I recently upgraded to the 8/2 build of Canary, but I am having some issues.
Here is my duplicati.service file:
[Unit]
Description=Duplicati
After=network.target
[Service]
ExecStart=/opt/duplicati/duplicati-server --webservice-port=8200
Restart=on-abort
EnvironmentFile=-/etc/default/duplicati
User=root
Group=root
[Install]
WantedBy=default.target
NOTE: I did change User/Group to root (and had no issues with prior releases)
Here is the status of duplicati.service:
● duplicati.service - Duplicati
Loaded: loaded (/usr/lib/systemd/system/duplicati.service; enabled; preset: disabled)
Active: active (running) since Tue 2024-08-06 13:53:01 EDT; 3s ago
Invocation: 1c23807310aa4d2f8fccb9009a4afa1c
Main PID: 180636 (duplicati-serve)
Tasks: 12 (limit: 76762)
Memory: 68.5M (peak: 69.7M)
CPU: 3.181s
CGroup: /system.slice/duplicati.service
└─180636 /opt/duplicati/duplicati-server --webservice-port=8200
Aug 06 13:53:01 nx1701i systemd[1]: Started Duplicati.
If I try the web interface here:
http://localhost:8200/login.html
No matter the browser I get: Unable to connect
If I try to telnet I get:
telnet localhost 8200
Trying ::1…
Connection failed: Connection refused
Trying 127.0.0.1…
telnet: Unable to connect to remote host: Connection refused
However if I stop the duplicati.service and run this in the terminal:
It works perfectly with http://localhost:8200/login.html no matter the browser.
I did change User/Group back to duplicati and retried everything but same issue.
What would cause this?
Thanks!
