Lightweight word processor and spreadsheet for Xfce
hi all, I have no office suite installed as I only use a word processor and spreadsheet occasionally, any recommendations please?
gnumeric and abiword are both light apps - standalone not so much - but light in the sense they don’t take much space.
You could try a appimage. Not always lightweight but small in size and standalone definitely.
Only office and libre offer them
Collabora (or another online editor) is very lightweight. Otherwise just install LibreOffice and forget about it. What’s disk space for if not to have applications installed?
One more vote for LibreOffice. If your machine ran Manjaro well, then performance should be no problem.
Note that there are basically two versions of LibreOffice: libreoffice-fresh (the latest available) and libreoffice-still (more conservative and tested for a longer time). Both are OK for occasional use.
Unless you are content with some online office solutions…
As an alternative, have a look at OnlyOffice (desktop version with stand-alone apps), it has a very nice and modern looking user interface (I don’t know why the link from the English page is shown as German below…):
Auf Englisch:
https://www.onlyoffice.com/de/download-desktop.aspx
because you have de inside :wink:
I would add my vote for Libre Office. I t doesn’t take up as much room as might be thought - a LOT of it is ‘common code’, and adding in the ‘rest of the pieces’ is quite low cost. It also gives you a common install which means help/assistance is always available if you have problems. I used to install AbiWord and Gnumeric, but if something didn’t work right…
the concensus seems to be libre office, so will go with that, thanks all
Or just google docs :grin::raised_hand_with_fingers_splayed:
No deps needed and usable in browser. Abiword and gnumeric is pretty lightweight… You notice the speed vs libreoffice. But standards are different story
I use google docs to save my bashrc aliases etc, then if the worst happens, its easy for me to quickly set up after reinstall, I need libreoffice for saving backups of gramps family history etc and doing reports, also found libre office draw useful for sorting photo prints ie 2 on one page etc
