could not resolve keysym XF86KbdInputAssistNextgrou
Jun 18 21:40:37 UncleEray kwin_wayland_wrapper[1303]: Errors from xkbcomp are not fatal to the X server
Jun 18 21:40:38 UncleEray kwin_wayland[1173]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:40:38 UncleEray kwin_wayland[1173]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:40:38 UncleEray kwin_wayland[1173]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:40:41 UncleEray kwin_wayland[1173]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:40:41 UncleEray kwin_wayland[1173]: kwin_scene_opengl: 0x2: GL_INVALID_VALUE in glTexStorage2D(width, height or depth < 1)
Jun 18 21:40:41 UncleEray kwin_wayland[1173]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:40:41 UncleEray kwin_wayland[1173]: kwin_scene_opengl: Can't enable invalid framebuffer object!
Jun 18 21:40:41 UncleEray kwin_wayland[1173]: kwin_scene_opengl: 0x2: GL_INVALID_FRAMEBUFFER_OPERATION in glClear(incomplete framebuffer)
Jun 18 21:40:42 UncleEray kwin_wayland[1173]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:44:46 UncleEray kwin_wayland[1173]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
Jun 18 21:44:46 UncleEray kwin_wayland[1173]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
Jun 18 21:46:11 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:46:12 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:46:17 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:46:18 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:46:30 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:46:43 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:47:45 UncleEray kwin_wayland[1173]: This plugin does not support raise()
Jun 18 21:51:08 UncleEray kwin_wayland[1173]: kwin_core: XCB error: 3 (BadWindow), sequence: 2873, resource id: 20971566, major code: 129 (SHAPE), minor code: 6 (Input)
Jun 18 21:53:17 UncleEray kwin_wayland[1173]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: No backend specified, automatically choosing drm
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: OpenGL vendor string:                   AMD
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: OpenGL renderer string:                 AMD Radeon 680M (radeonsi, rembrandt, LLVM 17.0.6, DRM 3.54, 6.6.34-1-lts)
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: OpenGL version string:                  4.6 (Core Profile) Mesa 24.1.1-arch1.1
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: OpenGL shading language version string: 4.60
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: Driver:                                 Unknown
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: GPU class:                              Unknown
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: OpenGL version:                         4.6
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: GLSL version:                           4.60
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: Mesa version:                           24.1.1
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: Requires strict binding:                no
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: Virtual Machine:                        no
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: Timer query support:                    yes
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT"
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:56:01 UncleEray kwin_wayland[1183]: kwin_wayland_drm: Failed to create framebuffer: Invalid argument
Jun 18 21:56:03 UncleEray kwin_wayland[1183]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: The XKEYBOARD keymap compiler (xkbcomp) reports:
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: > Warning:          Unsupported maximum keycode 708, clipping.
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: >                   X11 cannot support keycodes above 255.
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: > Warning:          Could not resolve keysym XF86KbdInputAssistPrevgrou
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: > Warning:          Could not resolve keysym XF86KbdInputAssistNextgrou
Jun 18 21:56:03 UncleEray kwin_wayland_wrapper[1323]: Errors from xkbcomp are not fatal to the X server
Jun 18 21:56:04 UncleEray kwin_wayland[1183]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:56:04 UncleEray kwin_wayland[1183]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 18 21:56:04 UncleEray kwin_wayland[1183]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:56:08 UncleEray kwin_wayland[1183]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:56:09 UncleEray kwin_wayland[1183]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 18 21:56:09 UncleEray kwin_wayland[1183]: kwin_scene_opengl: 0x2: GL_INVALID_VALUE in glTexStorage2D(width, height or depth < 1)
Jun 18 21:56:09 UncleEray kwin_wayland[1183]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Jun 18 21:56:09 UncleEray kwin_wayland[1183]: kwin_scene_opengl: Can't enable invalid framebuffer object!
Jun 18 21:56:09 UncleEray kwin_wayland[1183]: kwin_scene_opengl: 0x2: GL_INVALID_FRAMEBUFFER_OPERATION in glClear(incomplete framebuffer)
Jun 18 21:56:30 UncleEray kwin_wayland[1183]: kwin_xwl: Could not create a source from 0x591e6e0d1550 0
Jun 18 21:56:30 UncleEray kwin_wayland[1183]: kwin_xwl: Could not create a source from 0x7e8548002ec0 0
Jun 18 21:56:30 UncleEray kwin_wayland[1183]: QtDBus: cannot relay signals from parent QObject(0x591e6cd30da0 "") unless they are emitted in the object's thread QThread(0x591e6ca4d8e8 "libinput-connection"). Current thread is QThread(0x591e6c8eb960 "").
I read things about amd, but nothing about nvidia, maybe wayland isnt using my gpu im not sure.
I have set with optimus manager to use nvidia card for testing purposes.
So if wayland was the problem, would you know why? I heard wayland is like the … replacement for x11 and repos are even removing x11 support, do i need to configure wayland for nvidia perhaps?
This will happen at some point but I don’t see it happening this year (I could be very wrong also, there’s a reason I don’t gamble)(and to clarify this would be desktop specific, there is still a lot of things that only work onX11 )
Edit: everything was going well, i then turned on hybrid on on optimus manager… so it can switch between my dgpu and dgpu… im not sure if this caused it but when i opened a youtube video, it froze, but the audio continued.
even then, its running way longer than with wayland.
I will let update you tomorrow after using EOS the whole day, and see how it goes. If anyone knows how a nvidia user can use wayland, that would be appreciated as well :slight_smile: kind of scared about wayland replacing x11, like smokey said, it will happen at some point :confused:
Troubleshooting
  • Driver Updates: Ensure NVIDIA drivers are up to date.
  • Optimus Manager Settings: Check and configure Optimus manager for optimal GPU switching.
  • System Logs: Monitor logs for any specific errors or warnings that may provide insights into the freezing issue.
