Hi all,
I installed Endeavouros sway Edition and continued by also installing the Bspwm aswell.
I then converted the system from grub to systemd-boot. So far everything works.
I then decided to pimp lightdm with lightdm-webkit-theme-litarvan witch is an Webkit2 LightDM theme.
It seems to work but when logging in to Sway it stays loged in about a minute or two and then log you out/crash I dunno. Login to Bspwm works as supposed.
Anyone seen this before?
Best regards,
